cogrady84
Need Some Help With Being An Enthusiast! :)
Tue May 08, 2007 8:55 am
Hello
I've just completed my registration to this forum, this is officially my first post (wave).
I've been an aviation enthusiast for probably going on 15 years now, I use flight sims and visit airports as often as possible!
One thing I have always wanted to get into is using "scanners" to listen to live ATC comms, I have visited Heathrow several times now and often there are people sat around listening in, it facinates me and I often listed in on liveatc.net.
I have a planned trip to London coming up at the end of the month and would LOVE to have an appropriate device which will allow me to do this whilst im there! I'm staying in a hotel across from 09 for 2 nights. As I am in the UK I dont think I have the Radio Shack option, although somebody may be able to correct me on this... Could I have some advice on exactly what I should be looking for? What radio frequencies I should be using etc? I'm TOTALLY new to this!
Is this legal practice? Is there anything I shouldn't do?
I appreciate the help!
[Edited 2007-05-08 01:57:07]
PAHS200
RE: Need Some Help With Being An Enthusiast! :)
Tue May 08, 2007 9:04 am
Quoting Cogrady84 (Thread starter):
as I understand it it is OK to listen for your enjoyment but you CAN NOT share it like "liveatc.net"
I heard that on the liveatc.net forum.
as for the scanner part since i don't live in the UK i don't know where you can buy one you can try radioshack.com
Michael
WestJetYQQ
Tue May 08, 2007 9:10 am
It should be legal to listen to it without sharing it.
You can listen to any of the airport frequencies. It's just a matter of looking up what they are. If you have a British flight supplement, it could be of use to you.
Radio in and interfere with the radio communications!  duck
Welcome to A.net, and enjoy the rest of your enthusiast carreer!
Carson
Will You Try to Change Things? Use the Power that you have, the Power of a Million new Ideas.
David L
Wed May 09, 2007 12:04 am
Quoting PAHS200 (Reply 1):
Quoting WestJetYQQ (Reply 2):
In the UK, it is technically illegal to listen to broadcasts that aren't meant for you but apparently the Home Office takes a "relaxed view" provided you don't do something silly with it, like, as suggested, sharing it on the internet.
I bought my AOR AR8200 Mk II from http://www.javiation.co.uk/ - they have quite a wide range of scanners and accessories.
There are lists on the internet but you could start here: http://www.javiation.co.uk/vu.html . You could paste that list into a spreadsheet and sort by location.
(no, I have no connection with Javiation  Smile )
flyboyseven
Wed May 09, 2007 12:41 am
Congrats on your first post. I have wondered where to get a scanner myself, but now i know. thanks guys.
As long as the number of take-offs equals the number of landings...you're doing fine.
cogrady84
Wed May 09, 2007 3:09 am
Thanks for the info guys... although looking at the site, i still have NO idea what I should actually be getting? I would like something fairly compact, handheld. Range would need to be fairly good i assume. and be able to monitor frequencies at LHR and MME (Teesside/Durham Tees Valley).
David L
Wed May 09, 2007 4:44 am
Quoting Cogrady84 (Reply 5):
That's tricky. What's your budget? How many frequencies do you need to store? For £70 (at Javiation), you can get the Maycom 108 which seems to be great value for money.
For £400 you can get something that stores 1000 frequencies in 20 banks, so you can store all the frequencies you're likely to need anywhere and only scan the banks that apply at your current location (you don't want to be scanning 1000 memory channels when only 50 apply). You can also connect it to your PC and use control software and save your frequencies to Excel, etc.  Smile
Depending on your location when listening to MME, you may only be able to hear transmissions from aircraft in the air (perhaps only 50 ft or so and higher) and not the tower itself... but it depends. The "official" rule is line of sight but it's usually a bit better than that. From your location, you'll also be able to hear one side of some conversations with with London Centre and/or Scottish Centre by aircraft en route nearby, e.g. north Atlantic traffic, London-Glasgow/Edinburgh traffic.
From a hotel across the runway at LHR, you'll be able to hear both sides of the conversations, assuming the windows have no metallic content - I've been blocked by hotel windows before.  Sad
UK_Dispatcher
Wed May 09, 2007 6:12 am
Hi Craig,
Nice to hear you are from the MME area. I was brought up in the north east and lived near MME and NCL airports at different times. I worked at MME for a few years before moving to MAN and later to AUH.
Do you get to MME very often? I haven't been using it so much since EY started flying AUH-MAN - it is often easier now to fly there and get the train to Darlington than wait around LHR for a flight to MME.
When you get your scanner if you tune to 131.575, that is the company frequency used by bmi and Aviance at several UK stations including MME. I'm sure someone else can give you ATC frequencies for MME.
Let me know what the goings on are at MME if possible - it is always nice to hear about the more unusual visitors.
Ian.
LHRman
Fri May 11, 2007 7:14 am
Heathrow Frequencies:
118.500 N Tower (Primary Tower)
118.700 S Tower
121.900 N Ground (Primary Ground)
121.700 S Ground
121.975 Delivery
119.725 Heathrow N Director (Primary Director)
134.975 Heathrow S Director
120.400 Heathrow Final Director
Some London Control Frequencies of interest.
119.775 / 121.275 (NW stuff)
123.900 / 118.825 (NE stuff)
120.525 / 120.175 (SE stuff)
134.125 / 133.175 (SW stuff)
If you search around you can get more but this will definatly get you started.
Thanks..
Dave P
CAP
Always after the picture you can't get..
KaiGywer
Crew
Fri May 11, 2007 10:34 am
Here in the US, a cheap handheld scanner can be had for about $100. Should be good enough for ATC, cops, fire, ambulance.
cogrady84
Tue May 15, 2007 6:38 am
Hey again,
I'm looking at buying the UNIDEN UBC30XLT SCANNER, which is here:
http://www.thunderpole.co.uk/uniden_bc_30.htm
Is this a good buy?
KaiGywer
Crew
Tue May 15, 2007 9:22 pm
Quoting Cogrady84 (Reply 10):
Hey again,
Is this a good buy?
Looks decent enough, and it is fairly cheap. You can also check Ebay
cogrady84
Thu May 17, 2007 2:02 am
I actually bought that one from Ebay, £36 w/ postage!  Smile
Should be here tomorrow!
pjflysfast
Thu May 17, 2007 5:58 am
As long as you dont key the mic you will be fine! Welcome to A.net!
David L
Thu May 17, 2007 8:22 am
Quoting PJFlysFast (Reply 13):
Good luck trying that with a £36 scanner.  Smile
FighterPilot
Thu May 17, 2007 9:27 am
eBay is a good idea. That's where I got mine. It's a mint scanner, it covers almost everything. http://www.uniden.com/products/produ...cfm?product=BC246T&filter=Handheld
Cal  airplane
*Insert Sound Of GE90 Spooling Up Here*
