SInGAPORE_AIR
256MB ATI MOBILITY™ RADEON® X1400 HyperMemory™
Sat Nov 25, 2006 12:56 am
Does anyone know how good the following graphics card is with Flight Simulator X?
Kind regards
Bofredrik
RE: 256MB ATI MOBILITY™ RADEON® X1400 HyperMemory™
Sat Nov 25, 2006 3:24 am
That is far to "slow". Sorry!
+ It is not just that. You must also have atleast 2GB memory + a better g-card.
Gofly
Sun Nov 26, 2006 12:00 am
It will work, but don't expect to be able to run top settings or get high FPS.  Smile
In all honesty, if you have the money, an upgrade would be the best thing; however, if you have a lower end system, I wouldn't recommend putting a top spec graphics card in it. What are the rest of your specs?
-Gofly
Living the high life on my ex-Airliners.net Moderator pension...
AC773
Sun Nov 26, 2006 2:46 am
By the "Mobility Radeon" moniker, I can safely assume that this card is in a laptop. It's probably better than most portable GPUs, but as everyone before me has said, don't expect to get much out of FSX.
If you want to game with the latest flightsim, eschew the portables and get yourself a high-powered, purpose-built rig.
Better to be nouveau than never to have been riche at all.
SInGAPORE_AIR
Sun Nov 26, 2006 1:39 pm
Thanks for your responses, it is indeed in a laptop.
However, I checked Dell and HP and found that both only offer up to 256MB GFX cards. And since I need a laptop for univerrsity, I cannot justify buying a desktop computer just for FSX! Alas...
Looks like I'll have to wait a while until I get to experience FSX for myself but thanks again all the same.
boeingguy1
Sun Nov 26, 2006 9:56 pm
Quoting Singapore_Air (Reply 4):
If you have the cash, I suggest looking at alienware (http://www.alienware.com) they have excellent laptops for gaming-- at a price.
"...Gatwick South!? Id rather crash in Brighton!"
Gofly
Sun Nov 26, 2006 10:10 pm
PC Specialist is also excellent:
http://www.pcspecialist.co.uk/
-Gofly
AC773
Mon Nov 27, 2006 3:51 am
If you want a good gaming laptop, I'd suggest a Dell XPS M1710. It's really not cheap (starts around $2300), but you'll be able to play FSX pretty well. Check it out.
Of course, if you really want to go batshit crazy, pick up a Falcon Northwest FragBook DR 6800. It costs about 5 grand, but hey, that's not a biggie for some people.  Wink
And BTW the Aliewares are nice, but they're owned by Dell now anyway, and performance would be about the same as that of the XPS M1710 while costing you more money.
vinniewinnie
Mon Nov 27, 2006 5:15 am
Stick with FS9 I get excellent results with this graphic card on my Toshiba laptop even with the highest demanding sceneries such as scenery frankfurt!
And after all why bother switching to fsx? You hardly get any freeware with it whereas fs9 is at its peak freeware wise!
My 2 cents...  Smile
Flying Belgian
Tue Dec 05, 2006 11:36 pm
Is a 512mb graphic card enough to run FSX without too many troubles ?
FB.
Life is great at 41.000 feet...
AC773
Thu Dec 07, 2006 2:35 am
Quoting Flying Belgian (Reply 9):
Depends. There are really cheapo graphics cards with 512 MB of memory, and then there are really nice cards with the same amount. Memory can influence performance, but it's far from the determining factor.
If you happen to know the model and number (i.e. GeForce 7600 GT) of your card, then I may be able to give you some more solid advice.  Smile
QFA380
Thu Dec 07, 2006 12:55 pm
Hi all, could someone please help me to get a Video Card?
If I have these specs:
250GB HDD
2GB NECC Dual Channel DDR2 533MHz SDRAM Memory
AMD Athlon 64x2 Dual-core Processor 4200+
All I would like is about 30-40fps at most airports, 20 at major airports and about 50 in the air.
EDIT: My bidget is around US$390 (AU$500).
[Edited 2006-12-07 05:10:53]
AC773
Fri Dec 08, 2006 4:29 am
Quoting QFA380 (Reply 11):
Forgoing the spicy (and expensive) card-on-card action of SLI, I can get you damned close to that price with an eVGA 8800 GTS. Its only superior the $800 GTX variant, this card was the first to be built for directX 10 from the ground up. It's guaranteed to knock the socks (and pants) off of every other single-chip solution out there, save the aforementioned GTX.
Check it out here. [via NewEgg]
QFA380
Fri Dec 08, 2006 5:34 am
Quoting AC773 (Reply 12):
Thanks heaps for that, I guess I will just have to save up little longer.
