Pe@rson
FS2004: Problems With The Keys
Wed Jan 04, 2006 6:50 am
I installed FS2004 today. It loaded up all fine and dandy, but very few of the keys seem to work (I was using the same as for FS2002). I don't have a joystick enabled, as I do it by keys. Any ideas? Thanks.
ac21365
RE: FS2004: Problems With The Keys
Wed Jan 04, 2006 7:16 am
The keys for FS9 are nearly identical to FS5, I doubt they've changed much between then and now...
Mabye It's just me?
Pe@rson
Wed Jan 04, 2006 7:21 am
So what could the problem be?
ac21365
Wed Jan 04, 2006 7:44 am
If you want to change the key assignments, just go to options and find the controls page, and change it!
-Aaron
Pe@rson
Wed Jan 04, 2006 7:31 pm
Sorry, I wasn't clear. When I use the keys for FS2004, nothing happens, except when I press 'L' for lights and two particular views. The box for the joystick isn't ticked, so it can't be that. I don't know what it could be. Any suggestions? Thanks a bunch.
Gofly
Wed Jan 04, 2006 7:37 pm
I'm not entirely sure what your problem is Pe@rson. Sounds like you don't have any key assignments for some reason or other.
Try going to: Start/All Programs/Microsoft Games/FS2004/TroubleShooting/Reset Defaults
You will lose any settings you have, so be sure to make a note of them. I'm not sure if that will work, but it is worth a try.  Smile
Let us know if you have any luck!
-Gofly  Smile
Living the high life on my ex-Airliners.net Moderator pension...
Pe@rson
Wed Jan 04, 2006 8:01 pm
It worked! Woohoo. Thanks a lot man, you're a star.  Big grin
