SWISSER
PSS 777 Merges With Meljet's -200ER -200LR -300ER
Sun Nov 27, 2005 6:39 am
I' am working on a B777-200ER adaptation and merge for the PSS 772LR package with the Meljet 772ER, it's been nervwrecking to complete because of the different thrust ranges/tanks and weights, but...
It's 95% complete right now and I' am planning some testflights to check the performances on how a 777-200ER should react!
Currently I only have the GE-90-94B model and to be exact, the 142000 EOW version of AF, the newest version with the new cabin layout.
This is what I' am working on for the adaptation process:
* Correct tank layout for the 777-200ER
* Correct engine specifications according to the GE-90-94B
* Correct weight for the 200ER
* David Ebeling's exell sheet fuel planner for 200ER being adapted to kg for the european users and according to the GE-90-94B
* adapted loadout of the PSS exell sheet to the 200ER
Since the developers requested to not upload any merge to Avsim etc. I will only distribute it via Email,
which is karel.vanhees@swiss-va.com
Also for the ones waiting for the 773ER merge with Meljet,
tommorow or sunday it will be ready for release!
The 772LR merge is already available!
What time is top of descent?
Qantas744er
RE: PSS 777 Merges With Meljet's -200ER -200LR -300ER
Sun Nov 27, 2005 9:08 am
That is just great!!! Thanks, and welcome to my Respected Usesers list Big grin
i already sent you an email about the meljet 777-300ER merge, if you need my email kikass92@hotmail.com, keep this great work up! Big grin
Cheers leo
You live and you die, by the FMA
SWISSER
Mon Nov 28, 2005 12:38 am
Hi Leo!
I' am still having some little fuel consumption/power problems on the 200ER,
that I' am going to fix today, so there might be a little delay on the 773ER's release, but certainly tonight it will be done!
Reaching FL310 and keeping M.84 is very hard with a full load and that is not normal 200ER behaviour, also the engines should give 88.3%N1 and a FFof 3.5 at FL340 with GE90-94B where it in my current merge setup gives around 7.0FF and 92%N1...
It climbs even slower then an A340-200...
So still some work there!
Anyway I have the .CFG configured that the .Air file knows the correct dimensions of the 200ER, and the weight and tank position is correct!
I only need to test the autoland function properly when the correct power setting is ok!
SWISSER
Mon Nov 28, 2005 3:53 am
Well...
after almost 2 weeks of work it's done!
the FF is correct, same as the N1 setting and the climb rate is ok now!
The 777-200ER is finished.
So however who wants the files,
can contact me on
I still need to tweak the 772LR PSS/meljet merge because I noticed some balance issues, flap configs and Geometry problems, but the first release file I made earlier is already flyable.
[Edited 2005-11-27 19:55:36]
SWISSER
Sun Dec 11, 2005 6:55 pm
Hi Guys,
I noted some users mailed me about the climb performance of the 777's,
I can assure you the performance of the PSS FDE is quite realistic at MTOW, altough I noted there is still a problem with the trim and tailplane geometry.
The climb rate from GL to FL330 with MTOW is about 30 to 45 minutes,
which is quite fast actually (realistically) compared to other aircraft.
While many add-ons of FSIM climb like a rocket it is either of two things,
1. they are loaded almost empty.
2. the FDE is not correctly setup.
In either way,
you can change the power value yourself,
I have put in instructions in the .CFG merge file how to adjust the thrustrange should you think it's underpowered! I personally have tweaked this a lot to have the most realistic 777-200ER performance while climbing.
currently the 200ER is at 94k lbs, 200LR is at 105k lbs and 300ER at 115k lbs.
SWISSER
Sun Dec 18, 2005 1:45 am
Just to let you know that all files are in "frozen" condition now!
So there won't be any updates anymore unless some problems show up.
The maximum is out of the merges now, but please post you're thoughts and problems here in this thread!
Any comments are highly appreciated and can be used for further adaptation if possible!
B777-200LR
B777-228ER
B777-328ER
SWISSER
Tue Dec 20, 2005 12:52 pm
Hi Guys,
since there is a huge demand for the files,
I uploaded them to the forum of SWISS-VA,
you can find them here:
http://www.swiss-va.com/forum/index....s=276ad763d2b24dfa5927e8759af3c69d
Take note that I updated some values regarding the trim settings on the 300ER 200ER and 200LR.
It's still a mystery what caused the effect for the bad elevator effectiveness, but anyway it is fixed and the VR speed really is VR.
I advice all users to update.
Any problems with them,
post them here or mail me!
