csturdiv
Flight1 ATR 72-500
Sat May 20, 2006 10:20 am
Ok, I give up. I thought I was somewhat smart, but I cannot for the life of me figure out how to control the climb rate in the Flight1 ATR 72-500! The manual is somewhat confusing to read. And to make things worse, I cannot adjust the autopilot settings with FSNavigator.
An American expat from the ORD area living and working in SYD
gr325
RE: Flight1 ATR 72-500
Sat May 20, 2006 5:34 pm
You can control the climb rate on autopilot in two ways.
1: You can use vertical speed, ie; 1000 feet a minute. But you can also use IAS: indicated are speed, let's say you use 164 knots, it will climb the aircraft at 164 knots at all times. Am at work at the moment otherwise I could open FS and explain it in more detail.
What you also can do is set ias before you take off, sett altitude and hdg, then once airborne hot the AP button and it will climb at IAS.
Hope this helps a bit.
GR325
"You should have gone to specsavers"
csturdiv
Sun May 21, 2006 2:11 am
It did help some and good old fashioned trial and error helped as well. I finally figured it out and did a nice little flight from TJSJ to TQPF. Thanks for the help. This is a fun plane to fly.
