Qantas744er
Project Opensky
Sat Oct 15, 2005 2:04 am
Hey, i enjoy using the 747-400 from project opensky alot! The only thing that P**ses me off is the fact that wen im even 50,000 pounds under MTOW, the plane totates at only 190-220 knots!!!! ive used trim but if ipull her to much im just gonna scratch her tail.
i want to edit the Aircraft file wat could i change for better lift???
PLEASE HELP  Sad i reallyenjoy flying on FS
Cheers leo
You live and you die, by the FMA
CO737
RE: Project Opensky
Sat Oct 15, 2005 3:53 am
I've noticed the same thing with the POSKY model, and I haven't found a fix for the aircraft file that will fix it. I do, however, use 15 degrees of flaps (as opposed to 5 or 10 for other aircaft) whenever I takeoff, and I just remember to rotate at a faster airspeed. With 15 degrees of flaps, you can usually rotate around 180 KIAS.
Qantas744er
RE: Project Opensky
Sun Oct 16, 2005 1:14 am
Yeah it sucks and thats the reason i bought PMDG`S 747-400 yesterday im SOOOOOOOO AMAZED by that aircraft!!! It sure is worth its money well if you wanna check it out heres the link Big grin thanks anyways.
www.precisionmanuals.com
Cheers Leo
Users browsing this forum: zippity and 1 guest
