GAIsweetGAI
Fokker 50 Panel Project Trouble
Fri Sep 22, 2006 9:31 am
I can't get the engines to start and run!
How do I do that?
Or are there other Fokker 50 panels out there?
"There is an art, or rather a knack to flying. The knack lies in learning how to throw yourself at the ground and miss."
PAHS200
RE: Fokker 50 Panel Project Trouble
Mon Oct 02, 2006 10:30 am
try ctrl E
or
can you please post a link to were you got the panel from because there are many panels you can have.
hope it helps
michael
GAIsweetGAI
Mon Oct 02, 2006 10:51 am
Link to the panel:
http://www.fokker50.com/download.htm
Scroll all the way to the bottom to get the FS2004-compatible version.
And ctrl E was one of the first things I tried.
edit: Maybe I should mention that the Fokker 50 is the Dreamwings model.
[Edited 2006-10-02 03:53:23]
Arniepie
Tue Oct 03, 2006 9:23 pm
Check that the fuel valves are open on the pedestal, on the overhead panel open the fuel valves and don't forget to switch on the electrics.
When starting up put the valves on the ped. in the first position up and when the engine reaches the necessary level(EGT I believe) than put the valves fully up.
READ THE MANUAL for finding out the correct values!!!
[edit post]
Chey2748
Fri Apr 24, 2009 11:50 am
I have been experiecing the same problems with this panel. Every time the engine 2 is started, with the strobelights on, the panel starts flickering, shortly after, flight sim just crashes! I have no explaination, I have tried all the fixes, except for the reconfiguration in the fs9.config file, not the main Flight Sim file, I can't find this file. I also have the Virtualcol Fokker 50, and genrally experience simular issues with not being able to change radio frequencies, autopilot not being able to activate it, etc.
Has anyone identified the cause and has anyone come up with a fix for this program, or does anyone know of another Fokker 50 panel?
Users browsing this forum: No registered users and 9 guests
