LAXspotter
Kiah Ahd Eddf In Flight Simulator
Tue Jun 19, 2007 2:49 pm
Is anyone aware of a decent AFCAD for the two airports. I would like the AFCAD to be able to use crossing runways to make the airport free-flowing. Currently with EDDF operating with two runways, its really a mess, need your advice thanks.
"Patriotism is the last refuge of the scoundrel" Samuel Johnson
David L
RE: Kiah Ahd Eddf In Flight Simulator
Tue Jun 19, 2007 7:37 pm
Have you checked AvSim and FlightSim?
Burkhard
Tue Jun 19, 2007 8:59 pm
EDDF is rather hard to achieve cross wind support. Due to geometry, it only works if you close both 7s takeoff, so have takeoffs from 18/36 - and indeed if you clode the parallel ones, and wind comes from north, than 36 gets used even if closed.
atct
Thu Jun 21, 2007 2:43 am
I dont know how it works on AFCAD (or even if one is available for IAH)
But id suggest when you get one:
26R , 26L, 27 for Arrivals
Departing 15 R 15L
(Just make sure the runway lengths are up to date...some FS's have 15R being like 6,000ft...its since been widenned and extended).
ATCT
Trikes are for kids!
LAXspotter
Thu Jun 21, 2007 4:44 am
Quoting ATCT (Reply 3):
Departing 15 R 15L
Thats what Im trying to do, if i get that done, KIAH will be one smooth airport to fly into.
EDICHC
Thu Jun 21, 2007 8:44 pm
I know it is not the cheapest piece of payware, but have you considered Mega-Airport Frankfurt? If you have the hardware to support it, it is an amazing add-on! I also have KIAH on Just-Flight's World Airports 2, but as I don't use IAH very much I'm not sure if this meets your needs.
A300/319/320/346 ATR72 B722/732/3/4/5/6/8/742/4/752/762/3/772/3 BAC111 BAe146 C172 DHC1/6/8 HS121 MD80 PA28
jamesjimlb
Thu Jun 21, 2007 11:43 pm
whats is an AFACD file???
The sky is no longer the limit, but the mere minimum
Burkhard
Wed Jul 11, 2007 11:40 pm
AFCAD is a program by Lee Swordy that allows to modify FS8 airports. AFCAD2 is the version for FS9 airports. These modified airport bgls are called AFCAD files.
David L
Thu Jul 12, 2007 2:51 am
Quoting Burkhard (Reply 7):
Just to be clear, AFCAD files are FS files that define certain airport parameters, such as runway dimensions, surface type and orientation, taxiways, parking spots, navaids, but not scenery objects. Lee Swordy's program allows you to modify the FS9 versions (and earlier) but the last I heard was that he wasn't going to do a version for the FSX AFCAD files.  Sad
Burkhard
Thu Jul 12, 2007 6:21 pm
Yes, unfortunately Lee has left the scene after a short, but severe impact. I've created a way to use his program for FSX airports without any loss, and done more than 1000 airports this way up to now - but this obviously only is a poor mans solution until real FSX design programs appear on the market.