SWISSER
Tue Dec 20, 2005 2:03 pm
BTW,
here are some wing views and correct placement of the views,
place them into the PANEL.CFG VIEWS section,
[VIEWS]
VIEW_FORWARD_WINDOWS=9000, 9001, 8270, 8271, 8272, 8273, 8274, 8276, 8277, 8278
VIEW_FORWARD_ZOOM=1.000
VIEW_FORWARD_EYE=0.0, 0.5,0.0
VIEW_FORWARD_DIR=9.000, 0.000, 0.000
VIEW_DOWN_WINDOWS=37
VIEW_DOWN_DIR=-5.000, 0.000, 0.000
VIEW_LEFT_EYE=-1.8, -0.1, -31
VIEW_LEFT_DIR=0.0, 0.0,270
VIEW_RIGHT_EYE=3.4, -0.1, -31
VIEW_RIGHT_DIR=0.0, 0.0,90
VIEW_REAR_LEFT_EYE=-2.02, -0.1, -8.5
VIEW_REAR_LEFT_DIR=11, 0.0,225
VIEW_FORWARD_LEFT_EYE=-1.02, -0.1, 1
VIEW_FORWARD_RIGHT_EYE=2.4, -0.1, 1
VIEW_REAR_RIGHT_EYE=3.63, -0.1, -8.5
VIEW_REAR_RIGHT_DIR=11, 0,135
VIEW_REAR_EYE=-0.9, 0.5, -2.7
VIEW_REAR_DIR=8, 0.0,135
SWISSER
Thu Feb 02, 2006 8:20 am
I noticed the link is dead for the merges.
Stay tuned as I will re-arrnage them soon!
SWISSER
Fri Mar 10, 2006 6:31 am
http://www.swiss-va.com/forum/index....s=76bfe006a1159b69e19b8549657a4470
Here is the new link guys!
Sorry for the delay and have fun!
speedbird128
Fri Mar 17, 2006 9:14 pm
Thanks for the work SWISSER!!!
A306, A313, A319, A320, A321, A332, A343, A345, A346 A388, AC90, B06, B722, B732, B733, B735, B738, B744, B762, B772, B7
gotAirbus
Mon Aug 21, 2006 7:12 pm
Dude,
The whole swiss virtual is protected? The file links to the forum where I need to be a Swiss VA member to login...
(gotAIRBUS?) - (Got Commonality?) - (Have A Nice Flight!)
krisyyz
Mon Aug 21, 2006 9:59 pm
Quoting SWISSER (Reply 9):
I've been using that merge file for a while now, it works great! I love how the payload editor is compatible as well.
Many thanks...
It would be awesome if the Meljet -200ER models were merged with the PSS panel as well.
krisYYZ
gotAirbus
Mon Aug 21, 2006 10:55 pm
Still a no-go...
Swisser, you've got PM...
SWISSER
Sun Sep 24, 2006 12:20 pm
Try this link guys, and let me know if it still does'nt work.
Otherwise I'll have to move it to my private server.
BTW,
enjoy
http://www.forum2.swiss-va.com/index...s=550eec3ebd7e98d71a12e60ef977fc2a
SWISSER
Sun Sep 24, 2006 12:23 pm
Quoting KrisYYZ (Reply 12):
They are Kris!
try the upper file in the forum!
B737200
Sun Sep 24, 2006 4:13 pm
Sorry to be one to break the bad news but the link still isn't working. It says I need to login to use the forum Sad
Lady Guinness is ready to fly...
SWISSER
Sun Sep 24, 2006 5:26 pm
Quoting B737200 (Reply 16):
mmm... Typically!
I own the godd*mn server and people still change stuff all the time!
give me some time to figure it out! (read:fix it!)
OK, try again,
see if it works!
I' am not that super at managing forum acces etc. but it should work!
If not I ask my friends at SWISS-VA to get it fixed!
[Edited 2006-09-24 10:35:40]
B737200
Sun Sep 24, 2006 6:41 pm
Still the same. It says I need to enter a username and password.
Thanks a lot for your time and efforts SWISSER. If you perhaps want to try an other method just tell me.
SWISSER
Sun Sep 24, 2006 11:10 pm
Ok let's do it manually then!
I will give the CFG's here in a post, you need to download a specific Meljet 777 and paste everything manually.
Then you need to paste the PSS 777 panel, sound and .AIR file into the meljet 777, put the folder in aircraft and it should work!
777-200ER:
rename this area into the aircraft of your choice;
[fltsim.0]
title=PSS Boeing 777-200LR Boeing <--- leave this or the CDU will be wrong!//put a title of your aircraft next to it without the //!//
sim=PSSB777LR-GE
model=
panel=
sound=
texture=
ui_manufacturer=Boeing-PSS<----//you can change this!//
ui_type="Boeing 777-228ER"<----//you can change this!//
ui_variation=Air France F-GSPR<----//you can change this!//
atc_id=F-GSPR<----//you can change this!//
atc_airline=AIR FRANCE<----//you can change this!//
atc_flight_number=
atc_heavy=1
COPY AND PASTE BEHIND THIS LINE IN THE MELJET AIRCRAFT.CFG:
(DO NOT FORGET TO CHANGE THE FLIGHTSIM 0 SECTION!)
