fastenseatbelt
A.netters In Edinburgh
Sat Dec 03, 2005 1:41 am
Hey guys!
Was wondering how many A.netters are in Edinburgh? Would be kewl to know who there is out there.
I am currently doing my post-grad here in Edinburgh.
Hope to hear from you Burgh peeeps!
Nicki
Above the clouds...it must be beatutiful there
dogfighter2111
RE: A.netters In Edinburgh
Sat Dec 03, 2005 2:04 am
Hey,
I am Livingston  Smile
Go to EDI spotting very little but, can see anything arriving/departing from my house so...
Mike
fastenseatbelt
Sat Dec 03, 2005 2:21 am
Hey!
lucky you....i can only see the planes coming in over pentland from my kitchen window...harharhar...
I have never been spotting at EDI...as much as i love planes...3.50 for the bus is a bit uch just to get to the airport...also, no one to go with. going alone is a bit weird...lol
Have you seen the Continental babies yet? I really wanna see them in EDI...would be a reason to go to the airport...lol
Nicki
dogfighter2111
Sat Dec 03, 2005 2:41 am
Quoting Fastenseatbelt (Reply 2):
Aww, if only i could drive then  Smile
Yes, i saw the B762 arrive this morning, although it appeared a bit larger. It amy have just been the angle  Smile
Mike
David L
Sat Dec 03, 2005 4:51 am
I'm west of the centre - Slateford, if you know it, near Tynecastle. Moved here about 11 years ago from Glasgow - a Weegie in Embra! It's stupid but I've only been out to the airport a couple of times to collect someone and I've got plenty of time on my hands at the moment. With a pair of binoculars I get a fairly good view of aircraft departing 24 and arriving 06 from my sitting-room.
dogfighter2111
Sat Dec 03, 2005 5:12 am
Quoting David L (Reply 4):
Ahh, 06 arrivals are morning and evening usually and 24 are departures in the afternoon normally.
As i said, i saw the CO B767 arriving today. It was 06 approach as most mornings, and it is a lovely view.
Mike
David L
Sat Dec 03, 2005 5:26 am
Quoting Dogfighter2111 (Reply 5):
Well... there's only one runway so doesn't the wind have more of a say than scheduling? If 06 is in use I see arrivals, if 24 is in use I see departures.  Smile
ScottishLaddie
Sat Dec 03, 2005 6:05 am
Mike
Whaaat! It goes by wind direction not time of day!  Confused
I'm from Edinburgh btw....  Wink
dogfighter2111
Sat Dec 03, 2005 6:10 am
Quoting ScottishLaddie (Reply 7):
I amn't stupid, i do know how RWY direction works!!!
I was trying to say what the usual directions are. And i know how correct i am with the directions i mentioned. After all, i do see aircraft landing and departing in EDI every day.  Smile
Mike
GLAGAZ
Sat Dec 03, 2005 7:02 am
It will never operate like that on a regualr basis. Yes there will be a predominant wind direction most of the time, but it won't change as you say 3 times a day like clockwork.
If you had just said the runway that is mostly in use is runway 06 then it would have been a lot simpler than stating that the weather follows that strange pattern on a regular basis.
Gaz
Neutrality means that u don't really care cos the struggle goes on even when ur not there, blind and unaware
dogfighter2111
Sat Dec 03, 2005 7:51 am
Quoting GLAGAZ (Reply 9):
Well, i usually see RWY 06 in use in the morning and evening. When i leave in the morning and when i get back home in the evening.
Whenever my family go on holiday, i look at the arrival and departure time. If it is in the morning, i look out and i see them leave 99% of the time. I see them arrive if they land late evening and i am 99% correct.
I do sit and watch the activity sometimes, and i very rarely see departures at 06:00 on RWY 24. Although i did depart at 0700 when i flew to BFS, but we landed back on RWY 24 and that was in the afternoon.
Mike
ScottishLaddie
Sat Dec 03, 2005 8:03 am
Quoting Dogfighter2111 (Reply 10):
Mike
I'm confused.
