klm672
Help - New Graphics Card - Dont See Improvement (Long!)
Sun Jul 16, 2006 8:20 pm
I just bought a new Graphics card last night, G-Force 6200 AGP 8x 256MD DDR yet I don't see any improvement in FS from before. Framerates are the same on the ground (varies between 7-20). In the air at cruise Frame rates do go up (sometimes i hit 32, 63 even). I was wonder what (if anything) i did wrong and how i could improve my frame rates.
andre
BEFORE:
System Information
Time of this report: 7/14/2006, 22:01:04
Machine name: ANDRE
Operating System: Windows XP Home Edition (5.1, Build 2600) Service Pack 1 (2600.xpsp2.030422-1633)
Language: English (Regional Setting: English)
System Manufacturer: n/a
System Model: Product Name
BIOS: Phoenix - AwardBIOS v6.00PG
Processor: AMD Athlon(tm) XP 3000+, MMX, 3DNow, ~2.2GHz
Memory: 448MB RAM
Page File: 444MB used, 613MB available
Windows Dir: C:WINDOWS
DirectX Version: DirectX 9.0b (4.09.0000.0902)
DX Setup Parameters: Not found
DxDiag Version: 5.03.0001.0902 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: The file nv4_disp.dll is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL). You may be able to get a WHQL logo'd driver from the hardware manufacturer.
Sound Tab 1: The file nvapu.sys is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL). You may be able to get a WHQL logo'd driver from the hardware manufacturer.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce4 MX Integrated GPU
Manufacturer: NVIDIA
Chip type: GeForce4 MX Integrated GPU
DAC type: Integrated RAMDAC
Device Key: EnumPCIVEN_10DE&DEV_01F0&SUBSYS_904D1509&REV_A3
Display Memory: 64.0 MB
Current Mode: 1024 x 768 (32 bit) (75Hz)
Monitor: Plug and Play Monitor
Monitor Max Res: 1600,1200
Driver Name: nv4_disp.dll
Driver Version: 6.14.0010.5664 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 3/4/2004 17:29:00, 4256896 bytes
WHQL Logo'd: No
WHQL Date Stamp: None
VDD: n/a
Mini VDD: nv4_mini.sys
Mini VDD Date: 3/4/2004 17:29:00, 1893536 bytes
Device Identifier: {D7B71E3E-42B0-11CF-9960-47B002C2CB35}
Vendor ID: 0x10DE
Device ID: 0x01F0
SubSys ID: 0x904D1509
Revision ID: 0x00A3
Revision ID: 0x00A3
Video Accel: ModeMPEG2_A ModeMPEG2_B ModeMPEG2_C ModeMPEG2_D
Deinterlace Caps: {212DC723-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(YUY2,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_MedianFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{212DC723-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_MedianFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description: NVIDIA(R) nForce(TM) Audio
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: NFORCE_VAD
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: nvapu.sys
Driver Version: 6.14.0366.0000 (English)
WHQL Logo'd: No
Date and Size: 9/3/2003 23:51:00, 312704 bytes
Other Files:
Driver Provider: NVIDIA Corporation
HW Accel Level: Full
Cap Flags: 0xF5F
Min/Max Sample Rate: 100, 100000
Static/Strm HW Mix Bufs: 256, 254
Static/Strm HW 3D Bufs: 64, 64
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: Yes, Yes
I3DL2(tm) Listen/Src: Yes, Yes
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: Not run
Sound Capture Devices
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x41
Format Flags: 0xCC0
DirectMusic
DLS Path: C:WINDOWSSYSTEM32driversGM.DLS
DLS Version: 1.00.0016.0002
Acceleration: Enabled
Ports: NVIDIA(R) Kernel Synthesizer, Hardware (Kernel Mode), Output, DLS, Internal, Default Port
NVIDIA(R) nForce(TM) Audio, Software (Kernel Mode), Output, DLS, Internal
Microsoft MIDI Mapper [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
NVIDIA(R) DLS Synthesizer [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
Microsoft GS Wavetable SW Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: SideWinder Joystick
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x045E, 0x003C
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x10DE, 0x0067
| Matching Device ID: usbroot_hub
| Service: usbhub
| Driver: usbhub.sys, 7/4/2003 03:52:58, 53120 bytes
| Driver: usbd.sys, 3/31/2003 08:00:00, 4736 bytes
+-+ USB Human Interface Device
| | Matching Device ID: usbclass_03
| | Service: HidUsb
| | OEMData: 01 00 00 10 08 00 00 00
| | Driver: hidusb.sys, 8/18/2001 21:02:20, 9600 bytes
| | Driver: hidparse.sys, 3/31/2003 08:00:00, 23680 bytes
| | Driver: hid.dll, 8/17/2001 18:36:16, 22528 bytes
| | Driver: hidclass.sys, 3/31/2003 08:00:00, 34560 bytes
| +-+ HID-compliant game controller
| | | Matching Device ID: hid_device_system_game
Gameport Devices
PS/2 Devices
+ Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
| Matching Device ID: *pnp0303
| Service: i8042prt
| Driver: i8042prt.sys, 3/31/2003 08:00:00, 51072 bytes
| Driver: kbdclass.sys, 3/31/2003 08:00:00, 23424 bytes
+ Terminal Server Keyboard Driver
| Matching Device ID: rootrdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 8/28/2002 23:46:42, 38024 bytes
+ PS/2 Compatible Mouse
| Matching Device ID: *pnp0f13
| Service: i8042prt
| Driver: mouclass.sys, 8/28/2002 21:27:02, 22016 bytes
+ Terminal Server Mouse Driver