//Thank you for using this FDE merge file for Meljet and PSS, it has been very intense and fun for me to convert the original 777-200LR flight model into a full working 200ER, but //after almost two weeks of testing and comparing, the FDE is complete to my personal standards and that's a very narrow margin of difference with the reality. The actual subject //used for this merge is the Air France GE90-94B version, since this aircraft is quite popular and has the GE panel layout, off course it will work with other 777-200's of Meljet, //just replace evrything starting after fltsim.0, and take note regarding the thrust setting for you're 777, find the Turbineenginedata section in this file and read the //instructions. Take note that you still need the original .AIR file of the PSS LR package and this file is unusable if you don't own the exellent PSS software.
//Oh yes, the Air France ZIP file on avsim is called,
//jp_mj772er_airfrance.zip
//questions? karel.vanhees@swiss-va.com
//Have fun!
[fltsim.0]
title=PSS Boeing 777-200LR Boeing Air France
sim=PSSB777LR-GE
model=
panel=
sound=
texture=
atc_id=F-GSPR
atc_flight_number=
atc_heavy=1
description=MelJet/PSS Boeing 777-200ER FS2004 merged with PSS 772LR packagenVersion 1.0nnVisual model by Melvin Rafinhttp://www.meljet.comn28683 367 B777-228(ER) GE90-94B 19/10/01 AIR FRANCE (ILFC) F-GSPR BF-HJntwo General Electric GE90-94B rated 432.8 kN.nWeight: - empty: 142.430 Kg.n- max. zero-fuel weight: 195.046 Kg.n- fuel: 171.160 liter.n- max. payload: 59.422 Kg.n-Max. take off weight: 297.560 Kg.n-Max. landing weight: 208.653 Kg.n-Range: 14.316 km.nFDE was redesigned according to reference material of an Air France B772ER equipped with GE90-94B engines.Please take note that you need the original .AIR file of the 200LR package and the sound+panel folder placed in the meljet 777 folder, otherwise you are not able to use this aircraft.
atc_parking_types=GATE,RAMP
atc_parking_codes=AFR
[General]
atc_type=BOEING
atc_model=B772
editable=1
performance=Engine Thrust: 94000lbs eachnPowerplants:GE90-94BnnThis Aircraft and the Flight Dynamic File are freeware and are not to be sold or transfered in any form for which a fee is charged.
[weight_and_balance]
// ACM V2.5
max_gross_weight =660832
empty_weight =313346
reference_datum_position = 0, 0, 0
empty_weight_CG_position = 0, 0, 0
empty_weight_pitch_MOI = 17631459
empty_weight_roll_MOI = 7533629
empty_weight_yaw_MOI = 18421453
empty_weight_coupled_MOI = 0
max_number_of_stations = 14
station_load.0 = 900, 96.95, 0, 4.12, Cockpit Crew
station_load.1 = 1080, 10, 0, 0, Cabin Crew
station_load.2 = 2880, 70, 0, 0, First Class
station_load.3 = 10440, 55, 0, 0, Business Class
station_load.4 = 14580, 15, 0, 0, Coach Y1
station_load.5 = 24300, -10, 0, 0, Coach Y2
station_load.6 = 0.0, 40, 0, 0, Containers P. 1 (FRT)
station_load.7 = 500.0, 10, 0, 0, Containers P. 2 (FRT/MAIL)
station_load.8 = 10535, -25, 0, 0, Containers P. 3 (BGGE)
station_load.9 = 10535, -65, 0, 0, Containers P. 4 (BGGE)
station_load.10 = 200, -70, 0, 0, Bulk Cargo P. 5 (BULK)
station_load.11 = 452, 20, 0, 0, Meals
station_load.12 = 139, 20, 0, 0, Potable Water
station_load.13 = 40, 20, 0, 0, Lav Service
[airplane_geometry]
wing_area = 4400
wing_span = 199.9
wing_root_chord = 21.65
wing_dihedral = 6
wing_incidence = 0.0
wing_twist = 0
oswald_efficiency_factor = 0.88667
wing_winglets_flag = 0
wing_sweep = 0
wing_pos_apex_lon = 5.35
wing_pos_apex_vert = -2.75
htail_area = 1089.954
htail_span = 70.04
htail_pos_lon = -80.80
htail_pos_vert = 5.78
htail_incidence = 0.0
htail_sweep = 40
vtail_area = 572.963
vtail_span = 30.31
vtail_sweep = 35
vtail_pos_lon = -78.76
vtail_pos_vert = 11.09
elevator_area = 137.0
aileron_area = 76.5
rudder_area = 232.0
