Jacks757
Who Makes The Best ATC Scanner?
Thu Jun 01, 2006 11:15 am
HI,
Im not sure if this is the correct forum but I was just wondering about handheld scanners. I want to purchase a scanner so I can listen to ATC. Does anyone recommend a certain scanner. I would like to get a good one for a decent price.
Thanks for all your help!
Jacks
Boeinglover24
RE: Who Makes The Best ATC Scanner?
Thu Jun 01, 2006 11:46 am
You can get one at Radioshack for just 70 bucks.
http://www.radioshack.com/product/in...K&x=9&kw=scanner&parentPage=search
I have one and it works well provided that I am near an airport (You don't need that many banks because you can get the frequencies online at airnav.com)
Uhhh What?
Jacks757
Thu Jun 01, 2006 3:51 pm
Thanks Boeinglover24!
LTU932
Thu Jun 01, 2006 5:17 pm
Yup, Radioshack pretty much has everything you need, including good scanners. I bought a Pro 94 scanner from Radioshack and except for one time not working for unknown reasons, it's been a blessing for me when I go to the airport or try to listen to any airliner on the departure from my house. However I might get another antenna for it to improve the reception from my house. If you want to listen to the ARTCCs or FIR control centres, and if you live far away from the next airport, I suggest you do the same eventually.
CDreier
Sun Jun 04, 2006 7:54 am
I read that the ICOM R5 is a very good receiver (read it here on the Airliners.net forum). Here's a link to info on the receiver: http://www.icomamerica.com/brochures/ic-r5.pdf
[Edited 2006-06-04 00:54:55]
syncmaster
Sun Jun 04, 2006 11:44 pm
I have the Pro 83 (see link provided above) as well, its been a great scanner and definately gets the job done. I would highly recommend it.  bigthumbsup
-Charlie
aviationwiz
Tue Jun 06, 2006 8:14 am
I have the Sporty's SP-125 and absolutely love it:
http://www.sportys.com/acb/showdetl.cfm?&Product_ID=6201&DID=19
Sporty's has great service and has one nice product.
Proudly from the Home of the Red Tail.
lorm
Tue Jun 06, 2006 7:09 pm
My advice, do the math..
Sporty's SP-125:
Covers AM broadcast band 530KHz-1620KHz, FM broadcast band 88-108MHz, Civil Airband 118-136MHz-143MHz.
5 Programable Scanning Frequency Channels
Being Sold for $189.00 at
http://www.sportys.com/acb/showdetl....m?DID=19&Product_ID=6201&CATID=165
Radioshack Pro-83 (Least Expensive Model) :
Covers 25-27.995, 28-29.995. 30-49.995, 50-54,
Civil Airband+Navigational Aid Spectrum 108-136.9875 , 137-143.995, 144-147.995, 148-174, 406-419.99375, 420-449.99375, 450-469.99375, 470-512, 806-823.9875, 849.0125-868.9875, 894.0125-956 MHz
200 Programable Scanning Frequency Channels
Backlit Display and Keys
Being Sold for $69.97 at
http://www.radioshack.com/product/in...1000094%2F&fbc=1&parentPage=family
If you want to listen to just broadcast AM and FM radio, and civil airband sure buy the more expensive Sporty's  wink . If you want to be able to listen to more than just those three, get a Radioshack or a Uniden Scanner. Radioshack and Uniden scanners are very feature rich and IMO offer the best value for the money.
Unfortunately Radioshack's handhelds do not cover the military airband spectrum 225-400MHz, but certain Uniden handhelds do. If you want to go all out and get a wideband reciever that can cover 500KHz-3000MHz, AOR has the (expensive) AR8200 MKIII.
Keep in mind however in listening to Civil and Military Airband, the audio quality and what you can hear all depends on the height of your recieving location and the distance you are from the transmission source. Airband communication is line of sight - If the airport you want to listen to is behind that mountain, you'll only recieve the aircraft after they are airborne and above it. For best results while scanning at home and farther locations you're going to have to put up an external antenna. If you live next to an airport or go spotting, no problem, the included antenna will do!
http://www.uniden.com
http://www.aorusa.com
-LorM
Brick Windows
Jacks757
Wed Jun 07, 2006 6:24 pm
Thanks for all the help!
Pilot3033
Thu Jun 08, 2006 3:17 pm
Quoting Syncmaster (Reply 5):
Let me throw in my .02 for the 83. I bought one on sale a week ago, and it works great when I go spotting. I bought a better atenna as well so I could go a bit further from the feild. Not the best for staying at home, but still great when I am out shooting.
-Matt
-Matt
DeltaWings
Mon Jun 26, 2006 3:13 am
How far away from the airport can you pic up the signals with the standard inkluding antenna? Can that antenna pick up signals from crusing aircraft at FL350? I am thinking of getting the Uniden BC92XLT.
Homer: Marge, it takes two to lie. One to lie and one to listen.
United_fan
Mon Jun 26, 2006 7:00 am
I too just bought the PRO 83 from Radio Shack after retiring my 12 year old Uniden scanner. The battery wouldn't hold a charge,and Uniden no longer made parts for it.I like it that the buttons light up.
Champagne For My Real Friends,and Real Pain For My Sham Friends
noelg
Tue Jun 27, 2006 6:43 am
If your budget can stretch to it I'd highly recommend a Yupiteru. My MVT-7300 has done me well for 5 years, with many years of life left. It has a lot of features and you can't beat it for quality.
Mine was £350 five years ago, you can pick them up for under £200 now.
777jaah
Wed Aug 19, 2009 3:49 pm
I have a question:
Could you use one of these inflight?? Kind of UA ch 9, but private.......
777Jaah
Next flights: AV BOG-ADZ-BOG, AV-UA BOG-IAD-ORD-IAD-BOG, BOG-FLL-BOG, LA BOG-MIA-BOG J
BOCHORA
Thu Aug 20, 2009 12:12 pm
Quoting 777jaah (Reply 13):
No it definitely transmits a radio signal!
LHRman
Sun Aug 23, 2009 11:45 am
If you can afford one, I stronly recommend the Icom IC-R20. Fantastic scanner and has done me well for 2 years now and I can see it keep going for ages so a great piece of kit.
Always after the picture you can't get..
brianhames
Wed Aug 26, 2009 1:31 am
Are you allowed to? No. But I've done it several times. You can't hear everything pretty well until you start talking to Center. I've never been able to pickup center, but so long as you can hear your pilots communications to Center that would work - provided they repeat the next frequency when asked to change...
I have an old Sporty's JD-100 which still works quite well. I've been looking into new scanners (perhaps a Uniden) or even a higher power trunk scanner from my car. I drive by SEA and BFI twice a day and would like to be able to pickup those stations while driving, the hand held does not do very well in that situation.
Brian
