jamesbuk
Help With Afcad, Buildings In The Way!
Tue Sep 05, 2006 8:51 pm
Hi guys and gals,
I was extending and building an airport with AFcad 2.21 and when i went to fly it therre were buildings in the way, how do i remove them? also how can i build terminal buildings?
Thanks in advance
Rgds --James--
You cant have your cake and eat it... What the hells the point in having it then!!!
BAW076
RE: Help With Afcad, Buildings In The Way!
Tue Sep 05, 2006 8:59 pm
You can't remove or add buildings using AFCAD.
AFCAD is merely aircraft parking, runways, taxiways, lights, etc. Not buildings.
N754AN (x2), G-CPEL, G-MIDE, G-BPEC, G-BZHC, EI-DCH, LN-KKN, G-VIIW, G-BNLT, G-DBCA, G-MEDE, G-DBCE, G-MIDP.
jamesbuk
Tue Sep 05, 2006 9:11 pm
Quoting BAW076 (Reply 1):
Ok so how can i get rid of them? and how can i build terminals and other stuff?
Rgds --James--
BAW076
Tue Sep 05, 2006 10:03 pm
Quoting Jamesbuk (Reply 2):
I have absolutely no idea lol!
Gotta be someone here who knows though!
Ari
Tue Sep 05, 2006 10:28 pm
Dunno how to get rid of buildings but i think there's a program called "rwy12" or something which allows you to add scernery including buildings
aRi
QFA380
Wed Sep 06, 2006 7:31 pm
Where do you get the program from that makes the AFCAD's? And does it cost anything?
David L
Wed Sep 06, 2006 8:04 pm
Quoting QFA380 (Reply 5):
Free from:
http://library.avsim.net
http://www.flightsim.com
Filename: afcad221.zip
Version 2.21 only works with FS9, you need version 1.4 for FS2002.
JohnKrist
Crew
Wed Sep 06, 2006 8:38 pm
To get rid of buildings, roads, autogen of different kinds you have to do an exclude switch. There is an xml file if I remember correctly, there you can enter the coordinates for the area and what you want to exclude.
IIRC the way to get the coordinates is to use a square where you take the point of the upper left corner and the bottom right. I'll have to research that a bit more, I am at work right now, but you can search some by yourself too using the above info  Smile
Airliners.net Crew-Head Support
5D Mark III, 7D, 17-40 F4 L, 70-200 F2.8 L IS, EF 1.4x II, EF 2x III, SPEEDLITE 600EX-RT
JohnKrist
Crew
Wed Sep 06, 2006 8:44 pm
Did a quick search on Avsim and some nice person has made an app to aid in making exclude switches, search for ExcBuilder Version 2.0
David L
Wed Sep 06, 2006 9:59 pm
Quoting JohnKrist (Reply 8):
Excellent. I had a go at making a version of Sek Kong airstrip in Hong Kong as it was in the 1970s but there were trees all over the apron and in the hangars. I lost interest after trying to learn about exclude files. I might revisit that now.  Smile
GAIsweetGAI
Thu Sep 07, 2006 10:25 am
There's a program called FS Scenery Creator that allows you to flatten the ground and get rid of buildings. Works with FS2002 and FS2004.
"There is an art, or rather a knack to flying. The knack lies in learning how to throw yourself at the ground and miss."
