usair320
Help! PC Turnoff In The Middle Of FS.
Thu Aug 24, 2006 1:38 pm
My Computor will with no warning just turn off in the middle of FS. What is this? it dosent do this on the internet just FS. Has this happended to you? is there anything I can do about this? replys greatly appresiated.
nighthawk
RE: Help! PC Turnoff In The Middle Of FS.
Thu Aug 24, 2006 4:26 pm
Sounds like a heat issue: Flightsim puts a heavy load on your machine, causing all the parts to generate a lot of heat. If a component reaches its maximum temperature the PC will turn itself off to prevent damage.
Check all the fans inside are working properly, and add some extra ones if need be.
justplanecrazy
Thu Aug 24, 2006 5:57 pm
do you get an error message when the pc restarts?Try taking the cover of the pc to keep the tower cool this worked for me.
your pilots today on this 747 flight are captain oliver hardy and assisting will be FO stan laurel.Have a safe flight
woady
Fri Aug 25, 2006 7:17 am
It's not necessarily a heat issue... my computer kept restarting randomly on flight sim, turned out to be one of my sticks of memory- one was labeled incorrectly as PC3200 when it is actually PC2700 grrrrr.
Woady
A300-600R, 737-300, 737-800, 757-200, 767-200/300/ER, ERJ145, ATR72
