phatfarmlines
Command To Open Up Posky A330 Cargo Doors?
Thu Oct 27, 2005 10:32 am
I seem to have forgotten the command to open up the POSKY A330 cargo doors. I know it exists because you can see the gMax cutout of the cargo doors. It isn't Shift+E2, Ctrl+I, and Shift+T since I tried those. I also tried to open them using the "Water Rudder" command but to no avail. If anyone here knows the command please post it, thanks.
komododx
RE: Command To Open Up Posky A330 Cargo Doors?
Thu Oct 27, 2005 10:56 am
Try Shift+F or Shift+W.
Stefano  wave
I'm homeless and unemployed
phatfarmlines
Fri Oct 28, 2005 11:28 am
Those are not working either. "Shift+F" is set to "Retract Concorde Visor" while "Shift+W" is the Water Rudder command. Should I change these assignments?
jeffry747
Sat Oct 29, 2005 12:11 pm
I couldn't figure out myself what was the command for opening doors and such so I assigned my own key command for it: Shift+D. And when I tried it on the POSKY KLM A330, all it did was open the passenger doors on the right side of the aircraft.
C'mon Big B, FLY!
planesailing
Sun Oct 30, 2005 4:26 am
You need to assign tail hook and wings folding, they are not allocated as standard. I use Shift+C and Shift+V for mine, as these are free.
phatfarmlines
Mon Oct 31, 2005 12:22 am
Problem solved.
After unassigning and reassigning the keys multiple times with no success, I decided to check in the aircraft.cfg file to see what settings the tailhook/wingfold/exits were configured to. I discovered that the [exits] configuration was not even present in the aircraft.cfg file, for some mysterious reason. I then downloaded a base POSKY 330V2, and copied the [exits] configuration to the problem A330. The cargo doors now open with the "Shift+E2", in addition, the main door now opens with "Shift+E" which I also discovered was not opening.
Moral of the story: Check the aircraft.cfg file to verify the tailhook/wingfold/exits configuration are present and accurately configured. Without them, anyone attempting to assign keys to open doors without these configurations in place will discover that the commands will not work.
