AirPacific747
Question Regarding CPUs & FSX
Wed Oct 25, 2006 4:08 am
I'm looking at different CPUs trying to compare their specs.
I'd like to know how big the difference is between these two processors:
Intel Core 2 Duo (Conroe) E6600, 2,4GHz, EMT64, 4MB, LGA775
and
Intel Core 2 Duo (Conroe) E6700, 2,67GHz, EMT64, 4MB, LGA775
Would the 0,27ghz mean a lot of difference if used with FSX?
Sorry I'm a bit of a noob when it comes to this kind of thing :P
AirPacific747
RE: Question Regarding CPUs & FSX
Wed Oct 25, 2006 4:12 am
I should add that the price tags on those two CPUs are very different.. that's why i'm wondering. The 2,67ghz processor is almost double the price
Qantas744er
Wed Oct 25, 2006 4:39 am
Hey, i would not recomend you getting a dual core processor...
the reason: Dual Core only works with programs that have been written for dual threading. And sadly FSX is not capable of doing this yet but they have stated a patch will be released in a year or so with vista coming out.
And using dual core on a non dual core prog. can make it run even slower than normal.
Again my mothers friend works for a pc magazine and I get a lot of info. from him,
so for now i would stick with a normal CPU look at some Pentium 4 or AMD processor!
Cheers Leo
You live and you die, by the FMA
AirPacific747
Wed Oct 25, 2006 5:23 am
Quoting Qantas744ER (Reply 2):
Thanks for the advice!
I am just wondering what will make fsx run smoothly then.. My graphicscard is one of the best you can get at the moment and I have 2gb of ram..
my processor is a 3,2 ghz pentium 4 processor.
greaser
Wed Oct 25, 2006 11:18 am
Correct me if im wrong but i heard that the chip makers really screwed up the the whole ghz speed thing, and that now a 2.67 ( as noted above) is not the equivialent of a 2.67 we're used to, and that Intel's chips while having a higher displayed clock speed don't actually perform higher than comparable AMD chips.
Now you're really flying
nighthawk
Wed Oct 25, 2006 5:11 pm
Quoting Greaser (Reply 4):
Measuring a processors speed in Ghz/Mhz has always been a bad way of doing it, however there is not really a better way of doing it, so its continued to be used. When referring to a processors "speed", you are talking about the number of cycles a processor can perform per second (mhz / ghz). Given that each processors can perform a different number of tasks per cycle, this figure is an unreliable measure.
Take for example AMD chips, as you suggest. AMD chips are normally quoted as being "3200+", the Ghz/Mhz is never mentioned. The reason being that this processor infact performs just 2,800mhz, however as the processor can perform more instructions per cycle, it is roughly equivelent to a pentium running at 3.2ghz.
Now that we are moving into dual and even quad core processors, the ghz speed is even less reliable. A 3ghz quad core processor can perform 4 times as many instructions per cycle as a single core processor, however ONLY if the application has been written to take advantage of dual/quad cores.
An alternative measurement is MIPS (milions of instructions persecond) however even this has issues and is not an accurate reflection of a processors speed.
Processors are very complicated things, and there is no easy way to measure and compare their peformance.
goinv
Wed Oct 25, 2006 8:04 pm
My understanding of Dual Core processors was that they can handle two different applications at once.
So, for example, my AMD Athlon 64 3000+ needs to run FS, Anti-Virus and whatever else is running in the background.
With a dual core processor, wouldn't one core look after FS (meaning the full processing power of a single processor is available) whilst the other core could run my anti-virus software?
Am I right, reading the comments in this post that, with a dual core processor, a single core would still run FS and AV etc whilst the other core remains static ?
Be who you are, The world was made to measure for your smile. So Smile.
N231YE
Thu Oct 26, 2006 2:41 am
I was informed that only the Deluxe version will be capable of running Dual-Core, and only with Vista. Is this true?
Qantas744er
Thu Oct 26, 2006 4:02 am
Quoting N231YE (Reply 7):
Almost right  Smile'
All FSX versions will be able to run Dual Core once the patch is out.
Once vista in out january-feb. 07 then we can expect the dual core patch
along with a good range of DX10 cards. And yes I know the Nvidia Geforce 8000 is coming in nov. 06 but it is the first DX10 card and is not all too stable yet.
Regarding the Dual Core etc. i got some more information from my mothers friend.
The dual core is capable of operating two programms better of course, so
FS and an Anti virus for example with more ease. But! it will not be able to use all of its processing speed. So all programms will run slower with dual core if they were not made for dual core and the only advantage it has is that the processor uses about 5% less in processing power to do 2 programms but will not operate faster than a pentium 4 3,4Ghz.
Quoting AirPacific747 (Reply 3):
I am just wondering what will make fsx run smoothly then.. My graphicscard is one of the best you can get at the moment and I have 2gb of ram..my processor is a 3,2 ghz pentium 4 processor.