| Matching Device ID: rootrdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.0000.0900)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.0000.0900)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.0000.0900)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.0000.0900)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.0000.0900)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.0000.0900)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.0000.0900)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.0000.0900)
DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 Modem Service Provider: PCI SoftV92 Data Fax Modem with SmartCP
DirectPlay8 Serial Service Provider: COM1
DirectPlay8 TCP/IP Service Provider: Paradis - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1.4kbit/s
Voxware SC06 6.4kbit/s
Voxware SC03 3.2kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech(TM) 8.6 kbit/s
DirectPlay Lobbyable Apps
Flight Simulator (DX8) - Registry: OK, ExeFile: FS9.Exe (9.00.0000.30612) LauncherFile: ()
Microsoft Flight Simulator 2004 (DX7) - Registry: OK, ExeFile: FS9.Exe (9.00.0000.30612)
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 130.5 GB
Total Space: 152.6 GB
File System: NTFS
Model: WDC WD1600BB-00FTA0
Drive: D:
Model: LITE-ON CD-ROM LTN-487T
Driver: c:windowssystem32driverscdrom.sys, 5.01.2600.1106 (English), 3/31/2003 08:00:00, 47488 bytes
Drive: E:
Model: _NEC DVD_RW ND-2500A
System Devices
Name: PCI SoftV92 Data Fax Modem with SmartCP
Device ID: PCIVEN_14F1&DEV_2F20&SUBSYS_200014F1&REV_004&3B1D9AB8&0&4040
Driver: C:WINDOWSSYSTEM32DRIVERSHSF_CNXT.sys, 7.04.0005.0000 (English), 11/15/2003 01:18:36, 679808 bytes
Driver: C:WINDOWSSYSTEM32DRIVERSHSFHWBS2.sys, 7.04.0005.0000 (English), 11/15/2003 01:19:48, 210304 bytes
Driver: C:WINDOWSSYSTEM32DRIVERSHSF_DP.sys, 7.04.0005.0000 (English), 11/15/2003 01:17:00, 1042816 bytes
Driver: C:WINDOWSSYSTEM32DRIVERSmdmxsdk.sys, 1.00.0002.0005 (English), 1/17/2004 21:21:48, 12970 bytes
Driver: C:WINDOWSSYSTEM32DRIVERSHSFProf.cty, 11/15/2003 01:30:12, 128333 bytes
Driver: C:WINDOWSSystem32mdmxsdk.dll, 1.00.0002.0005 (English), 1/17/2004 22:14:50, 86016 bytes
Driver: C:Program FilesCONEXANTCNXT_MODEM_PCI_VEN_14F1&DEV_2F20&SUBSYS_200014F1HXFSetup.exe, 2.01.0007.0000 (English), 10/12/2003 08:18:58, 524288 bytes
Driver: C:WINDOWSSystem32HSFCI008.dll, 7.04.0002.0000 (English), 11/6/2003 22:02:02, 32218 bytes
Name: NVIDIA GeForce4 MX Integrated GPU
Device ID: PCIVEN_10DE&DEV_01F0&SUBSYS_904D1509&REV_A34&1B197270&0&00F0
Driver: C:WINDOWSSystem32DRIVERSnv4_mini.sys, 6.14.0010.5664 (English), 3/4/2004 17:29:00, 1893536 bytes
Driver: C:WINDOWSSystem32nvinstnt.dll, 6.14.0010.5664 (English), 3/4/2004 17:29:00, 131072 bytes
Driver: C:WINDOWSSystem32nvsvc32.exe, 6.14.0010.5664 (English), 3/4/2004 17:29:00, 77824 bytes
Driver: C:WINDOWSSystem32nvcod.dll, 1.00.0000.0014 (English), 3/4/2004 17:29:00, 31744 bytes
Driver: C:WINDOWSSystem32nvcodins.dll, 1.00.0000.0014 (English), 3/4/2004 17:29:00, 31744 bytes
Driver: C:WINDOWSSystem32nv4_disp.dll, 6.14.0010.5664 (English), 3/4/2004 17:29:00, 4256896 bytes
Driver: C:WINDOWSSystem32nvoglnt.dll, 6.14.0010.5664 (English), 3/4/2004 17:29:00, 4841472 bytes
Driver: C:WINDOWSSystem32nvcpl.dll, 6.14.0010.5664 (English), 3/4/2004 17:29:00, 2904064 bytes
Driver: C:WINDOWSSystem32nvmctray.dll, 6.14.0010.5664 (English), 3/4/2004 17:29:00, 46080 bytes
Driver: C:WINDOWSSystem32nvwddi.dll, 6.14.0010.5664 (English), 3/4/2004 17:29:00, 36864 bytes
Driver: C:WINDOWSSystem32nvwdmcpl.dll, 6.14.0010.5664 (English), 3/4/2004 17:29:00, 1617920 bytes
Driver: C:WINDOWSSystem32nvnt4cpl.dll, 6.14.0010.5664 (English), 3/4/2004 17:29:00, 241664 bytes
Driver: C:WINDOWShelpnvcpl.hlp, 3/4/2004 17:29:00, 87403 bytes
Driver: C:WINDOWShelpnvwcplen.hlp, 3/4/2004 17:29:00, 49796 bytes
Name: NVIDIA nForce2 Memory Controller
Device ID: PCIVEN_10DE&DEV_01EF&SUBSYS_904D1509&REV_A23&13C0B0C5&0&05
Driver: n/a
Device ID: PCIVEN_10DE&DEV_01EE&SUBSYS_904D1509&REV_A23&13C0B0C5&0&02
Driver: n/a
Device ID: PCIVEN_10DE&DEV_01ED&SUBSYS_904D1509&REV_A23&13C0B0C5&0&03
Driver: n/a
Device ID: PCIVEN_10DE&DEV_01EC&SUBSYS_904D1509&REV_A23&13C0B0C5&0&04
Driver: n/a
Device ID: PCIVEN_10DE&DEV_01EB&SUBSYS_904D1509&REV_A23&13C0B0C5&0&01
Driver: n/a
Name: NVIDIA nForce2 AGP Host to PCI Bridge
Device ID: PCIVEN_10DE&DEV_01E8&SUBSYS_00000000&REV_A23&13C0B0C5&0&F0
Driver: C:WINDOWSSystem32DRIVERSnv_agp.SYS, 4.12.0001.0334 (English), 3/20/2003 22:51:00, 18688 bytes
Driver: C:WINDOWSSystem32nvugart.exe, 1.00.0000.0030 (English), 5/14/2003 02:28:00, 77824 bytes
Driver: C:WINDOWSSystem32nvgart.nvu, 6/6/2003 22:00:18, 1431 bytes
Name: PCI standard host CPU bridge
Device ID: PCIVEN_10DE&DEV_01E0&SUBSYS_00000000&REV_A23&13C0B0C5&0&00
Driver: n/a
Name: PCI standard PCI-to-PCI bridge
Device ID: PCIVEN_10DE&DEV_006C&SUBSYS_00000000&REV_A33&13C0B0C5&0&40
Driver: C:WINDOWSSystem32DRIVERSpci.sys, 5.01.2600.1106 (English), 3/31/2003 08:00:00, 62976 bytes
Name: NVIDIA(R) nForce(TM) MCP Audio Processing Unit (Dolby(R) Digital)
Device ID: PCIVEN_10DE&DEV_006B&SUBSYS_904D1509&REV_A23&13C0B0C5&0&28
Driver: C:WINDOWSSystem32ksuser.dll, 5.03.0000.0900 (English), 12/12/2002 10:14:32, 4096 bytes
Driver: C:WINDOWSSystem32ksproxy.ax, 5.03.0000.0900 (English), 12/12/2002 10:14:32, 117248 bytes
Driver: C:WINDOWSSystem32wdmaud.drv, 5.01.2600.0000 (English), 8/17/2001 18:37:04, 22016 bytes
Driver: C:WINDOWSsystem32driversks.sys, 5.03.0000.0900 (English), 12/12/2002 10:14:32, 130304 bytes