elevator_up_limit = 30.0
elevator_down_limit = 30.0
aileron_up_limit = 30.0
aileron_down_limit = 15.0
rudder_limit = 25.0
elevator_trim_limit = 20.0
spoiler_limit = 60.0
aileron_to_spoileron_gain = 3
spoiler_handle_available = 1
min_ailerons_for_spoilerons = 10
min_flaps_for_spoilerons = 0
spoilerons_available = 1
[Reference Speeds]
flaps_up_stall_speed=138.0 //Knots True (KTAS)
full_flaps_stall_speed=122.0 //Knots True (KTAS)
cruise_speed=482 //Knots True (KTAS)
max_mach = 0.90
max_indicated_speed = 350 //Red line (KIAS)
[Flaps.0] //Inboard Krueger
type= 2
span-outboard= 0.100
extending-time= 15.000
system_type= 1
damaging-speed= 260.000
blowout-speed= 270.000
lift_scalar= 0.0
drag_scalar= 0.0000
pitch_scalar= 0.0
flaps-position.0= 0.000, 0.000
flaps-position.1= 30.000, 255.000
[Flaps.1] //Slat
type= 2
span-outboard= 0.800
system_type= 1
lift_scalar= 0.02100
drag_scalar= 0.300
pitch_scalar= 0.00
flaps-position.1= 15.500, 255.000
flaps-position.2= 15.500, 235.000
flaps-position.3= 15.500, 215.000
flaps-position.4= 15.500, 195.000
flaps-position.5= 30.000, 185.000
flaps-position.6= 30.000, 170.000
[Flaps.2] //Inboard Flap
type= 1
span-outboard= 0.200
extending-time= 25.000
system_type= 1
lift_scalar= 0.4950
drag_scalar= 0.250
pitch_scalar= 0.00
flaps-position.1= 0.1000, 255.000
flaps-position.2= 5.0000, 235.000
flaps-position.3= 15.000, 215.000
flaps-position.4= 20.000, 195.000
flaps-position.5= 25.000, 185.000
[Flaps.3] //Outboard Flap
type= 1
span-outboard= 0.600
system_type= 1
lift_scalar= 0.4950
drag_scalar= 0.300
pitch_scalar= 0.00
flaps-position.1= 0.10, 235.000
flaps-position.2= 5.000, 215.000
flaps-position.3= 15.000, 196.000
[flight_tuning]
cruise_lift_scalar=1.0
parasite_drag_scalar=1.0
induced_drag_scalar=1.0
elevator_effectiveness=2.0
aileron_effectiveness=1.0
rudder_effectiveness=1.0
pitch_stability=1.0
roll_stability=1.0
yaw_stability=1.0
elevator_trim_effectiveness=1.0
aileron_trim_effectiveness=1.0
rudder_trim_effectiveness=1.0
[fuel]
//Longitudinal (feet), Lateral (feet), Vertical (feet), Usable(gallons), Unusable (gallons)
fuel_type = 2
number_of_tank_selectors = 4
electric_pump = 1
Center1 = 3, 0, -4, 26100, 3 //--- New Value
LeftMain = 3, -35, 0, 9300, 3
RightMain = 3, 35, 0, 9300, 3
[autopilot]
autopilot_available=1
flight_director_available=1
default_vertical_speed=1800.0
autothrottle_available=1
autothrottle_arming_required= 1
autothrottle_max_rpm = 108.5
autothrottle_takeoff_ga= 1
pitch_takeoff_ga=8 ;
max_pitch=10.0
max_pitch_acceleration=0.88
max_pitch_velocity_lo_alt=0.7
max_pitch_velocity_hi_alt=0.4
max_pitch_velocity_lo_alt_breakpoint=11000.0
max_pitch_velocity_hi_alt_breakpoint=25000.0
max_bank=25.0
max_bank_acceleration=1.4
max_bank_velocity=2.8
max_throttle_rate=0.08
nav_proportional_control=11.00
nav_integrator_control=0.17
nav_derivative_control=0.00
nav_integrator_boundary=2.50
nav_derivative_boundary=0.00
gs_proportional_control=19.0
gs_integrator_control=0.530
gs_derivative_control=0.00
gs_integrator_boundary=0.70
gs_derivative_boundary=0.00
yaw_damper_gain = 1.0
[GeneralEngineData]
//f8d253538593ad248f0dbebb681db285
//0=Piston, 1=Jet, 2=None, 3=Helo-Turbine, 4=Rocket, 5=Turboprop
engine_type = 1
fuel_flow_scalar =0.950 // 0.415
min_throttle_limit = -0.51
engine.0 = 32.75, -32.03, -7.41,
engine.1 = 32.75, 32.03, -7.41,
[TurbineEngineData]
fuel_flow_gain=0.0010 //Gain on fuel flow
inlet_area=93.540195 //Square Feet, engine nacelle inlet area
rated_N2_rpm=29920 //RPM, second stage compressor rated value
static_thrust=103500 //Lbs, max rated static thrust at Sea Level-->correct setting //for merge file 777-200ER +10500lbs, 94000=103500
afterburner_available=0 //Afterburner available?
reverser_available=1 //Thrust reverser available?
