AirPacific747
Highest FPS Ever Recorded In FS9? :D
Fri Nov 03, 2006 12:16 am
So I just removed the limiter for fun to see how high my fps would go.. does anyone get a similar fps?
Big version: Width: 1280 Height: 1024 File size: 71kb
[Edited 2006-11-02 16:18:39]
ajd1992
RE: Highest FPS Ever Recorded In FS9? :D
Fri Nov 03, 2006 3:49 am
I've had mine upto about 120 - that was with no antivirus, no MSN, no portable firefox... just FS2002 (as it was at the time, i'm now on FS2004. I haven't checked on FS2004). To be honest, it's not something i wanna do often, having no antivirus. Usually, i average about 30-50 flying, at bigger airports with AI at it's highest, plus with some added AI (can't remember the name of the program, damn it..) i get 20 or so. Pretty good for a system that's coming up on 2 years old (granted, it's had a gig of RAM, 120GB HDD added to it's original 40GB (!!) one.)
AirPacific747
Fri Nov 03, 2006 3:55 am
Quoting Ajd1992 (Reply 1):
What does that have to do with your fps?
Anyway I usually have my fps locked at 30. more fps isn't needed.
Cadet57
Fri Nov 03, 2006 5:06 am
Quoting AirPacific747 (Reply 2):
Runs in the background, therefore taking system resources away from FS9 therefore slowing it down.
jamesbuk
Fri Nov 03, 2006 5:20 am
chris, BAW076 has a high spec PC and with everything at full, gets over 100 FPS, he'd easily get 300 with everything off.
Havent tried mine as of yet, will do soon though.
Rgds --James--
You cant have your cake and eat it... What the hells the point in having it then!!!
AirPacific747
Fri Nov 03, 2006 5:38 am
Quoting Cadet57 (Reply 3):
Ah thats why...  Smile
Quoting Jamesbuk (Reply 4):
Well my settings were set to max.. all of them. It doesn't really matter though if you're looking against the sky.. it'll do a lot to your framerates  Smile
san747
Fri Nov 03, 2006 11:15 am
I've hit 200 FPS on several occasions...
Scotty doesn't know...
Evan767
Fri Nov 03, 2006 12:26 pm
Im lucky to get 10 FPS in the air and about 5 on the ground. You guys are spoiled.
Cessna057
Fri Nov 03, 2006 12:51 pm
i get 100-125 on the ground and 150-160 in the air.
Hold it . . . Hold it . . . HOLD THE FREAKIN NOSE UP!!
malaysia
Fri Nov 03, 2006 1:44 pm
I get 250 over the grand canyon  Smile with all sliders maxed in FS2004, but only 10-15 with FSX with all sliders also maxed even autogen too
There Are Those Who Believe That There May Yet Be Other Airlines Who Even Now Fight To Survive Beyond The Heavens
BAW076
Fri Nov 03, 2006 5:37 pm
Rgds --James--
Signed,
Me
N754AN (x2), G-CPEL, G-MIDE, G-BPEC, G-BZHC, EI-DCH, LN-KKN, G-VIIW, G-BNLT, G-DBCA, G-MEDE, G-DBCE, G-MIDP.
malaysia
Sat Nov 04, 2006 12:55 am
We need screenies of highest fPS over a terrain. thats a better thing to see. The open sky is always the highest FPS to have.
sadly I can only get 30-45 FPS in the sky in FSX haha, but 2XX in FS9
COERJ145
Sat Nov 04, 2006 5:55 am
How do you guys get the red info text?
jamesbuk
Sat Nov 04, 2006 6:56 am
When flight sim is open (like when your flying, or on the ground) press Shift + z 2 or 3 times.
Rgds --James--
BMIFlyer
Sat Nov 04, 2006 9:29 pm
I'll be getting a new PC in the new year, so i'll let you know then Big grin
Lee
AirPacific747
Sun Nov 05, 2006 7:06 am
Quoting BMIFlyer (Reply 14):
Cool!  bigthumbsup
You should make sure that it will be able to run FSX as well! My pc is struggling with it despite of the excellent fps that I get in fs9
jamesbuk
Sun Nov 05, 2006 8:10 am
Quoting AirPacific747 (Reply 15):
Problem is no one will really know how to make FSX run as well as FS9 does on modern pcs at the minute.
