AirPacific747
A Flight Logger For FS?
Thu Aug 03, 2006 6:43 pm
Hi,
I am looking for a flight logger with a map that shows the flights that you have done just like with fspassengers, but where I don't have to take care of the passengers. Does anyone know of a program that can do this?
Thankyou in advance!
azza40
RE: A Flight Logger For FS?
Thu Aug 03, 2006 8:08 pm
I've just had a basic search on Avsim, and not found anything. I will have a more in depth look around the internet later today.
Aaron  swirl
Not been on here for a good 2/3 years!
jamesbuk
Thu Aug 03, 2006 8:58 pm
Couldnt you use the great circler map and just add the legs in when you do them?
Rgds --James--
P.s. the big three at it again lol
You cant have your cake and eat it... What the hells the point in having it then!!!
AirPacific747
Thu Aug 03, 2006 9:05 pm
Quoting Jamesbuk (Reply 2):
Not the same  Wink
Interpaul
Thu Aug 03, 2006 9:55 pm
AirPacific747
Thu Aug 03, 2006 10:08 pm
Quoting Interpaul (Reply 4):
Have you tried FS Flight Keeper ?
Awesome!!! Thanks a lot!
Damn, you've covered a lot!!!
[Edited 2006-08-03 15:12:04]
AirPacific747
Thu Aug 03, 2006 11:30 pm
btw does it register your flight automatically or do you have to type it in manually?
Interpaul
Fri Aug 04, 2006 1:20 am
At the beginning of your flight you connect to FS and check if the FS flightplan is properly recognized. After the flight it disconnects automatically and gives you a rating for the flight. All the waypoints, callsign, altitudes etc are imported automatically from FS if you start a flight.
Jan
AirPacific747
Fri Aug 04, 2006 1:36 am
Quoting Interpaul (Reply 7):
Very cool! And I noticed that on your map, it seems like it plots in the actual route that you flew, rather than just making the shortest line between the two points
Interpaul
Fri Aug 04, 2006 1:41 am
Quoting AirPacific747 (Reply 8):
It even plots the mad turns when you nearly get lost on the polar route from HKG to JFK as you can see on my map.  Wink
Jan
AirPacific747
Fri Aug 04, 2006 2:03 am
Quoting Interpaul (Reply 9):
Hahaha Big grin
Thank you for your help! This was exactly what I was looking for! It makes fs a lot more fun when you can actually see all the work you have done afterwards
AirPacific747
Fri Aug 04, 2006 2:59 am
I have a problem with installing that acars device though. It says that "the aircraft doesn't have a hotspot for the acars device and asks me if I want to correct it. I click "yes" and nothing happens. I have tried both with default aircraft and add-on aircraft.
Are you able to help me?
Interpaul
Fri Aug 04, 2006 3:29 am
Haven't tried the ACARS thing yet, so I can't really help you on that.
Jan
AirPacific747
Fri Aug 04, 2006 3:38 am
Quoting Interpaul (Reply 12):
Okay but how does it register your flight then?
Interpaul
Fri Aug 04, 2006 3:39 am
It's all done via that FSUIPC.DLL in the modules folder of FS.
AirPacific747
Fri Aug 04, 2006 3:51 am
Quoting Interpaul (Reply 14):
How do I activate it?
AirPacific747
Fri Aug 04, 2006 4:28 am
I think I found out. Thankyou for the help!
jamesbuk
Fri Aug 04, 2006 8:06 am
Is there a trial version? if so what impendmants are there? also how much does it cost?
Rgds --James--
AirPacific747
Fri Aug 04, 2006 8:41 am
Quoting Jamesbuk (Reply 17):
Yes there is a trial version. Dont know what is included in it though.
www.flightkeeper.net for more information
jamesbuk
Fri Aug 04, 2006 8:47 am
Quoting AirPacific747 (Reply 18):
Thanks for the link  Wink
Rgds --James--
AirPacific747
Fri Aug 04, 2006 9:00 am
Quoting Jamesbuk (Reply 19):
Thanks for the link
No prob  Wink
