co777er
Optimizing Graphics For FS9
Sun Apr 15, 2007 1:11 pm
Here's the scenario:
1st off I'll give you the cpu specs so you "FS9 experts" can help!
2.4ghz Core 2 Duo, 2gb ram, 2X512 nVidia 7950gtx SLI ...
When I turn the anti-aliasing off on my graphics card panel, the planes look like crap. But, when I turn it up, pop-ups like squawkbox and even some of the extra panel things like the FMC, Radio etc. cause the main view to freeze, or for lack of better terms, it looks like it is paused.
Does anyone have any suggestions to optimize the antialiasing, antistrophing on the cards.
727stretch
RE: Optimizing Graphics For FS9
Wed Apr 25, 2007 8:35 am
You should not be experiencing freezing with FS9 in a rig of your caliber. I have more RAM, a similar CPU, but only 1 GPU (Sapphire X1950 Pro 512MB). I have ATI control all of the settings and most are at high. I also have Trilinear filtering on in FS9. I don't have any visual/performance issues, except some stuttering in thunderstorms with puffy clouds, etc. Questions for you:
-Do you have AA on in FS9? I only recommend using your graphics driver AA function and leave it off in FS9.
-Have you tried AA at 4x? I'm not sure what the AF settings are for nvidia cards. But definitely AA at 4x should work fine.
-Have you added the following lines to your FS9.cfg file?
UPPER_FRAMERATE_LIMIT=XY (XY= whatever locked FPS you want; I recommend 35 for your card setup)
TEXTURE_BANDWIDTH_MULT=100
TextureMaxLoad=10
....Read this thread for more FS9 tweaking tips and background info on the above lines: http://www.sim-outhouse.com/sohforums/showthread.php?t=25421
-Have you done a clean install of your graphics drivers?
-How many background programs & services are you running?
I'd be glad to help you troubleshoot. Do a google search, too, and you should find a ton of stuff.
[Edited 2007-04-25 01:40:32]
RIHNOSAUR
Thu Apr 26, 2007 3:29 am
Quoting 727stretch (Reply 1):
I don't have as powerful a rig as you guys but it is a decent Hp laptop:
P4 3.0 Ghz Ht, 1Gb of Ram and an ATI 128 dedicated graphics card
I have maxed out most of the sliders on FS9 and set the target frame rate at 30. And I have bilinear anti aliasing on in FS9. however most of the time I get between 20 fps. I noticed that if I cut back on the traffic and clouds I get close to 30 fps. So here is (are) the question(s)
1. Do you recommend not using the FS9 anti aliasing??? if not, how do I ensure my graphics card is doing the best job it can in anti-aliasing???
2. What are some tweaks I can do withing FS9 and the cfg file that can get me more frame rates whilst still keeping great looking planes.. Similarly how can I tweak the ATI settings to work best for FS9???
cheers
particles and waves are the same thing, but who knows what that thing is...
co777er
Thu Apr 26, 2007 2:00 pm
Thanks for all the help it is working much better!
EA CO AS
Thu Apr 26, 2007 5:24 pm
Ok experts (because I'm DEFINITELY not one!), here's what my FS9.cfg currently reads. I'm running a P4 3.0gHz HT with 2GB PC3200 DDR SDRAM and a nVidia 6800GS 256MB GDDR3 PCIExpress card.
Please let me know what tweaks - if any - might be helpful!
