LHRSIMON
Cloud Cover In FS9?
Fri May 25, 2007 6:51 pm
Im after a bit of advise please  Smile
I have FS9 + Flight 1's Flight Envirment. But i have noticed something very strange. (Or may be its normal ???)
I will set my weather to however i want it to show. Lets say for example thunderstorms. Now when im at ground level everything is fine. The cloud , rain and lightning is all there. Visability is also low inline with the weather... As i take off everything is still fine until i get to about 7000-10000 ft. Then all of a sudden all the clouds go and im left with clear skies,perfect visability and a perfect view of the ground below. !!!!
The same goes for landing. I will have perfect skies (with some clouds) but as i decend into an airport all of a sudden the weather will change to the correct weather for that area. It very unrealistic to say the least. Its noting like in the real world where large areas are covered in cloud as you cruise at 30000 ft... Just perfect skies until i decend and then BANG !!!
I have tried all the setting ie cloud percentage / detailed clouds etc etc etc but nothing seems to have any effect. (BTW i have it set at detailed clouds at 20%. Cloud cover 80%)
Thanks all
Simon
 Smile
Canon 1D Mk III,Canon 20D+17-40 L f4.0,70-200 L IS USM f2.8,400 L USM f5.6,135 mm L f2.0, 50 mm f1.8,1.4 x II extender
Ryanair737
RE: Cloud Cover In FS9?
Sat May 26, 2007 1:03 am
I have noticed this too, unfortunately I think it is a limit with FS9 and cannot be altered. It is unrealistic, like you said when your at FL300+ and it is supposed to be overcast down below the ground is visable with only a few bits of lower level cloud. I'd also like to hear if anyone has solved this or has it been fixed in FSX?
737
LAST FLIGHTS= Ryanair LPL-BGY-LPL - EI-DPS/DWV - MAY 08 // NEXT FLIGHTS= TBC
GoingAround
Sat May 26, 2007 3:19 am
I would try altering the Visibility altitude in the 'Advanced Weather' menu, that should help with the sudden change of visibility (I normally change mine to the altitude that the cloud cover stops anyway as this is more realistic).
Past that the only thing I can suggest is maybe shelling out for a full copy of FSUIPC that will automatically 'smooth' the cloud layers and allow them to be rendered properly. Along with the many other features it provides for FS.
Alex
Ryanair737
Sat May 26, 2007 6:13 am
Quoting GoingAround (Reply 2):
That only works if your not using Real World Weather.
737
GoingAround
Sat May 26, 2007 6:14 pm
Quoting Ryanair737 (Reply 3):
Sorry, you hadn't mentioned you were using Real World Weather.
The default Real weather does have issues about rendering weather properly, the only solution to this is to get an addon that will use its own METAR information to produce weather situations. This can be done by programmes such as ActiveSky and GroundEnvironment. I think there is a free programme out there but unfortunately I couldn't tell you where to get it as I have searched and not found anything  Sad
All the best,
Alex
LHRSIMON
Sun May 27, 2007 11:55 pm
Im not using the default weather im using Flight 1's Flight Envirment. ?????
GoingAround
Mon May 28, 2007 2:28 am
Quoting LHRSIMON (Reply 5):
Im not using the default weather im using Flight 1's Flight Environment. ?????
Flight environment will provide the textures for things such as clouds etc. However it will not provide weather data (cloud coverage, visibility etc.) this will be provided either by FS (real world weather or pre-defined weather) or an external programme such as ActiveSky.
Are you setting the weather in the FS menu, or are you using real weather? Either provided by FS itself, or another programme?
Alex
LHRSIMON
Mon May 28, 2007 3:28 am
So to get real weather in "REAL WORLD WEATHER" i have to have Flight Enviroment AND Active Sky ???
Thx
SIMON
GoingAround
Mon May 28, 2007 6:30 am
Quoting LHRSIMON (Reply 7):
No  Wink
Both FlightEnvironment and ActiveSky provide the textures for clouds and sky colours. FS can provide real world weather. ActiveSky will produce enhanced real world weather.
You can get real world weather without either programme. FS can provide both, what FlightEnvironment and Activesky do it ENHANCE it  Smile
I answer to your original question:
In the real world, above the clouds, the visibility is usually much better then below the cloud canopy, this is due to things such as rain and lower lying cloud. So technically you would notice a dramatic difference between below the cloud and above the cloud. However, in the real world, there is very rarely only one layer of cloud, so the transition between these 2 stages is not as noticeable. In FS these many layers are not simulated in the default weather themes. To do this I would suggest making your own layers in the custom weather menu, and layering in around 3-5 different canopy's, each one with decreasing levels of cloud cover.
An example could be:
1000-4000ft - Thunderstorms (Overcast)
4000-5000ft - Thunderstorms (Scattered)
5000-6000ft - Cumulus (Scattered)
6000-6500ft - Cumulus (Few)
6500-7000ft - Stratus (Few)
Visibility:
5(km or miles, can't remember which FS uses) - 6000ft
Obviously this will differ judging on the effect you are wanting to create. This is only an example, I'm not sure how this would turn out exactly in FS however it is similar to the kinds of settings I use when creating thunderstorms.
I hope this clears things up for you,
Alex
wilax
Tue Jun 19, 2007 1:56 pm
The basic problem is the way FS9 renders visibility. Cloud cover is different from visibility and remains constant and varies only slightly as you move around. You see clouds at the horizon, fly past them, and then they disappear behind you. Visibility, in FS9 does not work that way. The sudden change that you observe is the visibility changing. In FS9 the degree of visibility is a fog that surrounds the user aircraft up to a certain altitude and out to a certain radius. You will never fly into or out of a different visibility. It just changes. You may notice, when you are at altitude, FL 270 or above, the weather may be clear all around you, but if you look straight down (keypad 5) you will see a fog near sea level. That fog travels with you in areas where visibility is low. As you fly into an area with unlimited vis. your fog will just disappear.