Driver: C:WINDOWSsystem32driversdrmk.sys, 5.01.2600.1106 (English), 8/30/2002 08:32:34, 57856 bytes
Driver: C:WINDOWSsystem32driversportcls.sys, 5.01.2600.1106 (English), 8/30/2002 09:01:00, 134272 bytes
Driver: C:WINDOWSsystem32driversstream.sys, 5.03.0000.0900 (English), 12/12/2002 10:14:32, 45696 bytes
Driver: C:WINDOWSsystem32driversnvax.sys, 6.14.0366.0000 (English), 9/3/2003 23:51:00, 36864 bytes
Driver: C:WINDOWSsystem32driversnvarm.sys, 6.14.0366.0000 (English), 9/3/2003 23:51:00, 66816 bytes
Driver: C:WINDOWSsystem32driversnvmcp.sys, 6.14.0366.0000 (English), 9/3/2003 23:51:00, 992640 bytes
Driver: C:WINDOWSsystem32driversnvapu.sys, 6.14.0366.0000 (English), 9/3/2003 23:51:00, 312704 bytes
Driver: C:WINDOWSSystem32nvack.dll, 6.14.0366.0000 (English), 9/3/2003 23:51:00, 7168 bytes
Driver: C:WINDOWSSystem32nvasio.dll, 6.14.0366.0000 (English), 9/3/2003 23:51:00, 29696 bytes
Driver: C:WINDOWSSystem32nvopenal.dll, 6.14.0366.0000 (English), 9/3/2003 23:51:00, 47104 bytes
Driver: C:WINDOWSSystem32OpenAL32.dll, 6.14.0366.0000 (English), 9/3/2003 23:51:00, 19456 bytes
Driver: C:WINDOWSSystem32ALut.dll, 6.14.0366.0000 (English), 9/3/2003 23:51:00, 5120 bytes
Driver: C:WINDOWSSystem32nvuaudio.exe, 1.00.0000.0037 (English), 9/3/2003 23:51:00, 98304 bytes
Driver: C:WINDOWSSystem32nvaudio.nvu, 9/3/2003 23:51:00, 2864 bytes
Name: NVIDIA(R) nForce(TM) Audio Codec Interface
Device ID: PCIVEN_10DE&DEV_006A&SUBSYS_904D1509&REV_A13&13C0B0C5&0&30
Name: Standard Enhanced PCI to USB Host Controller
Device ID: PCIVEN_10DE&DEV_0068&SUBSYS_904D1509&REV_A43&13C0B0C5&0&12
Driver: C:WINDOWSsystem32driversusbehci.sys, 5.01.2600.1243 (English), 7/4/2003 03:50:46, 25216 bytes
Driver: C:WINDOWSsystem32driversusbport.sys, 5.01.2600.1243 (English), 7/4/2003 03:49:30, 138752 bytes
Driver: C:WINDOWSsystem32driversusbhub.sys, 5.01.2600.1243 (English), 7/4/2003 03:52:58, 53120 bytes
Driver: C:WINDOWSSystem32hccoin.dll, 5.01.2600.1243 (English), 7/4/2003 03:50:12, 5632 bytes
Driver: C:WINDOWSSystem32usbui.dll, 5.01.2600.0000 (English), 8/17/2001 18:36:34, 67072 bytes
Name: Standard OpenHCD USB Host Controller
Device ID: PCIVEN_10DE&DEV_0067&SUBSYS_904D1509&REV_A43&13C0B0C5&0&11
Driver: C:WINDOWSsystem32driversusbohci.sys, 5.01.2600.1243 (English), 7/5/2003 07:51:16, 16000 bytes
Device ID: PCIVEN_10DE&DEV_0067&SUBSYS_904D1509&REV_A43&13C0B0C5&0&10
Name: NVIDIA nForce MCP Networking Controller
Device ID: PCIVEN_10DE&DEV_0066&SUBSYS_904D1509&REV_A13&13C0B0C5&0&20
Driver: C:WINDOWSSystem32DRIVERSNVENET.sys, 4.14.0001.0363 (English), 8/17/2003 02:22:16, 72771 bytes
Driver: C:WINDOWSSystem32nvuenet.exe, 1.00.0000.0031 (English), 8/17/2003 02:52:38, 94208 bytes
Driver: C:WINDOWSSystem32nvenet.nvu, 8/17/2003 02:05:38, 1398 bytes
Name: NVIDIA nForce2 IDE Controller
Device ID: PCIVEN_10DE&DEV_0065&SUBSYS_904D1509&REV_A23&13C0B0C5&0&48
Driver: C:WINDOWSSystem32DRIVERSpciide.sys, 5.01.2600.0000 (English), 3/31/2003 08:00:00, 3328 bytes
Driver: C:WINDOWSSystem32DRIVERSpciidex.sys, 5.01.2600.1106 (English), 3/31/2003 08:00:00, 23680 bytes
Driver: C:WINDOWSSystem32DRIVERSatapi.sys, 5.01.2600.1106 (English), 3/31/2003 08:00:00, 86912 bytes
Driver: C:WINDOWSSystem32nvuide.exe, 1.00.0000.0044 (English), 10/11/2003 19:11:00, 102400 bytes
Driver: C:WINDOWSSystem32nvide.nvu, 10/11/2003 19:11:00, 634 bytes
Name: NVIDIA nForce PCI System Management
Device ID: PCIVEN_10DE&DEV_0064&SUBSYS_904D1509&REV_A23&13C0B0C5&0&09
Driver: n/a
Name: PCI standard ISA bridge
Device ID: PCIVEN_10DE&DEV_0060&SUBSYS_00000000&REV_A43&13C0B0C5&0&08
Driver: C:WINDOWSSystem32DRIVERSisapnp.sys, 5.01.2600.0000 (English), 3/31/2003 08:00:00, 35840 bytes
DirectX Components
ddraw.dll: 5.03.0000.0900 English Final Retail 12/12/2002 10:14:32 284160 bytes
ddrawex.dll: 5.03.0000.0900 English Final Retail 12/12/2002 10:14:32 24064 bytes
dxapi.sys: 5.01.2600.0000 English Final Retail 3/31/2003 08:00:00 10496 bytes
d3d8.dll: 5.03.0000.0900 English Final Retail 12/12/2002 10:14:32 1177600 bytes
d3d8thk.dll: 5.03.0000.0900 English Final Retail 12/12/2002 10:14:32 8192 bytes
d3d9.dll: 5.03.0001.0902 English Final Retail 5/30/2003 19:00:02 1634304 bytes
d3dim.dll: 5.01.2600.0000 English Final Retail 3/31/2003 08:00:00 436224 bytes
d3dim700.dll: 5.03.0001.0902 English Final Retail 5/30/2003 19:00:02 797184 bytes
d3dramp.dll: 5.01.2600.0000 English Final Retail 3/31/2003 08:00:00 590336 bytes
d3drm.dll: 5.01.2600.0000 English Final Retail 3/31/2003 08:00:00 350208 bytes
d3dxof.dll: 5.01.2600.0000 English Final Retail 3/31/2003 08:00:00 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 3/31/2003 08:00:00 34816 bytes
dplay.dll: 5.00.2134.0001 English Final Retail 3/31/2003 08:00:00 33040 bytes
dplayx.dll: 5.03.0000.0900 English Final Retail 12/12/2002 10:14:32 217600 bytes
dpmodemx.dll: 5.03.0000.0900 English Final Retail 12/12/2002 10:14:32 77824 bytes
dpwsock.dll: 5.00.2134.0001 English Final Retail 3/31/2003 08:00:00 42768 bytes
dpwsockx.dll: 5.03.0000.0900 English Final Retail 12/12/2002 10:14:32 76800 bytes
dplaysvr.exe: 5.03.0000.0900 English Final Retail 12/12/2002 10:14:32 28160 bytes
dpnsvr.exe: 5.03.0000.0900 English Final Retail 12/12/2002 10:14:32 16896 bytes
dpnet.dll: 5.03.0000.0900 English Final Retail 12/12/2002 10:14:32 723968 bytes
