FaroeFlyer
AIsmooth
Sun Nov 13, 2005 8:11 pm
Had earlier versions of this program and it worked fine.
However now, after downloading v1.11a it is idle at best.
I suspect my settings might be wrong. Can any of you guys, who get this program to work, tell me your settings for me to try out.
Kristoffer
Cast your dancing spell my way...
FaroeFlyer
RE: AIsmooth
Mon Nov 14, 2005 10:52 pm
I can't believe no one has answered yet.
Kristoffer
flyingKangaroo
RE: AIsmooth
Tue Nov 15, 2005 12:31 am
I don't use it, so I cant answer..you may get more hits in the FS question thread though.
flyingKangaroo
QANTAS-- The Spirit of Australia
David L
RE: AIsmooth
Tue Nov 15, 2005 12:50 am
If someone who can answer sees the question, they'll answer.
chrisjake
RE: AIsmooth
Wed Nov 16, 2005 1:29 am
Kristoffer.......you may want to try posting this question in the FS2004 forum at www.AVSIM.com also.
i use AIsmooth but mine seems to run flawlessly.
chris
FaroeFlyer
RE: AIsmooth
Wed Nov 16, 2005 6:55 am
Quoting Chrisjake (Reply 4):
So why don't you do me a favour and tell me your settings?
chrisjake
RE: AIsmooth
Wed Nov 16, 2005 7:21 am
i use the default settings. the only thing i did was turn the ATC sound off.
FaroeFlyer
RE: AIsmooth
Wed Nov 16, 2005 7:09 pm
Strange... I use default settings too and it runs but airplanes still wont do holding patterns.
drerx7
RE: AIsmooth
Wed Nov 16, 2005 11:41 pm
Mine is running fine--when I get on my home pc I'll post my settings. What airport are you primarily travelling from?
Third Coast born, means I'm Texas raised
FaroeFlyer
RE: AIsmooth
Thu Nov 17, 2005 2:19 am
Well, I mostly fly from ARN, CPH and OSL.
Are the settings dependent on the airports you fly to/from? Don't they work equally good on all airports?
drerx7
RE: AIsmooth
Thu Nov 17, 2005 6:17 am
Well it should--the only thing funny about aismooth I notice is that some of my ai will fly at strange bank angles when turning.
FaroeFlyer
RE: AIsmooth
Thu Nov 17, 2005 2:25 pm
Ok, please post you settings when able.
btw: checked out your website www.wreckfastclub.net
Seems you and your friends are having a blast. Keep it up  Smile
drerx7
RE: AIsmooth
Thu Nov 17, 2005 11:26 pm
I appreciate that--I'm gonna check them before the day is over.
FiddleSticks
RE: AIsmooth
Thu Nov 17, 2005 11:52 pm
This old thread might be of use:
At Last, No More Go-Arounds And Holding Patterns! (by Gofly May 12 2005 in Aviation Hobby)
Check replies # 12 and # 15 for some test results from both AI Smooth and FS AI Separation as well as some info about how both programs function.
For FS AI Separation just search for fsaisv1.1.zip on avsim.
If you love yourself, go now to western union and send me the sum of $10,000 to save your life.
drerx7
RE: AIsmooth
Fri Nov 18, 2005 10:05 am
System poll interval [msec]: 500
Min. separation time [sec]: 120
Intercept radius [NM] 8.0
Intercept radius user plane [NM]: 5.0
heading tolerance: 60
Initial Approach Fix Distance [NM] 25.0
Minimum IFR hold altitude: 2000.0
Landing Release Altitude: 5.0
Roll-out speed [kt]: 100
AI planes respond to user plane: Check
Display ATC messages: check
I think those are pretty close to default settings--I changed a couple. You may also want to try and post on www.projectai.com 's forum.
Good luck
FaroeFlyer
RE: AIsmooth
Sat Nov 19, 2005 4:03 am
Thank you, will try.
But for some strange reason neither airsmooth nor ai seperation work right now.
When either program is running and trying to switch to full screen mode, game freezes and the cursor begins to flicker intensly between normal and hour glass. Then FS reports an error and shuts down. Suspect it to be a video driver issue, but this only happens with those two programs running
Maybe it has something to do with the interraction between the two, but Active Sky works... has anyone had this problem before?
