wilco737
Pmdg Problems... Who Can Help?
Fri Nov 17, 2006 4:18 pm
Hello guys,
I am using my PMDG 744 very often and do loads of flights with it.
Yesterday I did a nice flight from VHHH back to EDDF and everything went just fine.
I left home for 3 hours or so, then when I came back home I wanted to do another PMDG 744 flight. So, I set up the passengers and fuel and cargo and entered the cockpit.
I prepared the aircraft as usual, like I do everytime. Programmed the FMC and then taxied to the runway.
Take off, lift off, gear up! LNAV VNAV engage and I flew manually up to about 1500 feet, then I engaged the Center Autopilot and then the trouble begins!
The autopilot followed the LNAV track BUT not the VNAV path... It just continued to pitch up to 30° nose up!!! So I disengaged the A/P and corrected it myself and then reengaged the A/P! Same result! Pitch up to 25°! Same happens when I use different pitch modes like LVL CHG or V/S... Always pitching up right into the stall...
I removed PMDG744 from my HDD and reinstalled it... Same problem! Nothin has changed... I dont know whats going on...  Sad
I cannot use PMDG anymore at the moment! I am not flying EDDF-KSFO manually all the time...
Anyone knows what was going on here?
Aircraft is within CG limits and operational limits!
WILCO737
 airplane
Pilot3033
RE: Pmdg Problems... Who Can Help?
Sat Nov 18, 2006 2:54 am
Did you program the FMC correctly?
Check to make sure the weights and speeds are entered correctly.
If that's not it, contact PMDG.
-Matt
Gofly
Sat Nov 18, 2006 3:44 am
Quoting Pilot3033 (Reply 1):
I have a funny feeling Phil is fairly competent with FMCs  Wink  silly
I'm honestly not sure what the problem is, but it's probably worth taking a look at the PMDG forum to see if any similar problems have been reported.
-Gofly
Living the high life on my ex-Airliners.net Moderator pension...
wilco737
Sat Nov 18, 2006 4:18 am
Quoting Gofly (Reply 2):
-Gofly
Well, I guess the FMC is programmed problerly... Correct weights and speeds...
I found the mistake today! It was my joystick! I calibrated it the other day! Must've gone something wrong... So, the joystick always inted to PULL UP and did it! but not enough to make the A/P disengage! So I recalibrated it and now it is working fine again...
So, it wasnt PMDGs fault it was the joysticks Big grin
WILCO73
 airplane
David L
Sat Nov 18, 2006 8:06 am
That was going to be my first response, since most PMDG problems are caused by newbies wanting to fly without "reading the instructions". Then I saw who was asking so I kept my mouth shut.  Smile
Pilot3033
Sat Nov 18, 2006 8:52 am
Quoting David L (Reply 4):
I'm an a.net noob, forgive me  Silly
Quoting WILCO737 (Reply 3):
I had a similar problem, I can't believe I forget about it.
-Matt
-Matt
David L
Sat Nov 18, 2006 8:11 pm
Quoting Pilot3033 (Reply 5):
No problem. I wasn't so much having a go at you as just finding the situation amusing. Sorry!  Smile