dpnlobby.dll: 5.03.0000.0900 English Final Retail 12/12/2002 10:14:32 3072 bytes
dpnaddr.dll: 5.03.0000.0900 English Final Retail 12/12/2002 10:14:32 3072 bytes
dpvoice.dll: 5.03.0000.0900 English Final Retail 12/12/2002 10:14:32 381952 bytes
dpvsetup.exe: 5.03.0000.0900 English Final Retail 12/12/2002 10:14:32 80896 bytes
dpvvox.dll: 5.03.0000.0900 English Final Retail 12/12/2002 10:14:32 112128 bytes
dpvacm.dll: 5.03.0000.0900 English Final Retail 12/12/2002 10:14:32 19968 bytes
dpnhpast.dll: 5.03.0000.0901 English Final Retail 3/24/2003 19:00:02 32768 bytes
dpnhupnp.dll: 5.03.0000.0901 English Final Retail 3/24/2003 19:00:02 68096 bytes
dpserial.dll: 5.00.2134.0001 English Final Retail 3/31/2003 08:00:00 53520 bytes
dinput.dll: 5.01.2600.1106 English Final Retail 3/31/2003 08:00:00 151552 bytes
dinput8.dll: 5.01.2600.1106 English Final Retail 3/31/2003 08:00:00 168960 bytes
dimap.dll: 5.01.2600.0000 English Final Retail 3/31/2003 08:00:00 44032 bytes
diactfrm.dll: 5.01.2600.0000 English Final Retail 3/31/2003 08:00:00 394240 bytes
joy.cpl: 5.01.2600.1106 English Final Retail 3/31/2003 08:00:00 65536 bytes
gcdef.dll: 5.01.2600.0000 English Final Retail 3/31/2003 08:00:00 76800 bytes
pid.dll: 5.01.2600.1106 English Final Retail 8/28/2002 23:41:10 31744 bytes
dsound.dll: 5.03.0000.0900 English Final Retail 12/12/2002 10:14:32 355328 bytes
dsound3d.dll: 5.03.0000.0900 English Final Retail 12/12/2002 10:14:32 1294336 bytes
dswave.dll: 5.03.0000.0900 English Final Retail 12/12/2002 10:14:32 18432 bytes
dsdmo.dll: 5.03.0000.0900 English Final Retail 12/12/2002 10:14:32 186880 bytes
dsdmoprp.dll: 5.03.0000.0900 English Final Retail 12/12/2002 10:14:32 491520 bytes
dmusic.dll: 5.03.0000.0900 English Final Retail 12/12/2002 10:14:32 116736 bytes
dmband.dll: 5.03.0000.0900 English Final Retail 12/12/2002 10:14:32 27136 bytes
dmcompos.dll: 5.03.0000.0900 English Final Retail 12/12/2002 10:14:32 58368 bytes
dmime.dll: 5.03.0000.0900 English Final Retail 12/12/2002 10:14:32 171520 bytes
dmloader.dll: 5.03.0000.0900 English Final Retail 12/12/2002 10:14:32 33280 bytes
dmstyle.dll: 5.03.0000.0900 English Final Retail 12/12/2002 10:14:32 98816 bytes
dmsynth.dll: 5.03.0000.0900 English Final Retail 12/12/2002 10:14:32 100864 bytes
dmscript.dll: 5.03.0000.0900 English Final Retail 12/12/2002 10:14:32 76800 bytes
dx7vb.dll: 5.03.0000.0900 English Final Retail 12/12/2002 10:14:32 602624 bytes
dx8vb.dll: 5.03.0001.0902 English Final Retail 5/30/2003 19:00:02 1189888 bytes
dxdiagn.dll: 5.03.0001.0902 English Final Retail 5/30/2003 19:00:02 1675264 bytes
mfc40.dll: 4.01.0000.6140 English Final Retail 3/31/2003 08:00:00 924432 bytes
mfc42.dll: 6.00.8665.0000 English Beta Retail 3/31/2003 08:00:00 995383 bytes
wsock32.dll: 5.01.2600.0000 English Final Retail 3/31/2003 08:00:00 21504 bytes
amstream.dll: 6.05.0001.0900 English Final Retail 12/12/2002 10:14:32 64512 bytes
devenum.dll: 6.05.0001.0902 English Final Retail 5/30/2003 19:00:02 132608 bytes
dxmasf.dll: 6.04.0009.1125 English Final Retail 3/31/2003 08:00:00 498205 bytes
mciqtz32.dll: 6.05.0001.0900 English Final Retail 12/12/2002 10:14:32 34304 bytes
mpg2splt.ax: 6.05.0001.0900 English Final Retail 12/12/2002 10:14:32 136192 bytes
msdmo.dll: 6.05.0001.0900 English Final Retail 12/12/2002 10:14:32 13312 bytes
encapi.dll: 5.03.0000.0900 English Final Retail 12/12/2002 10:14:32 18944 bytes
qasf.dll: 9.00.0000.2980 English Final Retail 12/12/2002 03:34:40 241664 bytes
qcap.dll: 6.05.0001.0900 English Final Retail 12/12/2002 10:14:32 257024 bytes
qdv.dll: 6.05.0001.0900 English Final Retail 12/12/2002 10:14:32 311808 bytes
qdvd.dll: 6.05.0001.0902 English Final Retail 5/30/2003 19:00:02 449024 bytes
qedit.dll: 6.05.0001.0900 English Final Retail 12/12/2002 10:14:32 1798144 bytes
qedwipes.dll: 6.05.0001.0900 English Final Retail 12/12/2002 10:14:32 733184 bytes
quartz.dll: 6.05.0001.0902 English Final Retail 5/30/2003 19:00:02 1962496 bytes
strmdll.dll: 4.01.0000.3928 English Final Retail 3/31/2003 08:00:00 251904 bytes
iac25_32.ax: 2.00.0005.0053 English Final Retail 11/14/2002 22:58:00 199680 bytes
ir41_32.ax: 4.51.0016.0003 English Final Retail 11/14/2002 22:58:00 848384 bytes
ir41_qc.dll: 4.30.0062.0002 English Final Retail 11/14/2002 22:58:02 120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 11/14/2002 22:58:02 338432 bytes
ir50_32.dll: 5.2562.0015.0055 English Final Retail 11/14/2002 22:58:02 755200 bytes
ir50_qc.dll: 5.00.0063.0048 English Final Retail 11/14/2002 22:58:04 200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 11/14/2002 22:58:04 183808 bytes
ivfsrc.ax: 5.10.0002.0051 English Final Retail 11/14/2002 22:58:06 154624 bytes
mswebdvd.dll: 6.05.0001.0900 English Final Retail 12/12/2002 10:14:32 324096 bytes
ks.sys: 5.03.0000.0900 English Final Retail 12/12/2002 10:14:32 130304 bytes
ksproxy.ax: 5.03.0000.0900 English Final Retail 12/12/2002 10:14:32 117248 bytes
ksuser.dll: 5.03.0000.0900 English Final Retail 12/12/2002 10:14:32 4096 bytes
stream.sys: 5.03.0000.0900 English Final Retail 12/12/2002 10:14:32 45696 bytes
mspclock.sys: 5.03.0000.0900 English Final Retail 12/12/2002 10:14:32 5248 bytes
mspqm.sys: 5.01.2600.0000 English Final Retail 8/17/2001 09:48:46 4608 bytes
