qxq400
Lap Tops That Support Fs2k4
Mon Dec 12, 2005 7:12 am
I know this topic has been discussed before. I however can not find the tread.
I am looking for a lap top that can support fs2k4? Anyone know of any?
Welcome baby Madison Renee
airlinelover
RE: Lap Tops That Support Fs2k4
Mon Dec 12, 2005 9:24 am
Best bet is to get one geared towards maximum performance.. Dell has a few that would probably work well, if you don't mind spending a crapload of money..
Make sure the video RAM is dedicated, the HDD is 7200 RPM, and you have a nice gig of RAM or more..
Additionally, it would be good to have (of course) a higher end CPU..
Chris
Lets do some sexy math. We add you, subtract your clothes, divide your legs and multiply
airlinelover
Mon Dec 12, 2005 9:29 am
Sorry, should add this
You'll want to do what you can to make sure you can get good airflow around the unit. Heat is a major problem with laptops and a very large cause of their failure.
Chris
Go3Team
Mon Dec 12, 2005 10:51 am
Steer away from these processors:
Duron
Centrino
Celeron
Best bet is the P4 with HT. Be prepared to spend some $$$.
Yay Pudding!
deltairlines
Mon Dec 12, 2005 12:26 pm
My ThinkPad R51 runs FS04 fine.
Jeff
Fly2HMO
Mon Dec 12, 2005 12:47 pm
Anything with a P4HT with +3ghz, at least 784 in ram and 128mb dedicated video card (not on board) should be enough.
jamotcx
Mon Dec 12, 2005 5:57 pm
Quoting Go3Team (Reply 3):
Duron
Centrino
Celeron
i can understand keeping clear of the Duron and Celeron, but I would opt for the Centrino over the P4.
Also the HDD speed wont make much difference to your flying, just the speed it takes to load FS. If you have enough RAM it will just dump all the files needed there so will avoid disk swapping.
I'm just about to change my laptop and I'm looking at a Centrino 740/750, 128mb+ dedicated graphics (geforce radion etc), 1GB RAM.
Jamo
N864DA
Tue Dec 13, 2005 2:24 am
Duron
Centrino
Celeron
The Centrino performs as well as a P4 chip, only it is optomized for laptops and runs a lot cooler (not to mention better battery life). I have the 1.6GHz Centrino processor on my Dell Inspiron 6000, which performs like a 2.4GHz P4. FS2K4 runs great with 512MB RAM and 128MB dedicated ATI graphics card. You are going to need a lot of memory. Most of all, you don't need to spend a fortune as you can probably find an Inspiron 6000 for around $1500 with 1GB of RAM memory. Just be sure to get one with the dedicated card as they are a bit rare on that product line.
N864DA
MarBergi
Tue Dec 13, 2005 7:46 am
Quoting N864DA (Reply 7):
Agreed, I have similiar but with 1GB RAM and it runs pretty smooth except in really built up airports (LHR, CDG etc.) even with ultimate traffic, fspassengers and other addons included.
RichardPrice
Tue Dec 13, 2005 8:55 am
I would recommend either a PentiumM based system (the CPU in the Centrino laptops - Centrino is a marketing name for a bunch of stuff, its not a CPU) or an AMD Turion processor which is the mobile version of the Athlon64, which is a very capable chip.
Lots of ram, 1GB minimum.
A fast harddisk - people forget this, but Windows *will* be swapping to disk and loading textures.
United737522
Tue Dec 13, 2005 10:22 am
I use a Sony Vaio FS660
Intel Centrino 1.73 Ghz
1GB RAM
$1600 (Making interest free $120/mo payments. Should be payed off in 5 more months.)
'Michael Mooronism' ~Jetjack74
vinniewinnie
Thu Dec 29, 2005 8:05 am
I use a nearly 3 year old Dell 8500!
Spec:
-P4M 2.4 Ghz
-512 Ram
-64 Dedicated graphics cards
-60 gig 4200 Rpm hard drive
Result:
It works perfectly well under most circumstances. But when U use either add-on detailed sceneries, AI traffic or Payware plane, it struggles a lot, heats up very quickly, and frame rate goes down! So be warned!
Anyway it's now time to replace mine! Looking for a top-notch Dell 9300 laptop for about 2500 Euros! Should do the trick I think!  Smile
Gerry
Thu Dec 29, 2005 11:03 am
I use an ACER Ferrari 3400 with the Athlon 64 chip, 512Mb and 128Mb Video dedicated. Runs fs9 with PMDG 737NG and Level D 767 like a deam but does get very hot running Flightsim over extended periods of time.