[jet_engine]
thrust_scalar = 1.0
[Views]
eyepoint = 90.0, -2.65, 2.25
[contact_points]
static_pitch = 0.1
static_cg_height = 17.56
tailwheel_lock = 0
gear_system_type = 1
max_number_of_points = 17
//0 Class <0=none,1=wheel, 2=scrape, 3=float>
//1 Longitudinal Position (feet)
//2 Lateral Position (feet)
//3 Vertical Position (feet)
//4 Impact Damage Threshold (Feet Per Minute)
//5 Brake Map (0=None, 1=Left, 2=Right)
//6 Wheel Radius (feet)
//7 Steer Angle (degrees)
//8 Static Compression (feet) (0 if rigid)
//9 Max/Static Compression Ratio
//10 Damping Ratio (0=Undamped, 1=Critically Damped)
//11 Extension Time (seconds)
//12 Retraction Time (seconds)
//13 Sound Type
//14 Airspeed limit for retraction (KIAS)
//15 Airspeed that gear gets damage at (KIAS)
point.0=1, 87.42, 0.00, -17.50, 1181.1, 0, 3.500, 70.0, 1.0, 2.5, 0.7200, 15.0, 15.0, 0, 0.0, 0.0
point.1=1, -19.50, -12.00, -19.00, 1574.8, 1, 4.167, 20.0, 1.0, 2.5, 0.7500, 15.0, 15.0, 2, 0.0, 0.0
point.2=1, -19.50, 12.00, -19.00, 1574.8, 2, 4.167, 20.0, 1.0, 2.5, 0.7500, 15.0, 15.0, 3, 0.0, 0.0
point.3=2, -14.17, -47.33, 0.00, 787.4, 0, 0.000, 0.0, 0.00, 0.0, 0.0000, 0.0, 0.0, 5, 0.0, 0.0
point.4=2, -14.17, 47.33, 0.00, 787.4, 0, 0.000, 0.0, 0.00, 0.0, 0.0000, 0.0, 0.0, 6, 0.0, 0.0
point.5=2, -83.33, 0.00, 2.50, 787.4, 0, 0.000, 0.0, 0.00, 0.0, 0.0000, 0.0, 0.0, 9, 0.0, 0.0
point.6=2, 42.67, 0.00, -3.75, 787.4, 0, 0.000, 0.0, 0.00, 0.0, 0.0000, 0.0, 0.0, 4, 0.0, 0.0
point.7 = 2, -102, 36, 9, 787.4, 0, 0, 0, 0, 0, 0, 0, 0, 9, 0, 0
point.8 = 2, -38.4, 105, 12.5, 787.4, 0, 0, 0, 0, 0, 0, 0, 0, 6, 0, 0
point.9 = 2, -102, 0, 44.1266, 787.4, 0, 0, 0, 0, 0, 0, 0, 0, 9, 0, 0
point.10 = 2, -88.3844, 0, 0.0661, 787.4, 0, 0, 0, 0, 0, 0, 0, 0, 4, 0, 0
point.11 = 2, -57.091, 0, -6.708, 787.4, 0, 0, 0, 0, 0, 0, 0, 0, 4, 0, 0
point.12 = 2, -44.38, 0, -8.6234, 787.4, 0, 0, 0, 0, 0, 0, 0, 0, 4, 0, 0
point.13 = 2, -102.1003, 0, 3.9805, 787.4, 0, 0, 0, 0, 0, 0, 0, 0, 9, 0, 0
point.14 = 2, 50.4709, 0, 13.0267, 787.4, 0, 0, 0, 0, 0, 0, 0, 0, 4, 0, 0
point.15 = 2, 105.0852, 0, 0.4276, 787.4, 0, 0, 0, 0, 0, 0, 0, 0, 4, 0, 0
point.16 = 5, 0.0, 0.0, -10.0, 1600, 0.0, 0.0, 50.0, 0.0, 0.0, 1.00, 1.0, 1.0, 0, 0.0, 0.0
[electrical]
max_battery_voltage = 24
generator_alternator_voltage = 28
max_generator_alternator_amps = 60
engine_generator_map = 1,1
electric_always_available = 0
flap_motor = 0, 5, 17
gear_motor = 0, 5, 17
autopilot = 0, 5, 17
avionics_bus = 0, 5, 17
avionics = 1, 5, 17
pitot_heat = 0, 2, 17
additional_system = 0, 2, 17
marker_beacon = 1, 2, 17
gear_warning = 0, 2, 17
fuel_pump = 0, 5, 17
starter1 = 0, 20, 17
light_nav = 0, 5, 17
light_beacon = 0, 5, 17
light_landing = 0, 5, 17
light_taxi = 0, 5, 17
light_strobe = 0, 5, 17
light_panel = 0, 5, 17
[direction_indicators]
//1 Type: 0=None, 1=Vacuum Gyro, 2=Electric Gyro, 3=Electro-Mag Slaved Compass, 4=Slaved to another
//2 Indicator number of slaving indicator if Type = 4
direction_indicator.0=3,0
[pitot_static]
vertical_speed_time_constant =999 //Increasing this value will cause a more instantaneous reaction in the VSI
[exits]
number_of_exits = 1
exit_rate.0 = 0.1 ;Percent per second
[TailHook]
tailhook_length=1 ;(feet)