mskssrv.sys: 5.03.0000.0900 English Final Retail 12/12/2002 10:14:32 7424 bytes
swenum.sys: 5.03.0000.0900 English Final Retail 12/12/2002 10:14:32 4096 bytes
mstee.sys: 5.03.0000.0900 English Final Retail 12/12/2002 10:14:32 5504 bytes
bdaplgin.ax: 5.03.0000.0900 English Final Retail 2/17/2003 20:16:26 16896 bytes
bdasup.sys: 5.03.0000.0900 English Final Retail 2/17/2003 20:16:26 11392 bytes
msdvbnp.ax: 6.05.0001.0900 English Final Retail 2/17/2003 20:16:26 52224 bytes
psisdecd.dll: 6.05.0001.0900 English Final Retail 2/17/2003 20:16:28 354816 bytes
psisrndr.ax: 6.05.0001.0900 English Final Retail 2/17/2003 20:16:28 30208 bytes
ipsink.ax: 5.03.0000.0900 English Final Retail 2/17/2003 20:16:26 14848 bytes
mpeg2data.ax: 6.05.0001.0900 English Final Retail 2/17/2003 20:16:26 57856 bytes
ndisip.sys: 5.03.0000.0900 English Final Retail 2/17/2003 20:16:28 10112 bytes
mpe.sys: 5.03.0000.0900 English Final Retail 2/17/2003 20:16:26 15104 bytes
streamip.sys: 5.03.0000.0900 English Final Retail 2/17/2003 20:16:28 14976 bytes
msvidctl.dll: 6.05.0001.0900 English Final Retail 2/17/2003 20:16:28 1230336 bytes
slip.sys: 5.03.0000.0900 English Final Retail 2/17/2003 20:16:28 10880 bytes
nabtsfec.sys: 5.03.0000.0900 English Final Retail 2/17/2003 20:16:28 83968 bytes
ccdecode.sys: 5.03.0000.0900 English Final Retail 2/17/2003 20:16:26 16384 bytes
vbisurf.ax: 5.03.0000.0900 English Final Retail 2/17/2003 20:16:30 27648 bytes
msyuv.dll: 5.03.0000.0900 English Final Retail 2/17/2003 20:16:28 16896 bytes
kstvtune.ax: 5.03.0001.0902 English Final Retail 6/4/2003 20:30:32 274432 bytes
ksxbar.ax: 5.03.0001.0902 English Final Retail 6/4/2003 19:18:28 39424 bytes
kswdmcap.ax: 5.03.0000.0900 English Final Retail 2/17/2003 20:16:32 226304 bytes
wstcodec.sys: 5.03.0000.0900 English Final Retail 2/17/2003 20:16:32 18688 bytes
wstdecod.dll: 5.03.0000.0900 English Final Retail 2/17/2003 20:16:32 47104 bytes
msdv.sys: 5.01.2600.0000 English Final Retail 8/17/2001 10:06:34 52096 bytes
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMSpeech Decoder DMO,0x00600800,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00800001,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
WMT MuxDeMux Filter,0x00200000,0,0,WMM2FILT.dll,2.00.3312.0000
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.0001.0902
CyberLink DVD Navigator,0x00600000,0,3,CLNAVX.ax,5.00.0000.1031
DV Muxer,0x00400000,0,0,qdv.dll,6.05.0001.0900
Nero Digital Audio Decoder,0x00600000,1,1,NeAudio.ax,1.00.0003.0057
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.0001.0902
WM ASF Reader,0x00400000,0,0,qasf.dll,9.00.0000.2980
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.0001.0902
WMT AudioAnalyzer,0x00200000,1,1,WMM2FILT.dll,2.00.3312.0000
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.0001.0902
Indeo® video 5.10 Compression Filter,0x00200000,1,1,Ir50_32.dll,5.2562.0015.0055
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.0001.0900
WMT Format Conversion,0x00200000,1,1,WMM2FILT.dll,2.00.3312.0000
StreamBufferSink,0x00200000,0,0,sbe.dll,6.04.2600.1106
WMT Black Frame Generator,0x00200000,1,1,WMM2FILT.dll,2.00.3312.0000
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.0001.0902
Indeo® video 5.10 Decompression Filter,0x00640000,1,1,Ir50_32.dll,5.2562.0015.0055
WMT Screen Capture filter,0x00200000,0,1,WMM2FILT.dll,2.00.3312.0000
Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4487
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.0001.0902
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.0001.0902
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.05.0000.0050
Nero Audio Stream Renderer,0x00200000,1,0,NeRender.ax,1.00.0001.0008
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.0001.0900
CyberLink Audio Effect,0x00200000,1,1,claudfx.ax,5.00.0000.1028
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
CyberLink Line21 Decoder Filter,0x00200000,0,2,CLLine21.ax,4.00.0000.3030
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.0001.0902
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.0001.0902
File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,9.00.0000.2980
WMT Import Filter,0x00200000,0,1,WMM2FILT.dll,2.00.3312.0000
DV Splitter,0x00600000,1,2,qdv.dll,6.05.0001.0900
Bitmap Generate,0x00200000,1,1,WMM2FILT.dll,2.00.3312.0000
Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.05.0001.0902
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
CyberLink AudioCD Filter,0x00600000,0,1,CLAudioCD.ax,5.00.0000.1031
WMT VIH2 Fix,0x00200000,1,1,WMM2FILT.dll,2.00.3312.0000
Record Queue,0x00200000,1,1,WMM2FILT.dll,2.00.3312.0000
Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,9.00.0000.2980
ASX file Parser,0x00600000,1,1,wmpasf.dll,9.00.0000.2980
ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,9.00.0000.2980
NSC file Parser,0x00600000,1,1,wmpasf.dll,9.00.0000.2980
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.0001.0902
Windows Media source filter,0x00600000,0,2,wmpasf.dll,9.00.0000.2980
Video Renderer,0x00800001,1,0,quartz.dll,6.05.0001.0902
Frame Eater,0x00200000,1,1,WMM2FILT.dll,2.00.3312.0000
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.04.2600.1106
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.0001.0902
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.0001.0902
