rogerroger707
Help With Pss 757!
Fri Jun 08, 2007 11:44 am
I bought the PSS 757 about a half an hour ago and I loaded up a flight with the default flight planner using VOR to VOR and flying IFR. But the flight wasn't loaded into the on board navigation system and there isnt any way to use the GPS and cheat so I don't know what to do... I was gunna look for an answer in the PSS manual but I can't find it anywhere in my files.
Any help would be greatly appreciated!
thanks!
Eliot
autobrake max or hit the tracks!
QFA380
RE: Help With Pss 757!
Fri Jun 08, 2007 3:41 pm
Umm, well the PSS 757 is a very advanced plane cockpit wise. Its navigation systems are independant of FS9's.
I'm quite sure you didn't read the manual otherwise you would have realised that. If you did and you still didn't you should still be flying the default ones rather than the PSS 757.
Just a little constructive criticism.
David L
Sat Jun 09, 2007 12:09 am
I don't have the 757 but their A330/340 allows you to import an FS flight plan via a menu option on the MCDU. As QFA380 said, with such a complex model, you need to read the manual.  Smile
rogerroger707
Sat Jun 09, 2007 1:58 am
Quoting David L (Reply 2):
I know but I can't find the manual in my files.... Do you have any idea where it could be found?  Confused
David L
Sat Jun 09, 2007 3:51 am
I can't remember if the manuals came on the A330/340 CD - you could try their website, support section:
http://www.phoenix-simulation.co.uk/
rogerroger707
Sat Jun 09, 2007 4:27 am
Quoting David L (Reply 4):
They're on there! Thanks a lot!
David L
Mon Jun 11, 2007 12:35 am
Quoting Rogerroger707 (Reply 5):
No problem. Actually, I knew they were on there but I just wasn't sure if you already had them on the CD.
If you have access to a decent colour printer, print them out as you'll often need to refer to them while you're "flying".  Smile
rogerroger707
Mon Jun 11, 2007 10:10 am
Quoting David L (Reply 6):
print them out
Just did thanks for the idea