tailhook_position=-15.0, 0.0, -1.0 ;(feet) longitudinal, lateral, vertical positions from datum
cable_force_adjust=1.0
[folding_wings]
wing_fold_system_type=4 ;0=None
fold_rates=0.075,0.075 ;Percent per second
[LIGHTS]
//Types: 1=beacon, 2=strobe, 3=navigation, 4=cockpit, 5=landing
light.0 = 3,-102.25, 0.00, 6.25, fx_navwhih ,
light.1 = 2,-102.25, 0.00, 3.00, fx_strobeh ,
light.2 = 1, 39.00, 0.00, 10.50, fx_beaconh ,
light.3 = 1, 20.25, 0.00, -11.50, fx_beaconh ,
light.4 = 4, 93.50, 0.00, 5.50, fx_vclighth ,
[Radios]
// Radio Type = availiable, standby frequency, has glide slope
Audio.1=1
Com.1=1, 1
Com.2=1, 1
Nav.1=1, 1, 1
Nav.2=1, 1, 1
Adf.1=1,1
Adf.2=1,1
Transponder.1=1
Marker.1=1
[forcefeedback]
gear_bump_nose_magnitude = 3000
gear_bump_nose_direction = 18000
gear_bump_nose_duration = 250000
gear_bump_left_magnitude = 2700
gear_bump_left_direction = 35500
gear_bump_left_duration = 250000
gear_bump_right_magnitude = 2700
gear_bump_right_direction = 00500
gear_bump_right_duration = 250000
ground_bumps_magnitude1 = 1300
ground_bumps_angle1 = 08900
ground_bumps_intercept1 = 3.0
ground_bumps_slope1 = 0.20
ground_bumps_magnitude2 = 200
ground_bumps_angle2 = 09100
ground_bumps_intercept2 = 1.075
ground_bumps_slope2 = 0.035
crash_magnitude1 = 10000
crash_direction1 = 01000
crash_magnitude2 = 10000
crash_direction2 = 9000
crash_period2 = 75000
crash_duration2 = 2500000
[EFFECTS]
wake=fx_wake
water=fx_spray
dirt=fx_tchdrt
concrete=fx_sparks
touchdown=fx_tchdwn, 1
[keyboard_response]
elevator = 150, 200
aileron = 150, 200
rudder = 150, 200
[brakes]
toe_brakes_scale=0.671407
parking_brake=1
[gear_warning_system]
gear_warning_available = 0 //Normal
pct_throttle_limit = 0.1 //Percent throttle that activates warning
flap_limit_idle = 5.0 //Flap angle that activates warning at idle
flap_limit_power = 25.5 //Flap angle that activates warning at above idle
[brakes]
parking_brake = 1 //Parking brake available
toe_brakes_scale = 0.7 //Brake scalar
[hydraulic_system]
normal_pressure = 3000.0 //PSI
electric_pumps = 1 //no electric pumps
engine_map = 1,1,0,0 //pumps on Eng1,2
[stall_warning]
type=2
[attitude_indicators]
//Type: 0=None, 1=Vacuum Gyro, 2=Electric Gyro
attitude_indicator.0 = 2
attitude_indicator.1 = 1
[turn_indicators]
turn_indicator.0=1,0
[smokesystem]
smoke.0 = 5.9, -26.2, 77.2, fx_pss_fuel_jett
smoke.1 = 5.9, -26.2, -77.3, fx_pss_fuel_jett
SWISSER
Sun Sep 24, 2006 11:14 pm
Exactly the same stuff for the others guys!
the 777-200LR
[fltsim.0]
title=PSS Boeing 777-200LR Boeing Dreamliner
sim=PSSB777LR-GE
model=
panel=
sound=
texture=
ui_type=777-240LR
ui_variation=Boeing Dreamliners Sceme
atc_id=N6066Z
atc_airline=Boeing
atc_flight_number=6432
atc_heavy=1
description=MelJet Boeing 777-200LR for FS2002nVersion 2.0, Release 2 (July 18, 2003)nnVisual model and FDE by Melvin Rafinhttp://www.meljet.com
[General]
atc_type=BOEING
atc_model=B772
editable=0
performance=Flight Dynamic file Version 1.5 for FS2002nEngine Thrust: 110100lbs eachnPowerplant: GE90-110B1nnThis Aircraft and the Flight Dynamic File are freeware and are not to be sold or transfered in any form for which a fee is charged. Free distribution is allowed only after approval from MelJet.