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.0000.0900
Video Renderer,0x00400000,1,0,quartz.dll,6.05.0001.0902
Nero Audio Sample Renderer,0x00200000,1,0,NeRender.ax,1.00.0001.0008
WM ASF Writer,0x00400000,0,0,qasf.dll,9.00.0000.2980
WMT Sample Information Filter,0x00200000,1,1,WMM2FILT.dll,2.00.3312.0000
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.0000.0900
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000.4487
Nero Video Stream Renderer,0x00200000,1,0,NeRender.ax,1.00.0001.0008
File writer,0x00200000,1,0,qcap.dll,6.05.0001.0900
WMT Log Filter,0x00200000,1,1,WMM2FILT.dll,2.00.3312.0000
WMT Virtual Renderer,0x00200000,1,0,WMM2FILT.dll,2.00.3312.0000
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.0001.0902
CyberLink Audio Decoder,0x00601000,1,1,claud.ax,5.00.0000.1029
CyberLink Video/SP Decoder,0x00600000,2,3,CLVSD.ax,5.00.0000.1031
CyberLink TimeStretch Filter,0x00200000,1,1,CLAuTS.ax,1.00.0000.0704
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.0001.0902
AVI Draw,0x00600064,9,1,quartz.dll,6.05.0001.0902
.RAM file Parser,0x00600000,1,0,wmpasf.dll,9.00.0000.2980
WMT DirectX Transform Wrapper,0x00200000,1,1,WMM2FILT.dll,2.00.3312.0000
G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.0001.0900
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.0001.0900
Indeo® audio software,0x00500000,1,1,iac25_32.ax,2.00.0005.0053
Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,9.00.0000.2980
ASF DIB Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.2980
ASF ACM Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.2980
ASF ICM Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.2980
ASF URL Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.2980
ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.2980
ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.2980
ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.2980
9x8Resize,0x00200000,1,1,WMM2FILT.dll,2.00.3312.0000
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
Nero Video Decoder,0x00600000,2,3,NeVideo.ax,1.01.0007.0038
Allocator Fix,0x00200000,1,1,WMM2FILT.dll,2.00.3312.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.0001.0900
Null Renderer,0x00200000,1,0,qedit.dll,6.05.0001.0900
WMT Virtual Source,0x00200000,0,1,WMM2FILT.dll,2.00.3312.0000
MPEG-2 Sections and Tables,0x005fffff,1,0,mpeg2data.ax,6.05.0001.0900
IVF source filter,0x00600000,0,1,,5.10.0002.0051
WMT Interlacer,0x00200000,1,1,WMM2FILT.dll,2.00.3312.0000
StreamBufferSource,0x00200000,0,0,sbe.dll,6.04.2600.1106
Smart Tee,0x00200000,1,2,qcap.dll,6.05.0001.0900
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.0001.0902
RealPlayer Audio Filter,0x00200000,1,1,rdsf3260.dll,6.00.0012.0933
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.0001.0902
Uncompressed Domain Shot Detection Filter,0x00200000,1,1,WMM2FILT.dll,2.00.3312.0000
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.0001.0902
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.0001.0902
Wave Parser,0x00400000,1,1,quartz.dll,6.05.0001.0902
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.0001.0902
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.0001.0902
Lyric Parser,0x00400000,1,1,quartz.dll,6.05.0001.0902
File stream renderer,0x00400000,1,1,quartz.dll,6.05.0001.0902
XML Playlist,0x00400000,1,0,wmpasf.dll,9.00.0000.2980
Nero File Source,0x00200000,0,1,NeFileSrc.ax,1.00.0000.0006
Nero DVD Decoder,0x00600000,2,3,NeVideo.ax,1.01.0007.0038
NeroDigital Parser,0x00600000,0,3,NDParser.ax,2.00.0000.0015
AVI Mux,0x00200000,1,0,qcap.dll,6.05.0001.0900
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.0001.0902
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.0001.0902
File Source (URL),0x00400000,0,1,quartz.dll,6.05.0001.0902
WMT DV Extract,0x00200000,1,1,WMM2FILT.dll,2.00.3312.0000
WMT Switch Filter,0x00200000,1,1,WMM2FILT.dll,2.00.3312.0000
WMT Volume,0x00200000,1,1,WMM2FILT.dll,2.00.3312.0000
Nero Video Sample Renderer,0x00200000,1,0,NeRender.ax,1.00.0001.0008
Stretch Video,0x00200000,1,1,WMM2FILT.dll,2.00.3312.0000
Windows Media Pad VU Data Grabber,0x00600000,1,0,wmmfilt.dll,1.01.2427.0001
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.0001.0900
BDA MPEG2 Transport Information Filter,0x00200000,1,0,psisrndr.ax,6.05.0001.0900
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.0001.0902
ShotBoundaryDet,0x00200000,1,1,wmmfilt.dll,1.01.2427.0001
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.0001.0902
Indeo® video 4.4 Decompression Filter,0x0009c400,1,1,,4.51.0016.0003
Indeo® video 4.4 Compression Filter,0x00030d40,1,1,,4.51.0016.0003
WDM Streaming Data Transforms:
Microsoft Kernel Acoustic Echo Canceller,0x00000000,0,0,,
Microsoft Kernel GS Wavetable Synthesizer,0x00200000,1,1,,5.03.0000.0900
Microsoft Kernel DLS Synthesizer,0x00200000,1,1,,5.03.0000.0900
Microsoft Kernel DRM Audio Descrambler,0x00200000,1,1,,5.03.0000.0900
Video Compressors:
WMVideo Encoder DMO,0x00600800,1,1,,
MSScreen encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
WMVideo8 Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.0001.0900
Indeo® video 5.10 Compression Filter,0x00100000,1,1,Ir50_32.dll,5.2562.0015.0055
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.0001.0902