[PANELS]
IMAGE_QUALITY=1
UNITS_OF_MEASURE=0
QUICKTIPS=1
PANEL_MASKING=1
PANEL_STRETCHING=1
[Weather]
WindshieldPrecipitationEffects=1
MinGustTime=10
MaxGustTime=500
MinGustRampSpeed=1
MaxGustRampSpeed=200
MinVarTime=5
MaxVarTime=50
MinVarRampSpeed=10
MaxVarRampSpeed=75
TurbulenceScale=1.000000
DefaultVisibility=0
DynWx_MedianDewPointSpread=10.000000
DynWx_ProbCloudFormForMedianDewPoint=0.000500
DynWx_MaxDewPointSpread=50.000000
DynWx_ProbCloudFormForMaxDewPoint=0.000125
DynWx_ProbCloudFormForMinDewPoint=0.100000
DynWx_DryTempLapsePer1000Meters=9.000000
DynWx_ProbCloudFormForDryTempLapse=0.000500
DynWx_MoistTempLapsePer1000Meters=3.300000
DynWx_ProbCloudFormForMoistTempLapse=0.040000
DynWx_MaxProbCloudChangePerMinute=0.040000
DynWx_MultiplierForDynamicWeatherLevelMild=0.500000
DynWx_MultiplierForDynamicWeatherLevelNormal=1.000000
DynWx_MultiplierForDynamicWeatherLevelHigh=3.000000
DynWx_MultiplierForDynamicWeatherLevelExtreme=10.000000
DynWx_TempChangePercentageForOvercastClouds=0.750000
DynWx_TempChangePercentageForMinDewPoint=0.700000
DynWx_MaxTempChangePerMinute=0.060000
WeatherServerAddress=fs2k.zone.com
WeatherServerPort=80
WeatherGraphDataInDialog=0
DynamicWeather=0
LOADWEATHER=1
MAX_UNLIMITED_VIS=128747
CLOUD_DRAW_DISTANCE=4
3D_CLOUD_PERCENT=100
DETAILED_CLOUDS=1
CLOUD_COVERAGE_DENSITY=7
DownloadWindsAloft=1
DisableTurbulence=0
CloudsImpostorRingRadius=64000.000000
[INTERNATIONAL]
ASLAT=2
ASLON=1
MEASURE=0
[MISC]
COM_RATE=7
LOG_TIME=0
FOREIGN_TRANSLATOR=0
LOG_FILE=
[STARTUP]
DEMO=0
LOADSIM=1
LOADWINDOW=1
SHOW_OPENING_SCREEN=1
STARTUP_DEMO=
[GRAPHICS]
FULL_SCREEN=1
PERFORMANCE_MODE=0
DEF_PERF_MODE=6
TEXT_SCROLL=1
AUTO_LOD=0
DETAIL_TEXTURE=1
WATER_EFFECTS=2
TERRAIN_USE_VECTOR_MAP=1
TERRAIN_USE_VECTOR_OBJECTS=1
EFFECTS_QUALITY=2
GROUND_SHADOWS=0
SMOOTH_VIEW=1
IMAGE_SMOOTHING=1
TEXTURE_MAX_LOAD=1024
COCKPIT_HIGH_LOD=1
AIRCRAFT_SHADOWS=1
LANDING_LIGHTS=1
IMAGE_QUALITY=0
TEXTURE_BLDG=1
TEXTURE_GND=1
TEXTURE_WATER=1
AIRCRAFT_TEXTURE=2
SEE_SELF=1
TEXTURE_QUALITY=3
LOD_TARGET_FPS=18
NUM_LIGHTS=8
[REALISM]
INDASPD=0
PFactor=1.000000
Torque=1.000000
GyroEffect=1.000000
CrashTolerance=0.000000
General=1.000000