That is another thing with FSX!
The problem again is that FSX is programmed for Vista and will only run perfectly on Vista so its not your system specs. but windows XP! So there is no need to worry and once Vista is out you will be able to use you PC with full power.
AirPacific747
Thu Oct 26, 2006 4:58 am
Quoting Qantas744ER (Reply 8):
Thanks that comment saved my day Big grin
malaysia
Thu Oct 26, 2006 11:50 am
You can change the program affinity to have it run on which CPU you decide or just use either. Its kind of hard for me to set affinity cause I honestly disable viruscan and other programs when I play games. I have a NAT firewall so I am not affected security issues when playing games online with no background tasks running. so I wont bother with affinity settings, but
I need to wait for Vista.
I wish the dual-core patch would be allowed for even Windows XP 64Bit which
I am using now.
There Are Those Who Believe That There May Yet Be Other Airlines Who Even Now Fight To Survive Beyond The Heavens
Qantas744er
Thu Oct 26, 2006 8:35 pm
Quoting Malaysia (Reply 10):
I am using now.
Yup.. sucks! i use the XP64bit SP2 and thats why I stayed with a pentium 4 with 3,4GHz 4GB RAM and my new Dual Nvidia Geforce 7960 with 1Gb memory each.
They only thing FSX now operates compared to FS9 is when you have dual cards with SLI Antialising SLI 8x and SLI 16x
Cheers Leo
sv2008
Fri Oct 27, 2006 5:25 am
The problem again is that FSX is programmed for Vista and will only run perfectly on Vista so its not your system specs. but windows NEW: Xtra Airways (USA) and OLD: Casino Express (USA)">XP! So there is no need to worry and once Vista is out you will be able to use you PC with full power.
unfortunatly this is a myth and completly wrong.
- Vista will likely slow the game down on the same (any given) hardware because it uses more resources.
- FSX might be optimised for Vista and DX10 but this means I think nicer graphics, not improved FPS (although a small improvement might be possible).
It will run faster on Vista BUT ONLY WITH NEW DX10 HARDWARE (Video card and faster CPU). You are unlikely to see any improvement on your existing (DX9) hardware.
Remember the main reason it'll run faster with DX10 is that DX10 cards are simply newer and faster than DX9 cards! it has minimal to do with Vista.
This is one exception to all this - if you have bought a DX10 card but using it with NEW: Xtra Airways (USA) and OLD: Casino Express (USA)">XP, and you then upgrade to Vista, you will probably see a small but noticeable improvement.
I think people who install Vista on their existing hardware and expect it to run better are going to be very dissapointed.
I don't dislike Vista - but it's a next generation of OS for a next gen of hardware that dosn't really exist yet.
I
Qantas744er
Sat Oct 28, 2006 12:32 am
Quoting Sv2008 (Reply 12):
I cant fully agree on that, because all that SLI stuff and dual core is not capable of operating on FSX yet until the patch comes out. So the FPS will get better with vista and DX 10 cards.
And FSX will be able to be used at full power once Vista is out because it will run smoother. Correct that Vista runs on more resources but Vista in quicker as a operating system operating a lot better.
Cheers Leo
sv2008
Sat Oct 28, 2006 2:11 am
Quoting Qantas744ER (Reply 13):
XP supports SLi so it's not Vista thats adding that feature, and FSX dosn't support dual core either. Again it's the game that needs patching.
Some versions of XP (not many) already supprot Dual core but the game won't use it without a patch.
It will get better with DX10 cards but mainly because the Dx10 cards are more powerful hardware.
Remember, lots of people will upgrade to Vista with Dx9 cards expecting miracles with the FPS. Vista will have the features but the card won't support them.
If you upgrade to a DX10 card of course then they'll be an improvement.
Well just MS have said this. I think what they really mean is that "with Vista, with Dx10, With a Dx10 video card, with a powerful modern CPU, the game will run better".
Not the same as running better on older hardware! The reason I won't upgrade my current system to Vista.
As for Vista running quicker.........I'll believe it when I see it. Again I think it'll be heavily hardware dependant on if it runs quicker or not. Of course it'll run quicker on newer hardware.
Many people have upgraded recently but many haven't.
[Edited 2006-10-27 19:14:50]
sean377
Sat Oct 28, 2006 2:55 am
I agree with what sv2008 is trying (without much success) to say. The PC you are running XP and FSX on right now, will not run FSX any better if you upgrade that same PC to Vista.
Flying is the second greatest thrill known to man... Landing is the first!
Kovi17
Sat Oct 28, 2006 2:58 am
Im running with a intel dual core and its working just fine....
