jetmatt777
Crew
Help With RWY 12
Tue Jan 17, 2006 7:09 am
Hey,
I'm aving trouble with RWY 12. When I start the program up this comes up.
The application failed to initialize properly(0xc0000135). press OK to terminate the program.
What did I do wrong?
Thanx
Matt
Lighten up while you still can, don't even try to understand, just find a place to make your stand and take it easy
SWISSER
RE: Help With RWY 12
Tue Jan 17, 2006 12:21 pm
I don't know that program Matt,
what is it?
What time is top of descent?
David L
Wed Jan 18, 2006 2:48 am
Sounds like a problem I had a while back. You might need to reinstall .NET Framework.
jetmatt777
Crew
Wed Jan 18, 2006 6:56 am
Quoting SWISSER (Reply 1):
what is it?
Its a program where you can place objects where you want, like jetways,cars, static planes, people, etc.
Quoting David L (Reply 2):
What's that?
Thanx,
Matt
David L
Wed Jan 18, 2006 7:31 am
Quoting Jetmatt777 (Reply 3):
What's that?
Ah, you had to ask! Well, the short answer is that I'm not altogether sure. I belive it's a support framework which either allows or improves the running of .NET stuff - a "real" programmer would need to explain it. I was first aware of it when there was a Windows Update for it.
This might help:
http://www.craxtion.com/forums/viewt...d=7e288ecf6fcc736db894f165f332fe69
jetmatt777
Crew
Wed Jan 18, 2006 7:37 am
Thanks I am downloading it now.
Matt
David L
Wed Jan 18, 2006 7:52 am
Quoting Jetmatt777 (Reply 5):
Good luck - I'm not guaranteeing anything!
jetmatt777
Crew
Wed Jan 18, 2006 1:19 pm
Quoting David L (Reply 6):
When I looked at your link the person had the same message as me but, after he downloaded it and installed it he said it worked fine.
I haven't installed it just yet.
Thanx for the reply
jetmatt777
Crew
Thu Jan 19, 2006 11:02 am
It worked! Thank- You David
matt
David L
Thu Jan 19, 2006 7:10 pm
Phew, I was getting ready to buy a false passport and head for Mexico!
jetmatt777
Crew
Mon Jan 23, 2006 3:02 am
Quoting David L (Reply 9):
You might have to. Next problem: When I made a little test scenery at SEA When I pushed "generate scenery" It said " Failed to write a BGL file" Now what do I do?
Thanx,
-matt
David L
Fri Jan 27, 2006 3:44 am
Quoting Jetmatt777 (Reply 10):
Ah, now that's never happened to me before - sorry!
jetmatt777
Crew
Fri Jan 27, 2006 7:13 am
Quoting David L (Reply 11):
Okay, Thank - you anyways!
Matt
