Cessna057
FS9 Airspeed Indicater
Mon Jan 15, 2007 11:38 am
Ok. When I have been flying on FS9, after I get pass about 2k, my Airspeed drops to 0. Any ideas or any help as to what the problem is would be greatly appreciated.
Hold it . . . Hold it . . . HOLD THE FREAKIN NOSE UP!!
jamesbaldwyn
RE: FS9 Airspeed Indicater
Mon Jan 15, 2007 3:56 pm
Check in your simulated failers page in case you have selected something which may cause this problem.
Baldwyn Smile
FlyingPie946LJ
Mon Jan 15, 2007 4:01 pm
possibly try turning on the pitot heat, that should fix the problem
cptspeaking
Tue Jan 16, 2007 4:40 am
Quoting FlyingPie946LJ (Reply 2):
Just as clarification as to why this would be the case...
FS sims the buildup of ice in the pitot tube, which is one of the instruments used by the airspeed indicator. When this is blocked, it doesn't work. So, in order to get rid of the ice, you turn on the pitot heat to burn it off and prevent it from building up again...
Hope this fixes it!
Your CptSpeaking
...and don't call me Shirley!!
Cessna057
Tue Jan 16, 2007 2:55 pm
Pitot heat fixed it! Thanks guys.
CVGpilot
Tue Jan 16, 2007 3:46 pm
- Holy crap, I had no idea fs9 really simulated pitot ice, hmmmm....  cold
Cessna057
Wed Jan 17, 2007 8:53 am
Quoting CVGpilot (Reply 5):
Lol I know . . I was suprised as well.
EZEIZA
Wed Jan 17, 2007 12:23 pm
I learnt that the hard way too. It only happened to me once though, so i guess it's pretty uncommon
Carp aunque ganes o pierdas ...
Cessna057
Fri Jan 19, 2007 11:38 am
Quoting EZEIZA (Reply 7):
Well I fly in VATSIM, which uses a different type of real world weather and pitot ice is very common.