We dont worry about small things like that...
nycfly75
Sat Oct 28, 2006 3:38 am
I said this in another thread, but its more valid in this one:
Well, I may be doing a FS first, installing it on a dual core mac. I put windows xp pro (nervously) on my mac using the bootcamp feature. I must tell you, it works like a charm. I put FS2004 and maxed everything out and it works better than when I had my dual core Dell XPS (Weird huh?). Im wondering if I should invest in FSX. So yes, you can run FS on a Mac, even though its on a partition with Windows XP on it.
Config: (on the XP partition)
New 20" Imac with
2.16 ghz Intel Core 2 Duo
1 GB 667 MHZ SDRAM (soon upgrading to 2 gig)
ATI Radeon X1600 PCI 128mb
As I said FS2004 works perfectly maxed out on here, I would like input about putting FSX on Thanks!
sv2008
Sat Oct 28, 2006 3:43 am
About the FPs generally, FSX is a detailed game, but it runs worse than it should really on lower settings.
Some things like autogen really hurt the FPS. MS might yet release a patch to improve things.
goinv
Sat Oct 28, 2006 3:24 pm
I looked at a retail box of FSX yesterday - although I'm waiting for xmas to get it as a present.
It was interesting to see that Microsoft had but the Inbel Core Duo Extreme logo on the back.
Do you think that this is the processor that we should aspire to have for FS - albeitt at something like four times the price of most other processors (£650 here in the UK) ?
sv2008
Sat Oct 28, 2006 6:17 pm
No, MS just have marketing deals with intel probably, it dosn't mean much, although they'd like you to think so of course so you buy it!
AMD has a reputation for being better CPU for games anyway (although everyone has a favourite brand, either intel or AMD, or Nvidia or ATi).
dreamer
Sun Oct 29, 2006 7:33 am
At this point in time no AMD can compare to Intels latest chips in performance ( read one article her http://www.extremetech.com/article2/0,1697,1988799,00.asp )
or here from zdnet http://blogs.zdnet.com/Ou/?p=240
Also saying that the speed of the chip is the way to look at performance is totally wrong, to understand why it is so, read up on the technology at the page listed above. Going back to the thread starter where he is talking about core2duo, well, right now it is the best you can get and will beat AMD.
Testing at many different sites proves this hands down, see a list of comments from sites like Tomshardware and the rest of the gang http://www.intel.com/personal/our-te...duo/quotes.htm?iid=ptab+c2dquotes.
Maybe AMD can deliver more later, but now (somehow) intels latest chips rock and use less power and create less heat.
[Edited 2006-10-29 00:57:58]
still dreaming after all these years
PSAjet17
Wed Nov 01, 2006 12:03 pm
I have not heard one word that Microsoft is working on a "patch" to make FSX work with multi-processor systems. One of the ACES designers (tdragger)has tried to explain this a number of times in the discussion groups on sites like Avsim. He explains that the entire core of the application would have to be re written to fully take advantage of multiple processors...something that did not happen with FSX (and Vista will not fix this).
Applications like FSX require multiple threads running differing parts of the system. One thread might control your aircraft, another the weather, and another the AI aircraft around you. All of these thread may have to communicate with each other to exchange data that is then utilized in that thread such as the AI thread telling the your aircraft thread where the planes are so they can be visually seen by you when you look out the cockpit window.
If thread are spread across two or more CPUs, there will be times that CPU 1 will have to wait for data from CPU 2 and you know what that means to your smooth flying aircraft.
Please read tdragger's The Last Word on Dual Core in his blog at:
tdragger's blog
David L
Wed Nov 01, 2006 9:17 pm
Quoting PSAjet17 (Reply 22):
Neither have I, only a Vista "patch". If I've said otherwise it's just because I got swept along in the discussion but I'm still not convinced a dual-core processor won't make any difference to FSX. I still think having background tasks taking advantage of dual-core has to help a bit, even if FSX is restricted to one core.
Gofly
Wed Nov 01, 2006 9:55 pm
So should I not even think about throwing the Core 2 Quatro QX6700 2.67GHz Quad Core (which is out at the end of this month) into the equation?  Wink
Living the high life on my ex-Airliners.net Moderator pension...
David L
Wed Nov 01, 2006 10:19 pm
Quoting Gofly (Reply 24):
Oh, I think you should... if only for our entertainment.  Smile
dreamer
Wed Nov 01, 2006 10:34 pm
Quoting David L (Reply 23):
Absolutely, of course it will help. Are you also running other stuff, squakbox,vatsim, if so it will help, pluss everything else that runs on your system still needs to run.
Pluss as earlier mentioned, the Core technology is very advanced, we are finally seeing mainframe-style chips in a PC. Pluss also as I have said before, the Core outperformes anything else in the marked right now, so even in a single core it would be a top chip.
Also there are tests of fsx on a core2duo and it rocks
Gofly
Wed Nov 01, 2006 11:38 pm
