Btriple7
What's The Size Of Your FlightSim Files?
Sat May 06, 2006 12:27 pm
There was once a thread that talked about the symtoms of FlightSim addict. One was having a main Flight Simulator folder that took up half the harddrive.
Okay, right-click on the "Start" menu and go up to "Explore." Here you should get a list of all your computer's files. Find your "Microsoft Games" folder (it should be under program files):
C:/Program Files/Microsoft Games (Just replace the forward slashes with back slashes)
Find the folder that says "Flight Simulator." Right-click on it and go down to "Properties." A window should pop up. Go to the "General" tab. Look at the size of your FlightSim files. If your files exceed 7Mb, then you can definatly be classified as a true Flight Simulator addict.
Anyway, post your file size, file size on disk, and number folders within.
Here is what my FS files look like:
Size: 4.06 GB (4,369,122,620 bytes)
Size on disk: 4.14 GB (4,448,579,584 bytes)
Contains: 41,407 Files, 588 Folders
As you can tell, I don't have to much added on to my default FlightSim.
Anyway, how about you? Post your FlightSim file sizes.
Btriple7
[Edited 2006-05-06 05:29:27]
Just...fly.
jetmatt777
Crew
RE: What's The Size Of Your FlightSim Files?
Sat May 06, 2006 12:52 pm
Mine is 3.51GB
43,465 files
694 folders
-Matt  Smile
Lighten up while you still can, don't even try to understand, just find a place to make your stand and take it easy
LTU932
Sat May 06, 2006 1:20 pm
After re-installing FS after my computer change, I cleaned up and didn't install stuff I didn't need. So, after my FS folder had over 40 GB of stuff, this is how it looks:
Size: 24.2 GB (26,067,836,497 bytes)
Size on disk: 24.4 GB (26,277,830,656 bytes)
Contains: 92,064 Files, 3,481 Folders
elcableguy77
Sat May 06, 2006 1:53 pm
As for me:
Size: 14.9 GB (16,090,412,490 bytes)
Size on Disk: 15.0 GB (16,208,461,824 bytes)
55,949 files, 2,573 folders
I do love those POSKY and Meljet birds.  Smile Oh, and UT is in there, too.
Former ZW F/A | "Wisconsin 72A, contact departure, see ya."
gunsontheroof
Sat May 06, 2006 4:06 pm
Size on Disk: 22.6 GB
Contains: 102,614 files, 5,340 folders
Picked a hell of a week to quit sniffing glue.
jetflyer
Sat May 06, 2006 7:20 pm
Size: 29.8 GB (32,002,280,613 bytes)
Size on Disk: 30.0 GB (32,236,158,976 bytes)
Contains: 97,630 Files, 8,278 folders
777DadandJr
Sat May 06, 2006 8:32 pm
Size on Disk: 6.39G
Contains: 45,828 in 911 folders
Russ
My glass is neither 1/2 empty nor 1/2 full, rather, the glass itself is twice as big as it should be.
malaysia
Sat May 06, 2006 10:55 pm
Size: 11.5 GB (12,437,692,006 bytes)
Size on Disk: 9.47 GB (10,178,055,406 bytes)
Contains: 81,017 Files, 2,804 Folders
There Are Those Who Believe That There May Yet Be Other Airlines Who Even Now Fight To Survive Beyond The Heavens
woady
Sat May 06, 2006 11:50 pm
Mine is 17.5GB with 69,745 files.
Thank god for those big hard drives!
Woady
A300-600R, 737-300, 737-800, 757-200, 767-200/300/ER, ERJ145, ATR72
san747
Sun May 07, 2006 1:30 am
I clock in at:
Size: 7.43 GB (7,982,345,704 bytes)
Size on disk: 6.06 GB (6,509,349,824 bytes)
Files: 56,054
Folders: 3,021
Not much compared to most of you, however...