// ACM V2.5
max_gross_weight = 766800
empty_weight = 320000
empty_weight_pitch_MOI = 17481382
empty_weight_roll_MOI = 7506555
empty_weight_yaw_MOI = 18309769
[airplane_geometry]
wing_area = 4604.801
wing_span = 212.58
wing_dihedral = 6
wing_twist = 0
wing_sweep = 0
htail_span = 70.04
htail_sweep = 40
vtail_span = 30.31
vtail_sweep = 35
aileron_area = 76.5
rudder_area = 232.0
rudder_limit = 25.0
[Reference Speeds]
cruise_speed=482.0 //Knots True (KTAS)
max_mach = 0.90
type= 2
system_type= 1
lift_scalar= 0.0
drag_scalar= 0.0000
pitch_scalar= 0.0
[Flaps.1] //Slat
type= 2
system_type= 1
drag_scalar= 0.300
pitch_scalar= 0.00
type= 1
system_type= 1
lift_scalar= 0.4950
drag_scalar= 0.250
pitch_scalar= 0.00
type= 1
system_type= 1
lift_scalar= 0.4950
drag_scalar= 0.300
pitch_scalar= 0.00
[flight_tuning]
cruise_lift_scalar = 1.0
parasite_drag_scalar = 1.0
induced_drag_scalar = 1.0
elevator_effectiveness = 2.1
aileron_effectiveness = 1.0
rudder_effectiveness = 1.0
pitch_stability = 1.0
roll_stability = 1.0
yaw_stability = 1.0
elevator_trim_effectiveness = 1.0
aileron_trim_effectiveness = 1.0
rudder_trim_effectiveness = 1.0
[fuel]
fuel_type = 2
electric_pump = 1
LeftAux = -10, -60, 3, 4370, 0
RightAux = -10, 60, 3, 4370, 0
[autopilot]
max_pitch=10.0
max_bank=25.0
[GeneralEngineData]
engine_type = 1
fuel_flow_scalar = 0.950
[TurbineEngineData]
static_thrust=110100 //Lbs, max rated static thrust at Sea Level
[jet_engine]
thrust_scalar=1.0
[Views]
[contact_points]
//13 Sound Type
static_pitch = 0
gear_system_type=0
[electrical]
avionics = 1, 5, 17
[exits]
number_of_exits = 2
exit_rate.1 = 0.1 ;Percent per second
[TailHook]
[folding_wings]
[LIGHTS]
[Radios]
Audio.1=1
Com.1=1, 1
Com.2=1, 1
Nav.1=1, 1, 1
Nav.2=1, 1, 1
Adf.1=1,1
Adf.2=1,1
Transponder.1=1
Marker.1=1
[forcefeedback]
[EFFECTS]
wake=fx_wake
water=fx_spray
dirt=fx_tchdrt
concrete=fx_sparks
[keyboard_response]
elevator = 150, 250
aileron = 150, 250
rudder = 150, 250
[brakes]
toe_brakes_scale = 1.0 //Brake scalar
[hydraulic_system]
[stall_warning]
type=2
[turn_indicators]
//Type: 0=None, 1=Electric Gyro, 2= Vacuum Gyro
[flight_tuning]
elevator_effectiveness=1.0
pitch_stability=1.0
roll_stability=1.0
yaw_stability=1.0
[smokesystem]
SWISSER
Sun Sep 24, 2006 11:17 pm
777-300ER
[fltsim.0]
title=PSS Boeing 777-300ER Boeing Air France
sim=PSSB773ER-GE
model=
panel=
sound=
texture=
ui_type="Boeing 777-328ER"
atc_id=F-GSQJ
atc_flight_number=773
atc_heavy=1
description=MelJet Boeing 777-300 Flight Dynamics Version 1.0.nVisit www.meljet.com for more information.
[General]
atc_type=BOEING
atc_model=B773
editable=0
performance=Flight Dynamic file Version 1.5 for FS2002nEngine Thrust: 115300lbs eachnPowerplant: GE90-115BnnThis Aircraft and the Flight Dynamic File are freeware and are not to be sold or transfered in any form for which a fee is charged. Free distribution is allowed only after approval from MelJet.
