Cessna057
Easier Ways At AFCADs
Fri Feb 23, 2007 9:39 am
Ok, I downloaded some scenery for Cleveland and there was no afcad file for it. So for the past hour or so, I've been going through and putting the gate placement in the correct possition through afcad editor, but its taking forever!! Is there an easier way to do it or am I totaly screwed?
Hold it . . . Hold it . . . HOLD THE FREAKIN NOSE UP!!
QF108
RE: Easier Ways At AFCADs
Fri Feb 23, 2007 10:03 am
A lot of times if you download scenery, there will be an Afcad available separately. Sometimes by the scenery designer or someone who has done the hard work like you are doing now. If you search through all the KCLE Afcads available they will usually say something like Afcad for "John Smiths" excellent Cleveland scenery.
Good luck and hope you find something because I hate doing my own as you said, to do it right it takes forever.
Blessed are the Cheesemakers !
Interpaul
Fri Feb 23, 2007 10:32 am
If you use the FS slew function an afcad you can use the keyboard shortcuts to create nodes and parking spots etc. It's very easy and quick. Just move along all taxiways, pressing . every couple of meters and then connect the dots in afcad. Or if you just want to create parking spots, move your aircaft to the desired spot with the right heading and then press o to create a parking spot.
Jan
Cessna057
Fri Feb 23, 2007 10:41 am
Nothing...Just sitting down and making them myself =[
Cessna057
Fri Feb 23, 2007 11:47 pm
Ok, I finished the AFCAD for for file from AVSIM titled "cle2004u.zip" (which is amazing freeare btw). Anyone who wants it PM me..
BAW076
Sat Feb 24, 2007 1:32 am
My mate Lee Brompton did a superb AFCAD for this airport scenery...
go to www.avsim.com
and search for:
lb_kcle.zip
Chris  wave
N754AN (x2), G-CPEL, G-MIDE, G-BPEC, G-BZHC, EI-DCH, LN-KKN, G-VIIW, G-BNLT, G-DBCA, G-MEDE, G-DBCE, G-MIDP.
Cessna057
Sat Feb 24, 2007 2:26 am
Quoting BAW076 (Reply 5):
ARE YOU SERIOUS??
I spent about 4 hours yesterday making a perfect one....guess it was worthless haha
Thanks anyway
Chriss
BAW076
Sat Feb 24, 2007 2:31 am
Did you not search AVSIM for it before you started your one??
Cessna057
Sat Feb 24, 2007 3:25 am
Quoting BAW076 (Reply 7):
Yea for all CLE AFCADS abd got nothing  Sad oh well
BAW076
Sat Feb 24, 2007 3:36 am
Didn't look hard enough then eh?!
A little tip and trick when looking for stuff, which always works for me.
When you come to doing a search for something, say for example, I wanted to find an AFCAD for Philadelphia Airport, I would type in the search bar KPHL and then select from the drop down menu "FS2004 AFCAD files". It will bring up tons of them. I wouldn't type in PHL cos the chances are much more reduced of finding any.
Hope that helps for future reference.
Chris  wave
Cessna057
Sat Feb 24, 2007 1:39 pm
Quoting BAW076 (Reply 9):
Yeah I went through quite a few of those in my search, a few including the file name and everything. No like I'm pretty good with finding pretty much anything I want on the internet lol. I'm not really sure why I couldnt find it...
Chriss