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.0001.0900
Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.0001.0900
Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.0001.0900
Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.05.0001.0900
Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.0001.0900
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.05.0001.0900
Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.0001.0900
Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.0001.0900
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.0001.0900
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.0001.0900
Microsoft Windows Media Video 9,0x00200000,1,1,qcap.dll,6.05.0001.0900
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IAC2,0x00200000,1,1,quartz.dll,6.05.0001.0902
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.0001.0902
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.0001.0902
ACELP.net,0x00200000,1,1,quartz.dll,6.05.0001.0902
DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.0001.0902
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.0001.0902
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.0001.0902
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.0001.0902
Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.0001.0902
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.0001.0902
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.0001.0902
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.0001.0902
Audio Capture Sources:
NVIDIA(R) nForce(TM) Audio,0x00200000,0,0,qcap.dll,6.05.0001.0900
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.0001.0902
Microsoft GS Wavetable SW Synth,0x00200000,1,0,quartz.dll,6.05.0001.0902
NVIDIA(R) DLS Synthesizer,0x00200000,1,0,quartz.dll,6.05.0001.0902
WDM Streaming Capture Devices:
,0x00000000,0,0,,
NVIDIA(R) nForce(TM) Audio,0x00200000,5,5,,5.03.0000.0900
WDM Streaming Rendering Devices:
NVIDIA(R) DLS Synthesizer,0x00200000,1,1,,5.03.0000.0900
NVIDIA(R) Kernel Synthesizer,0x00200000,1,1,,5.03.0000.0900
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.0001.0900
Microsoft DVBC Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.0001.0900
Microsoft DVBS Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.0001.0900
Microsoft DVBT Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.0001.0900
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,1,0,psisrndr.ax,6.05.0001.0900
MPEG-2 Sections and Tables,0x00600000,1,0,mpeg2data.ax,6.05.0001.0900
WDM Streaming Mixer Devices:
Microsoft Kernel Wave Audio Mixer,0x00000000,0,0,,
BDA CP/CA Filters:
Decrypt/Tag,0x00200000,0,0,encdec.dll,6.04.2600.1106
Encrypt/Tag,0x00200000,0,0,encdec.dll,6.04.2600.1106
XDS Codec,0x00200000,0,0,encdec.dll,6.04.2600.1106
Audio Renderers:
NVIDIA(R) nForce(TM) Audio,0x00200000,1,0,quartz.dll,6.05.0001.0902
CyberLink Audio Renderer,0x00200000,1,0,CLADR.ax,5.00.0000.1006
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.0001.0902
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.0001.0902
DirectSound: NVIDIA(R) nForce(TM) Audio,0x00200000,1,0,quartz.dll,6.05.0001.0902
WDM Streaming System Devices:
NVIDIA(R) Kernel Synthesizer,0x00200000,1,0,,5.03.0000.0900
NVIDIA(R) nForce(TM) Audio,0x00200000,14,6,,5.03.0000.0900
AFTER:
System Information
Time of this report: 7/16/2006, 07:17:59
Machine name: ANDRE
Memory: 512MB RAM
Page File: 338MB used, 815MB available
DxDiag Notes
Direct3D: 0/4 (n/a)
Display Devices
Card name: NVIDIA GeForce 6200
Chip type: GeForce 6200
Device Key: EnumPCIVEN_10DE&DEV_0221&SUBSYS_02F1196E&REV_A1
Display Memory: 256.0 MB
Current Mode: 800 x 600 (32 bit) (75Hz)
Driver Version: 6.14.0010.7777 (English)
Driver Date/Size: 7/20/2005 21:07:00, 3908864 bytes
WHQL Logo'd: No
VDD: n/a
Mini VDD Date: 7/20/2005 21:07:00, 3198368 bytes
Device Identifier: {D7B71E3E-4161-11CF-BF64-FB2200C2CB35}
Vendor ID: 0x10DE
Device ID: 0x0221
SubSys ID: 0x02F1196E
Revision ID: 0x00A1
Revision ID: 0x00A1
Video Accel: ModeMPEG2_A ModeMPEG2_B ModeMPEG2_C ModeMPEG2_D ModeWMV9_B ModeWMV9_A
Deinterlace Caps: {212DC724-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{212DC724-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{212DC724-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{212DC724-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
Registry: OK
D3D Status: Enabled
AGP Status: Enabled
Sound Devices
Manufacturer ID: 1
Product ID: 100
Type: WDM
WHQL Logo'd: No
Other Files:
Cap Flags: 0xF5F
HW Memory: 0
Registry: OK
Cap Flags: 0x41
Format Flags: 0xCC0
DirectMusic
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
FF Driver: n/a
Attached: 1
Controller ID: n/a
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Registry: OK
USB Devices
+ USB Root Hub
| Service: usbhub
| | Service: HidUsb
Gameport Devices
PS/2 Devices
| Service: i8042prt
| Service: TermDD
| Service: i8042prt
| Service: TermDD
Registry: OK
DirectPlay Adapters
MS-PCM 64 kbit/s
Drive: C:
Free Space: 130.3 GB
File System: NTFS
Drive: D:
Drive: E:
System Devices
Name: NVIDIA GeForce 6200
Device ID: PCIVEN_10DE&DEV_0221&SUBSYS_02F1196E&REV_A14&1B197270&0&00F0
Driver: C:WIND
klm672
Sun Jul 16, 2006 8:26 pm
Its for Fs9.
filler
filler
pilotdude09
RE: Help - New Graphics Card - Dont See Improvement (Long!)