UnlimitedFuel=True
TrueAirspeed=False
AutoCoord=False
RealMixture=False
StressDamage=False
GEffect=True
ManualLights=True
GyroDrift=False
CrashWithDyn=False
CrashDetection=0
[CONTROLS]
KBDAIL=64
KBDELEV=64
KBDRUD=64
PAN_RATE=400
[USERINTERFACE]
MAP_ORIENTATION=2
PAUSE_ON_LOST_FOCUS=0
PROMPT_ON_EXIT=1
PageID=3
OpenATCOnCreate=0
FSLiveURL=www.microsoft.com/games/flightsimulator/product/fsliveweb.asp
SelectFlightLevel=0
SelectFlightTitle=0
SITUATION=
DisplayFuelAsWeight=0
[SOUND]
SOUND=1
SOUND_FADER1=0.200000
SOUND_FADER2=0.200000
SOUND_FADER3=0.230000
SOUND_FADER4=0.800000
SOUND_FADER5=0.230000
SOUND_FADER6=1.000000
SOUND_QUALITY=2
[DISPLAY.Device.RADEON X300 Series .0]
Mode=1280x1024x32
TriLinear=1
AntiAlias=1
MipBias=4
[DISPLAY]
UPPER_FRAMERATE_LIMIT=0
TEXTURE_BANDWIDTH_MULT=40
[TERRAIN]
TERRAIN_ERROR_FACTOR=84.000000
TERRAIN_MIN_DEM_AREA=10.000000
TERRAIN_MAX_DEM_AREA=100.000000
TERRAIN_MAX_VERTEX_LEVEL=19
TERRAIN_TEXTURE_SIZE_EXP=8
TERRAIN_AUTOGEN_DENSITY=3
TERRAIN_USE_GRADIENT_MAP=1
TERRAIN_EXTENDED_TEXTURES=0
TERRAIN_DEFAULT_RADIUS=9
TERRAIN_EXTENDED_RADIUS=9.5
TERRAIN_EXTENDED_LEVELS=5
[SCENERY]
IMAGE_COMPLEXITY=4
DYNAMIC_SCENERY=0
DYN_SCN_DENSITY=0
DAWN_DUSK_SMOOTHING=1
SUNGLARE=1
LENSFLARE=1
[AIRtoCONTAINER]
SIM1=Cessna Skylane 182R RG
SIM2=Learjet 45
SIM3=Schweizer 2-32 Sailplane
SIM4=Sopwith Camel
SIM5=Extra 300S
SIM6=Boeing 737-400
[APL]
CACHE_WAV_FILES=1
[TrafficManager]
TrafficDensity=80
IFROnly=0
EnableAirline=1
EnableGeneralAviation=1
[AContain]
ShowLabels=0
ShowUserLabel=0
ShowLabelManufacturer=0
ShowLabelModel=1
ShowLabelTailNumber=0
ShowLabelDistance=1
ShowLabelAltitude=1
ShowLabelAirline=0
ShowLabelAirlineAndFlightNumber=0
ShowLabelFlightPlan=0
ShowLabelContainerId=0
ShowLabelAirspeed=0
ShowLabelHeading=0
LabelDelay=2000
LabelColor=FF00FFFF
[SLEW]
MaxLateralRate=40000.000000
MaxVerticalRate=1000.000000
MaxPitchRate=360.000000
MaxBankRate=360.000000
MaxHeadingRate=360.000000
[VirtualCopilot]
VirtualCopilotActive=0
[RWW_WEATHER_MAP]
SHOW_AIRPORTS=0
SHOW_VORS=0
SHOW_NDBS=0
SHOW_APPROACHES=0
SHOW_INTERSECTIONS=0
SHOW_VICTOR=0
SHOW_JET=0
SHOW_AIRSPACE=0
SHOW_FLIGHTPLAN=1
