NASOCEANA
FS9 Fuel Calculations?
Sun Sep 11, 2005 7:17 am
I calculate my fuel for a 4500nm with a B777-300 flight as follows:
4500nm/480knts = 9.375 hrs x 22,000lbs = 206,250lbs x 1.08 = 222,750lbs and depending on the airport I'll add taxi fuel according to EST. taxi time.
So I will use 222,300lbs + taxi fuel to complete a 4500nm trip.
The 22,000lbs is fuel consumption per engine per hr. (11,000 x 2).
The 1.08 is used as my reserve fuel, usually 45 min. worth. (16,500)
Are these calculations correct? I usually arrive at my destination with about 20,000lbs in the tank when landing.
I think that the fuel calculations given in FS are not realistic so I compute my own for each trip.
How do you calculate fuel and cruise level for your trips?
B777 greatest Airliner ever built!
atco2b
RE: FS9 Fuel Calculations?
Tue Sep 13, 2005 9:47 pm
I do mine a bit simpler than that Big grin
I do the Route-Planner, see what i need then add on about 50% extra.
Usually get it about right  Wink
Hey, you want to go out for pizza and some sex? What, you don't like pizza?
Goldenshield
Sat Sep 17, 2005 12:16 am
While nowhere near exact, if we use 121 flag rules, and the figure that you have provided, I estimate a minimum release fuel of 225,000 pounds.
BURN 206250
ALTN 000000
INTL 002200
HOLD 016500
RLSF 224950
LAND 018700
intothinair
Mon Sep 19, 2005 7:28 pm
Yeah, it doesn't seem to be perfectaly accurate. On a different note, according to FS the Learjet 45 flies 2200NM. maximum. I managed to fly it just over 5000NM(No joke) non stop, that being with a 70pounds light pilot and no pax or baggage, and at a little bit higher altitudes. Does it really make such a difference?i can't imagine so, in real life i mean.
Cheers, Konstantin G.
