greaser
Possible To Run FS On VirtualPC?
Wed Feb 15, 2006 9:21 am
I have a Mac, used to have a PC, and just wondered whether, if i have VirtualPC/Windows, which is an emulator, could it effectively and smoothly run FS9/10??? it's an imac, so its modest on power, but could it?
Thanks.
Now you're really flying
dogfighter2111
RE: Possible To Run FS On VirtualPC?
Wed Feb 15, 2006 9:24 am
Yes it is, you just have to make sure that the joystick is picked up via virtual PC.
Mike
JamieD
Wed Feb 15, 2006 9:56 am
Quoting Greaser (Thread starter):
Granted I've never used VirtualPC on a Mac, but as Flight Simulator is a power-hungry application as it is, I would hazard a guess that performance within an emulator would be terrible, especially considering the fact that you're low on power as it is. Although if you're willing to give it a try, let us know how it goes.  Smile
[Edited 2006-02-15 01:58:03]
malaysia
Wed Feb 15, 2006 11:23 am
It would be a tad slow?
There Are Those Who Believe That There May Yet Be Other Airlines Who Even Now Fight To Survive Beyond The Heavens
greaser
Wed Feb 15, 2006 1:37 pm
Quoting JamieD (Reply 2):
Haha well I don't know, it would be nice if someone else here knew what the outcome would be, coz i wouldnt want to buy FS for nothing, if you know what I mean. People I've talked to say just get X-plane 8, and i did, but man, its like driving a german car. Once you've tried that, you never want to drive anything else...the xplane just isn't up to par in terms of graphics, model handling, and realism. I still have my wireless joystick, but i dont know whether im desperate enough to buy FS just to see what happens.....btw is FS10 gonna be for mac as well  Smile? thanks for the replies!
JohnKrist
Crew
Wed Feb 15, 2006 6:11 pm
Quoting Greaser (Reply 4):
btw is FS10 gonna be for mac as well ?
FSX will be for both Windows and OSX, but it will demand more power than an iMac can deliver. Don't know if it will be 2 separate editions or one that can run on both. I hope for 2 separate as there is a lot of junk code when you adapt one product to run on 2 platforms, and it will eat system resources.
Also, my guess is that it might only run on Mac with Intel processors.
Airliners.net Crew-Head Support
5D Mark III, 7D, 17-40 F4 L, 70-200 F2.8 L IS, EF 1.4x II, EF 2x III, SPEEDLITE 600EX-RT
RichardPrice
Wed Feb 15, 2006 6:36 pm
Quoting JohnKrist (Reply 5):
THe 'junk code' is easily disposed of at compile time, its a simple matter of using #ifdef WINDOWS of #ifdef OSX. Conditional preparser code blocks like this wont even make it to compile stage, it gets removed from the actual code if the correct thing isnt defined.
And the hard part of porting from Windows to OSX is the 'Windows to OSX' part, not the 'Intel to PPC' part, although since the Endians are different on the two processors, its not as trivial as it could be, but if you wrote the code with this in mind, a simple recompile will solve all these issues.
Chances are, the Xbox360 may have a port underway or planned, and the Xenon processor in the 360 is 95% the same as a PPC in a Mac, so do a port for one of the two machines and you are looking at a lower cost to do it for the other, increasing the market potential.
Maintaining two seperate products is not cost effective.
chksix
Fri Feb 17, 2006 1:03 am
VPC on my iMac emulates an old first gen Pentium. I guess you'll be watching a PowerPoint presentation if you manage to get MSFS to run at all.  Smile
The conveyor belt plane will fly
derekone
Mon Feb 20, 2006 10:41 am
get x-plane for mac osx it has way better graphics and is recognice by the FAA
you could download the trial version
http://www.x-plane.com/
I DONT KNOW WHAT CAN I SAY?????????
nighthawk
Mon Feb 20, 2006 6:05 pm
Quoting RichardPrice (Reply 6):
I think what JohnKrist was meaning was a single CD edition that would work under Vista or MacOSX, thereby having code libraries for both built into it. WHat you have described is still 2 seperate editions, based off a single code base.
I presume you are aware that Macs now use Intel based chips...? As FSX is not due to ship until the end of the year, it can be assumed it will target the current generation of Macs rather than the discontinued line....
EDIT: Better add my 2 cents to the original topic:
Ive never tried running games through an emulator like VirtualPC, but I would strongly advise against it. Flight Sim struggles on anything but the highest spec pcs, most users need to shut down as many windows processes as possible to get it running smoothly.
Through an emulator you are going to have 2 operating systems and the emulator all taking up memory and processor time, also remember that you are emulating a machine through software, so its going to be slower than running natively.
So unless you have a machine with specs double the recommended, your going to be stuck with a slideshow...
[Edited 2006-02-20 10:10:24]
RichardPrice
Mon Feb 20, 2006 10:35 pm
Quoting Nighthawk (Reply 9):
Yes, but its going to be a looooooooong time until the installed userbase switches over to being predominently intel based. Certainly any releases this year will *have* to be targetted to the PPC version of the Mac, since a release for just the Intel version would be targetting a userbase that is simply too small currently.
And as I said before, the hardest part is the Windows -> OSX part with the library calls and such forth. The actually processors targetted is pretty easy to overcome.
Take a look at whats on the CDs, 99% of it is data that both versions can use. The actual binaries run are going to come in as a very small percentage of whats actually shipped.