SHOW_WEATHERSTATIONS=1
SHOW_WEATHERSYSTEMS=1
SHOW_DATATAGS=1
SHOW_TERRAIN=1
[FlightPlanMap]
SHOW_AIRPORTS=1
SHOW_VORS=1
SHOW_NDBS=1
SHOW_APPROACHES=1
SHOW_INTERSECTIONS=1
SHOW_VICTOR=0
SHOW_JET=0
SHOW_AIRSPACE=1
SHOW_FLIGHTPLAN=1
SHOW_WEATHERSTATIONS=0
SHOW_WEATHERSYSTEMS=0
SHOW_DATATAGS=1
SHOW_TERRAIN=1
show_waypoints=1
show_airways=1
show_markers=1
show_volume_boundaries=1
show_ac_twr=1
[MAPVIEW_MAP]
SHOW_AIRPORTS=1
SHOW_VORS=1
SHOW_NDBS=1
SHOW_APPROACHES=1
SHOW_VICTOR=0
SHOW_JET=0
SHOW_AIRSPACE=1
SHOW_FLIGHTPLAN=1
SHOW_DATATAGS=1
SHOW_TERRAIN=1
show_flight_history=1
[MULTIPLAYER]
ALWAYS_SHOW_INITIAL_DIALOG=1
SESSION_NAME=SquawkBox (your-d26ef63b94)
PLAYER_NAME=EAL718
GUARANTEED_MESSAGES=0
MAX_PLAYERS=8
MAX_OBSERVERS=0
TICKS_PER_SYNC=90
PACKETS_PER_SEC=4
COLLISION_SECS=2
FOLLOWING_MULTIPLIER=5
ALLOW_PLANE_MODEL_SEND=0
ALLOW_PLANE_MODEL_RECEIVE=0
ALLOW_TEXTURE_SEND=0
ALLOW_TEXTURE_RECEIVE=0
MAX_SEGMENT_SIZE=100
MAX_SEGMENTS_PER_SEC=1
CONNECTION_TYPE=0
PROTOCOL_SELECTION=0
ALLOW_DESCRIPTIVE_SEND=1
ALLOW_DESCRIPTIVE_RECEIVE=1
AUTOPILOT_LOCK=0
DISTANCE_DISPLAY=0
ADF_TRACK=0
ALLOW_NAME_TAG_DISPLAY=1
CLIENT_CONNECT_USE_CUSTOM_PORT=0
CLIENT_CONNECT_PORT=23456
CLIENT_HOST_USE_CUSTOM_PORT=0
CLIENT_HOST_PORT=23456
HOST_CONNECT_USE_CUSTOM_PORT=0
HOST_CONNECT_PORT=23456
[SIM]
SYSCLOCK=1
[ATC]
AutoOpenAirTrafficWindow=1
UsePilotVoice=1
ShowATCText=1
PilotVoice=1
[MAIN]
Location=191,101,993,611
HideMenuNormal=0
HideMenuFullscreen=1
Maximized=0
[FACILITIES]
COUNTRY=
STATE=
CITY=
GTL_BUTTON=6225
[FrameCallNoWarn]
BYRONS ULTRALIGHT=0
shuttle=0
FFG_737-900_v5=0
Piper Tomahawk=0
[WEATHER_MAP]
SHOW_AIRPORTS=0
SHOW_VORS=0
SHOW_NDBS=0
SHOW_APPROACHES=0
SHOW_VICTOR=0
SHOW_JET=0
SHOW_AIRSPACE=0
SHOW_FLIGHTPLAN=1
SHOW_DATATAGS=1
SHOW_TERRAIN=1
[WeatherAreaMap]
show_airports=0
show_waypoints=0
show_airways=1
show_vors=0
show_ndbs=0
show_markers=0
show_volume_boundaries=0
show_ac_twr=1
[DISPLAY.Device.NVIDIA GeForce 6800 GS.0]
Mode=1280x1024x32
TriLinear=1
AntiAlias=1
[DISPLAY.Device.NVIDIA GeForce 6800 GS .0]
Mode=1280x1024x32
TriLinear=1
AntiAlias=1
[KEYBOARD_MAIN]
SELECT_1=49,8
SELECT_2=50,8
SELECT_3=51,8
SELECT_4=52,8
