MCIGuy
FSX Issues
Fri Jan 05, 2007 5:41 pm
Man, I really love this sim, but I'm starting to be disappointed with it in many ways. I have a P4/3.2 Ghz. system with a Radeon 9700 Pro video card and 2 gigs of RAM. For some reason, I can't turn the scenery setting up past "medium low" or my screen goes psychedelic and my system hard locks. I noticed that this turned off most of the airport terminals so I obviously can't use the fuel truck and jetway options. It's still a great sim, so I said "ok, I can live with that". However, it seems to have taken away more than just airport terminals. When I flew the first training mission in the ultralight out of Edwards AFB it was amazing! I did the mission and then turned toward the base. Wow, all sorts of cool planes on the ground! There were two 747's, five F-22's (with "TY" tail markings, Tyndall?), some F-18's and some B-52's! "How cool", I thought, until I tried the same thing in "Free Flight". There was nothing, just one truck and the Space Shuttle. I have to believe this is a matter of the scenery settings. If so, I guess I'm out of luck. This makes me disappointed enough with the sim to put it away until I get a faster computer/video card. I tried playing around with the settings within the "medium high" setting, stil no luck, locks up every time I'm flying. Is there some other setting I can use to get the non-moving ground aircraft? Is there something else I'm missing?
I can't imagine what kind of a system you'd need to go full-on with FSX.
PS> Any suggestions as to why this setting locks up my system would also be highly appreciated. It is definitely the scenery setting, "medium high" = lock-up on the first flight, "medium low" = hours of trouble-free flight.
[Edited 2007-01-05 09:44:05]
Airliners.net Moderator Team
MCIGuy
RE: FSX Issues
Fri Jan 05, 2007 7:28 pm
FIXED, sort of. I think I got it to work with the "medium high" scenery setting. I forgot that I'd manually tried to crank up the frame rate, so I let it choose this time (20 fps) and it seems to be stable now. I also turned down the "Global texture resolution" in the "Graphics" settings to "medium" and it seemed to help a lot. It's a lot less choppy than when I tried to use that setting before in fact, it looks pretty good. This was a low-level flight around Kansas City departing from 0L8. I flew pretty low the whole time and made several low passes over Arrowhead Stadium. I still don't get the military planes on the ground at EDW. I guess that's either a special deal for the training flight or you have to have a monster system and turn the detail way up.
[Edited 2007-01-05 11:32:16]
MCIGuy
RE: FSX Issues
Mon Jan 08, 2007 4:56 am
NAILED IT!!!
I got it dialed in now and I'm getting 30 FPS, shhh-wheat!  Smile
jamesbaldwyn
RE: FSX Issues
Mon Jan 08, 2007 6:07 am
Glad you got it sorted, Lucky Little * 30 FPS lol
pjflysfast
RE: FSX Issues
Mon Jan 08, 2007 11:13 am
I just went in and set my settings to the same as yours and am going to try it out. I will be back with a report.
David L
RE: FSX Issues
Tue Jan 09, 2007 12:03 am
Quoting MCIGuy (Reply 2):
And some people said it couldn't be done.  Smile
pjflysfast
RE: FSX Issues
Tue Jan 09, 2007 5:59 am
I have mine at different settings and it works fine. Thanks for the advice though.
MCIGuy
RE: FSX Issues
Tue Jan 09, 2007 3:27 pm
I have two setting configurations, one named "Detail" and one named "Performance". The "Performance" is the one I'm talking about.
Here are my settings:
http://i108.photobucket.com/albums/n26/formattc/fsxset1.jpg
http://i108.photobucket.com/albums/n26/formattc/fsxset2.jpg
http://i108.photobucket.com/albums/n26/formattc/fsxset3.jpg
http://i108.photobucket.com/albums/n26/formattc/fsxset4.jpg
http://i108.photobucket.com/albums/n26/formattc/fsxset5.jpg
Hope this helps someone.  Smile
Matt C.
[Edited 2007-01-09 07:45:07]
QFA380
RE: FSX Issues
Tue Jan 09, 2007 4:37 pm
Quoting MCIGuy (Reply 7):
I've changed my settings to yours, not sure how it will go as some things I brought some down and others went up.
MCIGuy
RE: FSX Issues
Tue Jan 09, 2007 4:52 pm
Quoting QFA380 (Reply 8):
Yeah, you have to make a few changes manually. That's what makes your settings show as "custom" in the pull down.  Smile
QFA380
RE: FSX Issues
Tue Jan 09, 2007 5:13 pm
Quoting MCIGuy (Reply 9):
I did have it Custom, but I really couldn't be bothered doing trial and error to get it right. I just said, I think it might get this and each time my system performed better than expected so I upped the settings.
MCIGuy
RE: FSX Issues
Tue Jan 09, 2007 5:20 pm
Quoting QFA380 (Reply 10):
Sorry, wasn't being rude, just didn't understand.
Glad it worked out for you.  Smile
MCIGuy
RE: FSX Issues
Thu Jan 11, 2007 1:50 am
UPDATE:
It turns out that the settings in FSX had nothing to do with it's locking up my system. Apparently, I have one of the "winlogon" viruses.
Last night, my FSX started slowing down during just navigating the menus and it suddenly locked up, on the menus, not actual flying. Only this time, it let me do a normal shutdown, not just a reset. I shot the error report off to MS as soon as it came back up and they immediately responded with "your computer is infected withe the winlogon trojan virus". Too bad it wasn't more specific. There are several variations of it and most if not all hide from antivirus software. Looks like this one's going to be rough. Ugh.
 Sad
QFA380
RE: FSX Issues
Fri Jan 12, 2007 9:34 pm
Quoting MCIGuy (Reply 12):
Must suck dude, heres hoping that it works out for you.