I loaded up flight simulator earlier and was hitting 180-190FPS with a default Md83 (trying to get it to work for someone) and then hit 150FPS with the PSS777
Rgds --James--
Avsfan
Mon Nov 06, 2006 6:44 am
Nice to see the stats that everyone is getting with FS9, but the real question is....what are the specs for each of your computers? If you have a top of the line CPU with High-end dual PCI Express videos cards, then you will get high FPS. If someone is still running a low-end CPU and video card, then they will suffer with FPS. Lets see those computer specs to go along with mentioning FPS.
"Oh I have slipped the surly bonds of Earth...Put out my hand and touched the face of God"
JohnKrist
Head Support
Sat Nov 11, 2006 6:34 am
I usually get around 15 fps at dense airports like LAX, 30-50 fps at CPH and 50+ in some sandy desert in Angola Big grin
I run FS on a clean stripped down Windows XP with PC-Cillin as only stuff not FS related, meaning that I have 2 separate XP installs on one computer.
Specs as follows:
P4 3.2GHz 800FSB
2x512 DDR400 in dual channel
2x80GB 8MB cache 7200rpm WD HDD in RAID
ASUS Ti4400 Ultra (oldest thing in my rig)
5D Mark III, 7D, 17-40 F4 L, 70-200 F2.8 L IS II, 50mm 1.4, EF 1.4x II, EF 2x III, SPEEDLITE 600EX-RT
JohnKrist
Head Support
Sat Nov 11, 2006 6:35 am
Oh, I forgot, highest fps recorded was around 350 IIRC at 30.000 feet looking up on a clear sky  Smile
AirPacific747
Sat Nov 11, 2006 6:49 am
My specs are:
3,2GHz Pentium 4 processor
2x1024mb ddr400
250gb 7200rpm SATA HDD
Nvidia Geforce 7950GT graphicscard with 512mb ddr
malaysia
Sun Nov 12, 2006 9:39 am
Quoting AirPacific747 (Reply 20):
2x1024mb ddr400
Same as me except I am on RAID 0 with 2 7200RPM 200GB SATA II drives to make 400GB
and I have an AMD Athlon 64 X2 4400+ CPU.
Cessna057
Mon Nov 13, 2006 1:32 am
It looks like i apparently get really high FPS for my specs...150 in the air and 110-115 on the ground and these are my specs:
1.6 Pentium M
2x256 ram
40 GIG HDD
ATI radeon mobility
jamesbuk
Mon Nov 13, 2006 3:13 am
Quoting Cessna057 (Reply 22):
Fair enough but what are your settings? if we all ran Ultra low graphics anyone would hit that.
I also forgot to mention im running visual settings mostly at 80% and running AI during flight at 100% and approaching a big airport (to land) about 60%.
Rgds --James--
Cessna057
Mon Nov 13, 2006 9:23 am
Quoting Jamesbuk (Reply 23):
I run pretty high stats on everything...Ultra high scenery, blah blah blah
Avsfan
Mon Nov 13, 2006 2:13 pm
1.6 Pentium M
2x256 ram
40 GIG HDD
ATI radeon mobility
Quoting Cessna057 (Reply 24):
Something does not seem right here, these are my specs and I am lucky to average 20 FPS. I run my FS9 with all settings maxed out except AI traffic which is set for 75%. My add-on scenery programs include "Birds Eye View", "Real Environment Pro" and other freeware scenery mesh.
    * Gigabyte GA-K8NSC-939 Motherboard
    * AMD Athlon(TM) 64 3500+ Processor
    * 4x512 MB Kingston 400 MHz DDR PC3200 DIMM 3-3-3 RAM
    * 160Gb & 300Gb Seagate Barracuda 7200.7 Serial ATA HDDs
    * 128Mb eVGA 6600GT nVidia geForce AGP 8x Video Card
How much add-on scenery and what type of AI traffic do you use?
Louis
ZKSUJ
Tue Nov 14, 2006 5:44 pm
In the other thread in the Hobby forum, note that QANTAS744ER runs up to 361 FPS on FSX with max scenery settings. Just imagine the FPS he could get on FS9 with that.  Wow!
Cessna057
Fri Nov 17, 2006 10:48 am
Quoting Avsfan (Reply 25):
I dont have any addons except one 737-900ER and a CO meljet 777....My AI is on 65% and after readingthis thread I'm not really sure whats up either. I dont have much else on my computer though...