MINUS=189,8
PLUS=187,8
ZOOM_1X=8,8
SOUND_TOGGLE=81,8
ENGINE=69,8
SIM_RATE=82,8
XPNDR=84,8
SLEW_TOGGLE=89,8
EGT=85,8
SMOKE_TOGGLE=73,8
STROBES_TOGGLE=79,8
PAUSE_TOGGLE=80,8
ATC=192,8
ADF=65,8
VIEW_MODE=83,8
HEADING_GYRO_SET=68,8
DME=70,8
GEAR_TOGGLE=71,8
ANTI_ICE_TOGGLE=72,8
JET_STARTER=74,8
JOYSTICK_CALIBRATE=75,10
ALL_LIGHTS_TOGGLE=76,8
SITUATION_SAVE=186,8
VIEW_WINDOW_TO_FRONT=222,8
AP_MASTER=90,8
FREQUENCY_SWAP=88,8
COM_RADIO=67,8
VOR_OBS=86,8
BAROMETRIC=66,8
NAV_RADIO=78,8
MAGNETO=77,8
BRAKES=190,8
SPOILERS_TOGGLE=191,8
SITUATION_RESET=186,10
FLAPS_UP=116,8
THROTTLE_FULL=115,8
THROTTLE_INCR_SMALL=114,8
THROTTLE_DECR=113,8
FLAPS_DOWN=119,8
THROTTLE_CUT=112,8
VIEW=111,8
ELEV_TRIM_DN=36,8
ELEV_DOWN=38,8
INCREASE_THROTTLE=33,8
AILERONS_LEFT=37,8
CENTER_AILER_RUDDER=12,8
AILERONS_RIGHT=39,8
ELEV_TRIM_UP=35,8
ELEV_UP=40,8
DECREASE_THROTTLE=34,8
VIEW_FORWARD=38,41
VIEW_FORWARD_RIGHT=33,41
VIEW_RIGHT=39,41
VIEW_REAR_RIGHT=34,41
VIEW_REAR=40,41
VIEW_REAR_LEFT=35,41
VIEW_LEFT=37,41
VIEW_FORWARD_LEFT=36,41
VIEW_DOWN=12,41
RUDDER_LEFT=45,8
RUDDER_RIGHT=135,8
BRAKES_LEFT=122,8
BRAKES_RIGHT=123,8
AP_ATT_HOLD=84,10
AP_LOC_HOLD=79,10
AP_APR_HOLD=65,10
AP_HDG_HOLD=72,10
AP_ALT_HOLD=90,10
AP_WING_LEVELER=86,10
AP_BC_HOLD=66,10
AP_NAV1_HOLD=78,10
EXIT=67,10
ABORT=3,10
READOUTS_FLIGHT=90,9
PANEL_TOGGLE=219,9
VIEW_MODE_REV=83,9
PANEL_LIGHTS_TOGGLE=76,9
LANDING_LIGHTS_TOGGLE=76,10
PARKING_BRAKES=190,10
MINUS_SHIFT=189,9
PLUS_SHIFT=187,9
FLAPS_INCR=118,8
FLAPS_DECR=117,8
PROP_PITCH_LO=115,10
PROP_PITCH_INCR_SMALL=114,10
PROP_PITCH_DECR=113,10
PROP_PITCH_HI=112,10
MIXTURE_RICH=115,11
MIXTURE_INCR_SMALL=114,11
MIXTURE_DECR=113,11
MIXTURE_LEAN=112,11
SCRIPT_EVENT_1=219,10
SCRIPT_EVENT_2=221,10
YAW_DAMPER_TOGGLE=68,10
CENTER_NT361_CHECK=57,11
CLOSE_VIEW=221,8
NEW_VIEW=219,8
NEW_MAP=221,9
NEXT_VIEW=9,10
PREV_VIEW=9,11
VIEW_TYPE=83,10
VIEW_TYPE_REV=83,11
RADIO_VOR1_IDENT_TOGGLE=49,10
RADIO_VOR2_IDENT_TOGGLE=50,10
RADIO_DME1_IDENT_TOGGLE=52,10
RADIO_ADF_IDENT_TOGGLE=53,10
GEAR_PUMP=71,10
SPOILERS_ARM_TOGGLE=191,9
PITOT_HEAT_TOGGLE=72,9
AP_AIRSPEED_HOLD=82,10
AUTO_THROTTLE_ARM=82,9
AUTO_THROTTLE_TO_GA=71,11
LANDING_LIGHT_UP=38,11
