aileron11
Can Not Pick Up ATC
Fri Oct 21, 2005 4:25 am
Does anybody know why I can only pick up airplanes talking on my scanner and not ATC? When atc talks to airplanes I should pick then up just like the airplanes. Also just to let you all know I am new in aviation it is a hobby I just started and SO far I find it a lot of fun. And one last thing what is a good camera for beginners thanks.
Jersey Lou
SA006
RE: Can Not Pick Up ATC
Fri Oct 21, 2005 4:57 am
Quoting Aileron11 (Thread starter):
Most air-band scanners are line of sight so they plane has to be flying near your area or you need to be near an airport. You also have to know the frequencies for control centres around your area.
Try a search of that topic in the aviation-photography forum , there are many topics on it.
-SA006  wave
Proudly South African
nighthawk
Fri Oct 21, 2005 6:44 am
as mentioned by SA006...radio receivers work on line of sight. If there is a mountain, or buildings between you and the airport transmitter then you will not receive a signal, and will instead only hear signals from the aircraft.
How far are you from the nearest airport?
SPREE34
Mon Oct 24, 2005 11:38 am
When you travel take it with you. Sometimes ACC/ARTCC remote sites are where you least expect them. They usually are not at an airport.
I don't understand everything I don't know about this.
solarix
Tue Oct 25, 2005 1:21 pm
Where are you located? What kind of antenna are you using? The rubber duck that came with your scanner is not the best antenna for airband. In fact, unless you monitor from the airport, don't expect to hear much on it.
You may want to consider an outdoor antenna such as a discone or Scantenna (antennawarehouse.com). It doesn't even have to be mounted outdoors for it to work better than your rubber duckie. But if you can put it outside, by all means do it!
I live about 40 miles from ONT and can hear the tower when using an outdoor antenna. I can also pick up BUR ATIS from my location which is about 90 miles away. And in Utah, I can hear the SLC ATIS from about 100 miles away (this while in the car with an external antenna on the roof).
If you want to go "all out" try a yagi (directional antenna) cut for airband. They are very directional but offer gain and will likely improve you signal quite noticeably.
Good luck.
Bong Hits 4 Jesus