Scotty doesn't know...
csturdiv
Sun May 07, 2006 2:04 am
I just used a program called ACA2005 to pull up the stats on my install:
Number of Aircrafts installed: 337
Number of Aircraft textures (in aircraft.cfg): 4792
Number of Aircraft texture maps: 4765
Number of Aircraft used in Flightplans: 4949
Number of Flightplan files: 29
Number of Airports used in Flightplans: 278856
Number of different Airports used in Flightplans: 26380
Number of Flights: 38529
Number of Legs: 650313
Size of Aircraft map: 10.97GB
Size of Flight Simulator Map: 16.83GB
Much of my install is AI aircraft related (textures and flightplans) but I have recently gotten into the scenery bug.
An American expat from the ORD area living and working in SYD
jetflyer
Sun May 07, 2006 3:23 am
Oh yes some other information:
Number of Aircrafts installed: 753
Number of Aircraft textures (in aircraft.cfg): 4180
Number of Aircraft texture maps: 4198
Number of Aircraft used in Flightplans: 4496
Number of Flightplan files: 171
Number of Airports used in Flightplans: 1426194
Number of different Airports used in Flightplans: 26038
Number of Flights: 43959
Number of Legs: 721895
Svenskpilot
Thu May 25, 2006 3:45 pm
Can anyone beat this:
Big version: Width: 365 Height: 452 File size: 30kb
Boeinglover24
Fri May 26, 2006 1:53 am
Not quite up there yet.....
Uhhh What?
EA CO AS
Sat May 27, 2006 5:53 pm
Size: 12.0 GB (12,915,884,646 bytes)
Size on disk: 12.1 GB (13,056,667,648 bytes)
Contains: 71,878 Files, 2,474 Folders
jamesbuk
Sat May 27, 2006 6:41 pm
Mine is,
Size: 13.4 GB (14,426,684,554 bytes)
Size on disk:15.1 GB (16,235,102,208 bytes)
Files :77,795, 2905 folders
Rgds --James--
You cant have your cake and eat it... What the hells the point in having it then!!!
jetflyer
Sun May 28, 2006 12:54 am
Quoting Svenskpilot (Reply 12):
Quite a lot of people in a similar thread on www.fspassengers.com beat that easily one guy has over 100 payware addons and his is over 110GB.
chrisjake
Sun May 28, 2006 10:44 am
yep, see below
Size: 41.6 GB (44,773,016,780 bytes)
Size on disk: 42.0 GB (45,135,929,344 bytes)
contains: 168,750 Files, 10,028 Folders
chris
northwestEWR
Tue May 30, 2006 11:50 pm
I can top that.
Size on disk : 67GB
Contains : 157,308 files in 7,521 folders
Northwest Airlines - Now You're Flying Smart
AirPacific747
Wed May 31, 2006 12:11 am
Size: 8,09 GB (8.691.175.172 byte)
Size on disk: 8,20 GB (8.807.776.256 byte)
Contains: 55.035 files in 3.310 folders
AirPacific747
Wed May 31, 2006 12:13 am
Quoting Jetflyer (Reply 11):
lol how many flights is that per day since fs2004 came out???
LawrenceMck
Wed May 31, 2006 3:01 am
14.5GB for me
Lawrence  Smile
Love It To Live It
TheRedBaron
Wed May 31, 2006 12:52 pm
74 Gigs on X-plane......
Yeah I am nuts...
The best seat in a Plane is the Jumpseat.
kangarooman
Thu Jun 01, 2006 5:25 am
Hi all
mine is a measly: 401MB 4489 files 227 folders but mind this is a family computer and its FS98 with 1 bit of downloaded scenery and about 20 downloaded aircraft
Roo
A/C Flown EI 146&320, MYT 763&333, WW 733&735, AZ 319&MD80, LS 146, FR 738, 2L F100, LX 320&321, A3 RJ100, FI 752 AB 738
noelg
Sun Jun 11, 2006 5:07 am
FS has it's own computer with two hard drives - it is currently:
291,927 Files, 8,968 folders
Plus all related install files etc on the second hard drive.
Noel
dan2002
Sun Jun 11, 2006 11:56 am
Hah, lightweights,
Size:
94.6GB
328,963 files, 15,287 folders.
A guy asks 'What's Punk?'. I kick over a trash can and its punk. He knocks over a trash can and its trendy.