LANDING_LIGHT_DOWN=40,11
LANDING_LIGHT_LEFT=37,11
LANDING_LIGHT_RIGHT=39,11
LANDING_LIGHT_HOME=12,11
PAN_RESET=46,9
KNEEBOARD_VIEW=121,8
MP_PLAYER_CYCLE=84,11
MP_PLAYER_SNAP=70,11
MP_GO_OBSERVER=79,11
MP_CHAT=221,11
MP_ACTIVATE_CHAT=13,8
PANEL_1=49,9
PANEL_2=50,9
PANEL_3=51,9
PANEL_4=52,9
PANEL_5=53,9
PANEL_6=54,9
PANEL_7=55,9
PANEL_8=56,9
PANEL_9=57,9
AP_MACH_HOLD=77,10
VIEW_FORWARD_UP=38,42
VIEW_FORWARD_RIGHT_UP=33,42
VIEW_REAR_RIGHT_UP=34,42
VIEW_REAR_UP=40,42
VIEW_REAR_LEFT_UP=35,42
VIEW_FORWARD_LEFT_UP=36,42
VIEW_UP=12,42
INVOKE_HELP=191,10
TOGGLE_AIRCRAFT_LABELS=76,11
ENGINE_AUTO_START=69,10
INC_COWL_FLAPS=86,11
DEC_COWL_FLAPS=67,11
USER_INTERRUPT=27,8
AILERON_TRIM_LEFT=37,10
AILERON_TRIM_RIGHT=39,10
RUDDER_TRIM_LEFT=45,10
RUDDER_TRIM_RIGHT=135,10
TOGGLE_FLIGHT_DIRECTOR=70,10
TOGGLE_AFTERBURNER=115,9
TOGGLE_MASTER_BATTERY_ALTERNATOR=77,9
TOGGLE_AIRCRAFT_EXIT=69,9
TOGGLE_WING_FOLD=67,9
TOGGLE_TAIL_HOOK_HANDLE=188,8
PANEL_HUD_TOGGLE=87,8
SNAP_TO_PANEL=45,41
MARKER_SOUND_TOGGLE=51,10
TOGGLE_WATER_RUDDER=87,9
TOGGLE_PUSHBACK=80,9
KEY_CHASE_VIEW_NEXT=87,10
KEY_CHASE_VIEW_PREV=87,11
HEADING_BUG_SELECT=72,11
ALTITUDE_BUG_SELECT=90,11
CHASE_VIEW_TOGGLE=81,10
EYEPOINT_UP=13,9
EYEPOINT_DOWN=8,9
EYEPOINT_RIGHT=13,11
EYEPOINT_LEFT=8,11
EYEPOINT_FORWARD=8,10
EYEPOINT_BACK=13,10
EYEPOINT_RESET=32,8
ENGINE_AUTO_SHUTDOWN=79,9
AIRSPEED_BUG_SELECT=82,11
TOGGLE_TAILWHEEL_LOCK=71,9
ROTOR_BRAKE=66,9
ROTOR_CLUTCH_SWITCH_TOGGLE=190,9
ROTOR_GOV_SWITCH_TOGGLE=188,9
VIRTUAL_COPILOT_TOGGLE=88,11
VIRTUAL_COPILOT_ACTION=88,10
[KEYBOARD_SLEW]
SLEW_TOGGLE=89,8
SLEW_ALTIT_UP_FAST=115,8
SLEW_ALTIT_UP_SLOW=114,8
SLEW_ALTIT_FREEZE=113,8
SLEW_ALTIT_DN_FAST=112,8
SLEW_ALTIT_PLUS=81,8
SLEW_ALTIT_MINUS=65,8
SLEW_PITCH_DN_FAST=119,8
SLEW_PITCH_DN_SLOW=118,8
SLEW_PITCH_FREEZE=117,8
SLEW_PITCH_UP_FAST=116,8
SLEW_PITCH_PLUS=57,8
SLEW_PITCH_MINUS=48,8
READOUTS_SLEW=90,9
SLEW_BANK_MINUS=36,8
SLEW_AHEAD_PLUS=38,8
SLEW_BANK_PLUS=33,8
SLEW_LEFT=37,8
SLEW_FREEZE=12,8
SLEW_RIGHT=39,8
SLEW_HEADING_MINUS=35,8
SLEW_AHEAD_MINUS=40,8
SLEW_HEADING_PLUS=34,8
SLEW_RESET=32,8
EYEPOINT_UP=13,9
EYEPOINT_DOWN=8,9
EYEPOINT_LEFT=8,11
EYEPOINT_BACK=13,10