// ACM V2.5
max_gross_weight = 777000
empty_weight = 370000
empty_weight_pitch_MOI = 26443208
empty_weight_roll_MOI = 8710758
empty_weight_yaw_MOI = 24371969
station_load.0 = 360, 112.7, 0, 4.12, Cockpit Crew
station_load.1 = 1080, 0, 0, 0, Cabin Crew
station_load.2 = 3960, 85, 0, 0, First Class
station_load.3 = 12600, 40, 0, 0, Business Class
station_load.4 = 19440, 0, 0, 0, Coach Y1
station_load.5 = 19440, -20, 0, 0, Coach Y2
station_load.6 = 2316, 40, 0, 0, Containers P. 1
station_load.7 = 6952, 10, 0, 0, Containers P. 2
station_load.8 = 6952, -30, 0, 0, Containers P. 3
station_load.9 = 11027, -60, 0, 0, Containers P. 4
station_load.10 = 1325, -70, 0, 0, Bulk Cargo P. 5
station_load.11 = 474, 0, 0, 0, Meals
station_load.12 = 139, 0, 0, 0, Potable Water
station_load.13 = 20, 0, 0, 0, Lav Service
[airplane_geometry]
wing_span = 212.58
wing_dihedral = 3.90
wing_incidence = 1.0
wing_twist = -2
wing_sweep = 0
wing_pos_apex_lon = 5.40
wing_pos_apex_vert = -4.46
htail_span = 70.04
htail_pos_lon = -100.23
htail_sweep = 40
vtail_span = 33.23
vtail_sweep = 35
vtail_pos_lon = -94.60
vtail_pos_vert = 10.63
aileron_area = 76.5
rudder_area = 232.0
rudder_limit = 25.0
[Reference Speeds]
flaps_up_stall_speed=150.0 //Knots True (KTAS)
full_flaps_stall_speed=120.0 //Knots True (KTAS)
max_mach = 0.90
max_indicated_speed = 330 //Red line (KIAS)
type= 2
system_type= 1
damaging-speed= 270.000
blowout-speed= 275.000
lift_scalar= 0.0
drag_scalar= 0.0000
pitch_scalar= 0.0
flaps-position.1= 30.000, 265.000
[Flaps.1] //Slat
type= 2
system_type= 1
drag_scalar= 0.300
pitch_scalar= 0.00
flaps-position.1= 15.500, 265.000
flaps-position.2= 15.500, 245.000
flaps-position.3= 15.500, 230.000
flaps-position.4= 15.500, 225.000
flaps-position.5= 30.000, 200.000
flaps-position.6= 30.000, 180.000
type= 1
system_type= 1
lift_scalar= 0.4750
drag_scalar= 0.250
pitch_scalar= 0.00
flaps-position.1= 0.1000, 265.000
flaps-position.2= 5.000, 245.000
flaps-position.3= 15.000, 230.000
flaps-position.4= 20.000, 225.000
flaps-position.5= 25.000, 200.000
type= 1
system_type= 1
lift_scalar= 0.4750
drag_scalar= 0.300
pitch_scalar= 0.00
flaps-position.1= 0.10, 265.000
[flight_tuning]
elevator_effectiveness=2.1
pitch_stability=1.0
roll_stability=1.0
yaw_stability=1.0
[fuel]
fuel_type = 2
electric_pump = 1
Center1 = 5, 0, -4, 20550, 3
LeftMain = 5, -35, 0, 9300, 3
RightMain = 5, 35, 0, 9300, 3
[autopilot]
max_pitch=10.0
max_pitch_acceleration=1.0
max_bank=25.0
[GeneralEngineData]
//618ef224d12e7dad929ac74c941b9b34
engine_type = 1
fuel_flow_scalar = 1.0401
min_throttle_limit = -0.25
[TurbineEngineData]
inlet_area=93.840195 //Square Feet, engine nacelle inlet area
rated_N2_rpm=11292 //RPM, second stage compressor rated value
static_thrust=115540 //GE90-115B Lbs, max rated static thrust at Sea Level
[jet_engine]
thrust_scalar = 1.0
[Views]
eyepoint = 108.0, -2.65, 2.25
[contact_points]
//13 Sound Type
point.0=1, 105.42, 0.00, -17.50, 1181.1, 0, 3.500, 70.0, 1.0, 2.5, 0.7200, 15.0, 15.0, 0, 0.0, 0.0
static_pitch = 0
gear_system_type=0
[electrical]
avionics = 1, 5, 17
[exits]
number_of_exits = 2
[TailHook]
[folding_wings]
[LIGHTS]
[Radios]
Audio.1=1
Com.1=1, 1
Com.2=1, 1
Nav.1=1, 1, 1
Nav.2=1, 1, 1
Adf.1=1,1
Adf.2=1,1
Transponder.1=1
Marker.1=1
[forcefeedback]
[EFFECTS]
wake=fx_wake
water=fx_spray
dirt=fx_tchdrt
concrete=fx_sparks
[keyboard_response]
elevator = 150, 250
aileron = 150, 250
rudder = 150, 250
[brakes]
[hydraulic_system]
[turn_indicators]
[stall_warning]
type=2
B737200
Mon Sep 25, 2006 4:20 am
Thanks a million SWISSER. I'll give it a try tomorrow since I'm just back from the Malta International Airshow and I have to clear out all my camera flash cards and I'm totally exhausted.
Anyway once again thanks, I really appreciate it.
SWISSER
Mon Sep 25, 2006 5:34 am
Have fun!
I' am flying to LHR 2moro on a 3 day block, so you are on your own then!
after that I' am off straight away to FRA and then 1 day off, I hope I will have time then to help you out if the need comes!
I need a laptop with some internet acces...
B737200
Tue Sep 26, 2006 2:01 am
I managed to merge a meljet -200er with the panel.
Once again thanks a lot.
