keta
Is The Ground Effect Simulated?
Wed Oct 19, 2005 11:40 pm
Either in FS9, X-plane or other simulator, is this effect simulated?
Keta
Where there's a will, there's a way
A3204eva
RE: Is The Ground Effect Simulated?
Wed Oct 19, 2005 11:55 pm
Which ground effect? There are many
"They have lady pilots......... they're not that good, but they have 'em"
bully707
Thu Oct 20, 2005 12:11 am
Quoting A3204eva (Reply 1):
I think he means the "real" ground effect....!!
The one that will "suck" your aircraft into the ground, when being too low....
However, I don't think that has been implemented in any sim so far....
Correct me if I'm wrong...  Wink  Wink
Bully
"That's the good thing about the 707...it can do anything, but read!" Joe Patroni, Airport '70
David L
Thu Oct 20, 2005 12:27 am
Quoting Bully707 (Reply 2):
... or the one which cushions the aircraft and creates more lift as you near the ground. I'm not aware of the one which sucks an aircraft into the ground.
I'm afraid I'm not sure if it's modelled.
Edit: Bully707: sorry about that! (Note to self - read the entire post before responding!)
[Edited 2005-10-19 17:28:51]
[Edited 2005-10-19 17:29:26]
keta
Thu Oct 20, 2005 12:50 am
Yes I was referring to the effect that creates more lift. Thanks guys for your answers.
Quoting David L (Reply 3):
I'm lost...  Confused
SWISSER
Thu Oct 20, 2005 3:18 am
The famous flare cushion?
Comparing a Level-D A340 flight simulator to the PSS A340, I witness similar effect on flaring, so I guess the PSS add-on does it.
Altough the Level-D is much more sensitive in the way it will get you longer to drop altitude, but again the difference is not much.(much more is the initial climb-out, the PSS climbs like a rocket!)
I haven't done many landings in the original jets of FS9, but I do remember they are always harder!
So I guess some add-on's and aircraft simulate this effect.
What time is top of descent?
bully707
Thu Oct 20, 2005 6:00 am
Quoting Keta (Reply 4):
I'm lost... {Confused}
Don't be...!!!
It is I who did get things confused and wrote a totally stupid post....  Sad
Sorry...but I was somewhat "lost" and therefor "created" a ground effect that will suck your aircraft into the ground....  banghead
Godspeed
Bully
Fly2HMO
Thu Oct 20, 2005 6:17 am
X-plane does in any plane, FS9 doesn't.
David L
Thu Oct 20, 2005 7:46 am
Quoting Bully707 (Reply 6):
I'm lost...
What happened was that I posted in response to Bully707's post about the "sucking" ground effect and thought I was being smart by correcting him. After I'd posted I noticed the rest of his post where he said he wasn't being serious. I had to edit the post to add the apology!
keta
Thu Oct 20, 2005 8:00 pm
Quoting David L (Reply 8):
OK, I get it, don't worry mates  Wink
Quoting FLY2HMO (Reply 7):
So X-Plane does have it? Man this sim is awesome!
