pjflysfast
Pmdg 747-400 Problems
Fri Sep 15, 2006 4:47 am
I recently bought PMDG's 747 and flew it at the most 6 times. Then the Overhead panel wont work and neither will the throttle quadrant. Any ideas on how to fix it would be greatly appreciated!
David L
RE: Pmdg 747-400 Problems
Fri Sep 15, 2006 10:13 pm
Are you using the panel selector or the keyboard (or both) to try to select those panels? If the problem only exists when you use the keyboard, perhaps you need to look at the keyboard assignments in the PMDG menu.
David L
Sun Sep 17, 2006 8:32 am
Did you just give up on those panels?
pjflysfast
Sun Sep 17, 2006 10:52 pm
I fixed it, turns out you have to have all the firewalls and spy sweepers turned off when you download it.
David L
Mon Sep 18, 2006 12:39 am
Hmm... funny how some bits of it get through and not others. I only disabled my anti-virus software as I installed it, that's all.
 confused
pjflysfast
Mon Sep 18, 2006 4:23 am
It took me a little while to figure that out!  crazy