Mon Jul 17, 2006 12:34 am
 Wow!
Long?? its a flammin novel  Smile
Its most likley to be your processor and ram, Those are the 2 things that need to be upgraded aswell.
Qantas, Still calling Australia Home.........
krisyyz
Mon Jul 17, 2006 1:45 am
While the geforce 6200 is a good card don't expect too much from it.
I would try the following things to improve you FPS.
Make sure that all your setting in the nvidia driver controls are set to the appropriate setting, i.e. anti-aliasing is set to 4,8 or 16 but not on "application controlled". In fs, you can try decreasing the traffic level, limiting visibility or decreasing the display settings. Also make sure the FS has recognized your new card through the DirectX settings.
Quoting KLM672 (Thread starter):
I'd download the newest driver from Nvidia.com, I believe its version 91.31.
I went from a geforce 6800GT to a Radeon X550, and noticed no difference at all in fact, the cheaper Radeon has given me way less problems than before.
If you're on Avsim, check out the discussion forum they have some great tips there has well.
KrisYYZ
pilotdude09
Mon Jul 17, 2006 3:07 am
You need atleast 1gig of ram and you should have a dual core processor or atleast a 3.2 Ghtz processor, this would give you optimum preformance off your new graphics card, done some more research and found that this could really be the only reason.
Because reading bout the card it should runs flight sim smoothly and with out any problems and realtivley good frame rates, but its usually the RAM that kills you!!
jutes85
Mon Jul 17, 2006 5:18 am
I think you need to post your IP address, that would help solving the problem.
nothing
Salomon
Mon Jul 17, 2006 5:44 am
Quoting Jutes85 (Reply 5):
In what way would that help, lol. You want to hack him?
Takeoffs are optional; landings are mandatory.
klm672
Mon Jul 17, 2006 6:46 am
wow good thing you posted that salomon, i was just about to post my IP. Phew, good timing *wink wink*. I was going to buy RAM but the guy at staples couldn't tell what kind of RAM (i printed the same thing I posted here). I heard I could open my computer and look for it, any advice on where to find it?
jetflyer
Mon Jul 17, 2006 7:14 am
Maybe there is some other kind of bottleneck in your system. That sounds most likely. What clock speed is your RAM and also the old Athlon XP processors have slow Front Side Bus speeds so you are better with a Pentium 4 or Athlon 64 with hypertransport than an old Athlon XP processor for FS9. To have graphics cards not making any difference in frame rates shows another bottleneck somewhere, especially having upgraded from intergrated graphics.
[Edited 2006-07-17 00:16:20]
LTU932
Mon Jul 17, 2006 1:15 pm
Quoting Pilotdude09 (Reply 4):
 checkmark
You don't need a dual-core processor to have good performance. A perfect processor for mid-to-high end computers that is not dualcore is the AMD 64 3800+ San Diego, which when not overclocked, runs at 2.2 GHz and gives good performance, provided you have more than enough RAM and a good GPU. I have the 3800+ San Diego in my computer, and combined with 2 GB RAM and a GeForce 6600LE, I get pretty good performance so far.
Just remember: the 3800 on AMD processors to give you an example, means it will run at the same speed as a conventional Intel Pentium IV processor, despite the lower clock speed. This is because AMD processors are more efficient, although Intel is slowly catching up with the philosophy of more efficiency and not necessarily more clock speed.
ZBA320
Wed Jul 19, 2006 5:24 am
www.crucial.com does an automatic memory test on their website to see what type of RAM your computer takes! Crucial Memory is quite cheap I find and the quality it good too.
I got a new Graphics Card (Not state of the art  Wink) a while back, and got 5fps on FS9. I had a fiddle around with the configurations of Smoothing, anti-alising etc. Could fix the problem!
IP address. Never post an IP over a public forum!!
An Engineer made a bet that a 747 Gear wouldn't retract in a Hangar. He lost the bet.
jetflyer
Wed Jul 19, 2006 7:58 am
Quoting LTU932 (Reply 9):
Er, what have u got to lose. Now AMD X2 dual core CPUs cost nearly as little as single cores ones so you might as well get one... and it will be good future proofing it software is converted to take advantage of multi-threadng. I'd recomend a dual core,. I jsut ordered my new computer with dual core YHEAAHH
klm672
Wed Jul 19, 2006 8:21 am
Thanks for all the help, guys! I went out and bought another stick of memory, that did the trick! Thanks again  Smile
EA CO AS
Wed Jul 19, 2006 5:48 pm
Quoting KLM672 (Reply 12):
Just out of curiosity...
1. How much more memory did you buy?
2. What kind of impact did it have on your framerates?
gunsontheroof
Wed Jul 19, 2006 6:19 pm
Quoting EA CO AS (Reply 13):
For what it's worth, I put another 1GB in my computer the other day (bringing it up to 2GB), and it didn't do that much...maybe an extra 10 FPS in most situations. Looks like I'm in the market for a new video card...
EA CO AS
Thu Jul 20, 2006 3:43 am
Quoting Gunsontheroof (Reply 14):
Still, who couldn't use an extra 10 FPS?  bigthumbsup
I've got a PNY Verto Nvidia GeForce 6800GS(overclocked) 256MB GDDR3 PCI Express card, and have 1GB PC3200 DDR SDRAM, and this is on a machine with a P4 HT processor 530 at 3.0ghz, with 1.2MB L2 cache and an 800mhz FSB.
I'm thinking doubling my RAM to 2GB might make a substantial impact, but I'm not sure. Thoughts?
gunsontheroof
Thu Jul 20, 2006 5:46 am
Quoting EA CO AS (Reply 15):
Very true. I'm definetly enjoying the boost, I just don't feel like I'm noticing a performace increase as substantial as when I upgraded from 512mb to 1gb...although that was quite some time ago.
Probably worth the money in the long run, especially if you're planning on getting FSX when it comes out.
Users browsing this forum: No registered users and 9 guests
