goinv
Tips For Descent / Landing In Pmdg B737-800
Sun Feb 26, 2006 6:46 pm
Hi,
Just upgraded from PMDG B737-700 to B737-800. I find that the 800 series is difficult to slow down. As soon as I get descent clearance I pull the throttles back to idle and usually do a "Level Change" to get the steepest descent at the desired speed.
However, I find that I am now arriving at the airport way too high and having to use speed brakes. I know spped brakes are used in real life - but not on every flight.
How do other PMDG B737-800 series pilots descend?
Your hints / tips are greatly appreciated.
Be who you are, The world was made to measure for your smile. So Smile.
woady
RE: Tips For Descent / Landing In Pmdg B737-800
Sun Feb 26, 2006 7:06 pm
I've got that problem too. Will be interested in any replies  Smile
Woady
A300-600R, 737-300, 737-800, 757-200, 767-200/300/ER, ERJ145, ATR72
gunsontheroof
Sun Feb 26, 2006 7:08 pm
I've got the same problem...I usually just ask for a lower cruising altitude and start decending a ways before the T/D. The hot approaches were fun for awhile though...
Qantas744er
Sun Feb 26, 2006 8:46 pm
Hey, I fly the PMDG 747-400, and often the the same problem happens to me because VNAV makes a very tight descent so what you need to do is press on the Hold button in the FMC and put the name of one of the Waypoints about 25Nm to 30Nm away from your destination. Then you can keep on descending with speedbrakes and dont need to worry of coming in to fast and too high so with the holding pattern you have as much time as you want to reach your desired speed and altitude then just press exit hold on the hold page and your plane will return onto the desired course.
If you need any other help just email me  Smile
Cheers Leo
You live and you die, by the FMA
goinv
Sun Feb 26, 2006 9:02 pm
Quoting Qantas744ER (Reply 3):
Good idea about the hold - but try telling this to the MSFS ATC  Smile
Qantas744er
Mon Feb 27, 2006 4:40 am
Quoting Goinv (Reply 4):
LOL!  Smile I dont even talk to those idiots anymore Big grin
I fly on VATSIM and its just great  Smile
Cheers Leo
goinv
Mon Feb 27, 2006 6:19 am
Just done another flight. Before descent I was cruising at M.078 which equated to 245knots IAS.
This time, when MSFS told be to descend, I maintained the IAS (245 Knots) and used the LVL CHG to get the steepest descent for the speed. I managed to get to the desired level for the ILS at the destination airport some 7 miles before intercepting the ILS. There was a pretty strong headwind so I don't know if this helped.
Normally I would maintain Mach Number (rather than IAS) until the Indicated Airspeed reached 300Knots, then hold 300 Knots until 10000 feet, then hold 250 knots until the ILS.
I'll see what happens on subsequent flights.
CDreier
Tue Feb 28, 2006 12:18 am
Just a thought. Holding 250k to the ILS is way too fast. You should be slowed to perhaps 180 intercepting the localizer, and then down to 160-165 upon interception of the glideslope. Then you reduce as you proceed down the slope to your target landing speed, usually somewhere in the 140-150k range. Atleast that's how it's done in real life, and it works like a charm on my PMDG 737-800.  Smile
Gerry
Tue Feb 28, 2006 9:17 pm
Yes, the PMDG series does require a lot of drag in the descent and sometimes not even long deployment of the speed brakes may be enough. Just start the descent using say 1800 fpm on the VS some 10 - 15 Nm before the T/D point. 250 kts is way too fast to intercept an ILS. By the way the LDS 767 does not suffer from this being well behaved in the descent at all times with no speed brakes necessary on the way down.
Mir
Tue Feb 28, 2006 11:03 pm
I use VNAV for the descents, and it works pretty well for me. Sometimes I'll need to use speedbrakes if there's a tailwind, but usually not.
-Mir
sevenheavy
Fri Mar 03, 2006 5:35 pm
It is also worth reducing airspeed a little before commencing descent. At cruise try slowing to around M0.72 or so before descending. I always control my descent myself rather than let the VNAV take care of it. The generally accepted rule is 3 miles for every thousand feet of altitude.
For example from FL330 you should be in a position to commence descent at 99 miles out.
This is a fair representation of real world handling - the B737NG is notoriously slippery and requires carefull descent planning.
So long 701, it was nice knowing you.
David L
Fri Mar 03, 2006 7:52 pm
Quoting Gerry (Reply 8):
Are you sure it's PMDG's fault and not the FS ATC? I've been issued late descent in various aircraft.
goinv
Sat Mar 04, 2006 4:20 pm
Quoting Goinv (Reply 6):
Just to clarify my orginal post, to be more accurate it should have read
"then hold 250 knots until the ILS intercept altitude" - hopefully this will be a few miles before you intercept the ILS and then I begin a steady decrease in speed until I intercept the ILS (as many pointed out - about 180knts).
Sorry for be misleading - well done to those who spotted it.
Just thought I was driving for WN that's all.  biggrin
