KPDX
Problem With FS9 Aircraft
Mon May 01, 2006 10:56 pm
Hey guys, I have been having a problem with my FS aircraft recently. Whenever I start to takeoff in a plane the rudder always kicks in full, and turns me to a hard right so its hard to keep the plane on the runway, I kept trying things with autorudder on, and off.
Help would be appreciated!
KPDX  Smile
View my aviation videos on Youtube by searching for zildjiandrummr12
ZSOFN
RE: Problem With FS9 Aircraft
Tue May 02, 2006 12:22 am
Might as well start with the obvious; joystick properly calibrated?
Amy
Tue May 02, 2006 12:26 am
Sounds like a joystick fault to me. I'd try opening it up (carefully!) and checking it's clean, re-installing the drivers or something like that.
A340-300 - slow, but awesome!
jamesbuk
Tue May 02, 2006 12:47 am
How bought in the cockpit hitting the Yaw-Damper button, Always works for me BTW thats the Y/D button in freeware panels.
Rgds --James--
You cant have your cake and eat it... What the hells the point in having it then!!!
freedomtofly
Tue May 02, 2006 10:31 am
Quoting Jamesbuk (Reply 3):
Just a quick question, what exactly does that Y/D switch do when turned on. Also should I have it on all the time along with pitot heat?
Aaron
You are now free to move about the world.
KPDX
Tue May 02, 2006 11:56 am
Fixed the problem, thanks guys!  Smile
KPDX  Smile
jamesbuk
Wed May 03, 2006 4:43 am
Quoting Freedomtofly (Reply 4):
Freedomtofly
What it does is it effectively cancels out the signal from the yaw movement on your joystick/footpedals or whatever you use to control the rudder so i mainly use it on no-wind take offs as no adjustment is ever needed.
Its fairly useful.
Rgds --James--