 Confused
David L
Sat Dec 03, 2005 8:12 am
It may be that when the wind is insignificant they'll vary the runway in use for noise abatement.
During the day 24 departures are more obvious to me because of the angle I see them at as they're climbing - arrivals are more head-on so they have a smaller cross-section. At night 06 arrivals are more obvious because I can see the landing lights.
I'm going to study this.  Smile
dogfighter2111
Sat Dec 03, 2005 8:17 am
Quoting ScottishLaddie (Reply 11):
I'm confused.
About what?
It is pretty simple what i was trying to say. In the first place, i said that USUALLY RWY 06 was used in the Morning and Evening, and 24 in teh afternoon. I have seen this process for years.
Picking it up wrong. I was only trying to state an observation.
Mike
David L
Sat Dec 03, 2005 8:27 am
Nor was there anything wrong with what I said - it's what I can see.  Smile
ScottishLaddie
Sat Dec 03, 2005 8:28 am
Quoting Dogfighter2111 (Reply 13):
About what?
By saying that you are implying that it goes by time of day, if the wind direction is such that 24 needs to be in use in the morning and evening then so be it.
Having worked in the airport all summer at all sorts of times, the time of day has nothing to do with it, 24 is used more often than 06 generally I'd say. But that's obviously down to wind direction, and they aren't going to change the runway direction in the afternoon if the wind direction hasn't changed,
dogfighter2111
Sat Dec 03, 2005 8:42 am
Quoting ScottishLaddie (Reply 15):
Again, i say USUALLY
I watch the aircraft arrive and depart everyday. I USUALLY see arrivals on RWY 06 in the morning and evening, and RWY 24 i USUALLY see in use in the afternoon.
I AM NOT IMPLYING THAT IT GOES BY TIME OF DAY!!!
I AM IMPLYING THAT USUALLY THE TIMES ARE SIMILAR EVERYDAY.
Mike
ScottishLaddie
Sat Dec 03, 2005 9:00 am
But that doesn't usually happen. It's usually 24 ops full stop. 06 obviously isn't used as often due to the direction of the wind which leads to 24 ops more often.
dogfighter2111
Sat Dec 03, 2005 9:27 am
Quoting ScottishLaddie (Reply 17):
That's funny how nearly every mornings and evenings i see arrivals on 06 and nearly every afternoon i see departures from 24.
I do live directly under the flight path, i do know which way the airport is and i do know what i am saying is correct. It is probably you not understanding it properley.
Mike
ScottishLaddie
Sat Dec 03, 2005 9:37 am
Quoting Dogfighter2111 (Reply 18):
So in other words you are saying that nearly everyday the wind changes direction in the afternoon, which it doesn't. When I start shifts at 5/6am 24 is in use more often that 06 is, but as I've already said that is simply down to the fact that the prevailing winds dicate that 24 is used more often.
dogfighter2111
Sat Dec 03, 2005 9:51 am
That is true, but i am talking about 7:30am and 7pm onwards when i usually see RWY 06 in use.
Mike
GLAGAZ
Sat Dec 03, 2005 7:26 pm
Quoting Dogfighter2111 (Reply 20):
Mike
*USUALLY  Wink lol good thread.
Gaz
dogfighter2111
Sat Dec 03, 2005 7:58 pm
Quoting GLAGAZ (Reply 21):
lol, yer i'm having a lot of arguing  Wink
What i am saying is proably not understood by the brain of others.
Mike
David L
Sat Dec 03, 2005 8:21 pm
11:20, 06 in use. Let's see how the day progresses.  Smile
ScottishLaddie
Sun Dec 04, 2005 12:41 am
Quite funny actually.  Wink
David L
Sun Dec 04, 2005 2:03 am
Oops... forgot to check!
nighthawk
Mon Dec 05, 2005 12:31 am
i used to live in slateford in appin terrace. moved back to SW Scotland 2 years ago. Im in edinburgh fairly often for a spotting trip.
David L
Mon Dec 05, 2005 2:08 am
Quoting Nighthawk (Reply 26):
I'm right across the railway line in Hermand Terrace!
