AirPacific747
Question Regarding Multiple Engine Control In Fs
Sun Nov 19, 2006 1:33 am
Hi, I sometimes have a problem with the throttle after having used the autothrottle. Sometimes it'll only let me control one engine with my joystick, and then I have to manually control the other engine with my mouse.
Is there a way to start controlling both or all the engines again at the same time?
dogfighter2111
RE: Question Regarding Multiple Engine Control In Fs
Sun Nov 19, 2006 2:53 am
Heya,
If when this happens you hold down:
E + 1 + 2
(If you are using a 2 engine jet, for a 3 engine add + 3 etc.)
You must do it pretty quickly.
Mike
AirPacific747
Sun Nov 19, 2006 3:47 am
Quoting Dogfighter2111 (Reply 1):
Heya,
E + 1 + 2
Hey! Thank you so much!
That'll save me a lot of hassle.
dogfighter2111
Sun Nov 19, 2006 4:04 am
Quoting AirPacific747 (Reply 2):
Hey, no problem mate. Happy flying!
Mike
noelg
Sun Nov 19, 2006 4:09 am
I often find this doesn't work unless you pause for a few seconds between each press, even then it can take a few goes.
If you have a full copy of FSUIPC you can assign a key combination to "Take control of all engines". I just assign Ctrl+Shift+E and all I have to do is hit that to take over all engines!
Noel
AirPacific747
Mon Nov 20, 2006 1:47 am
Quoting Noelg (Reply 4):
Thank you for the advice! Yes I do have a full version of FSUIPC, so I will see if I can figure it out
ZSOFN
Mon Nov 20, 2006 1:51 am
The FSUIPC route is much quicker; I simply assigned "d" for all engines (I didn't use whatever assignment FS had originally given for "d"). Very simple!
jamesbuk
Mon Nov 20, 2006 5:58 am
As this Q has now been answered, What is a FSUIPC? whats i stand for and do?
rgds --James--
You cant have your cake and eat it... What the hells the point in having it then!!!
