ANITIX87
X-Plane Tips (and Flight-sim In General)
Wed Jun 20, 2007 3:50 am
Hello, all.
I've been using X-plane for a few months now, and my biggest complaint probably has to be ATC, and the manual's lack of completeness.
Firstly, and more importantly...
I was wondering how to use the FMS correctly. I love to do long flights across the Atlantic, but I have work every day, so normally I take off in the morning, put the destination into the FMS, put my bearing needly on the red line, and leave it on autopilot while I go to work. Then, when I come home, I'm 700 miles off course, adding an hour to the flight and just making it a dumb experience all around. I know some of the waypoints along the way, but I have two questions. On a real flight, how far apart are consecutive waypoints, and how would I use the FMS to make the aircraft fly the route I want, all on its own? Is this even possible?
In regards to ATC. They vector me in from cruise altitude, and usually I get a good ILS approach and they put me in line with the runway. But, sometimes, they make me guess. They tell me to contact the tower, and I have no idea what bearing I should be on. Sure, I could look at the charts, but shouldn't ATC be better? Also, what is a standard rate of descent for final approach? The glideslope is usually around -700 fpm, but I, very often, find myself just a hundred feet from the threshhold, 600 feet AGL, and I have to nose-dive straight down and pull up violently to get down in time. Again, would the only way to fix this be to look at approach charts?
Also, the planes I use seem to change appearance. Every time I make a flight, the fuselage gets blurrier and blurrier. On my BA777, you can no longer read the titles on the fuselage, and the tail is just a muddle of black lines (it's the Hong Kong world tail). Same with my other planes.
In regards to weather. I download Live Weather from the internet, but it doesn't seem to have it for anywhere but the USA. Or an I dreaming? Also, it seems that no matter what the weather is reported to be, I get down to 2000 feet and I can't see 5 feet in front of me. Even if I change the weather myself to be perfectly clear with 14 mile visibility, the same thing happens.
Thanks for any advice you can give me.
TIS
jogales
RE: X-Plane Tips (and Flight-sim In General)
Wed Jun 20, 2007 10:37 am
Quoting ANITIX87 (Thread starter):
To have the plane follow your desired route after you've programmed it into the FMS, switch the autopilot source selector to FMS or NAV (varies with different planes) Switch the autopilot on with the flight director switch by moving it to "auto" and turn on NAV or LOC autopilot (also depends on the model)
In regards to ATC.
X-Plane's ATC is rubbish and not worth using. If you want ATC, I'd suggest connecting to IVAO or VATSIM.
Go to settings/rendering options and change the texture resolution to high or very high. I'd also recommend using the 777 from XP Jets as it is much better looking and more accurately built than the default one as long as your computer can handle it. http://www.xpjets.com/
Real weather should work outside of the US...perhaps the weather reporting system that X-Plane uses is down where you're flying. As far as not being able to see 5 feet in front of you, it's probably because you have your rendering options set too high for your computer. X-Plane will reduce visibility when the framerate dips below 19 FPS to keep an accurate flight model. There's no way around it except lowering your rendering options or getting a faster computer. Turning off objects, roads, forests and the high detail world checkbox helps FPS a lot as does lowering the world detail distance to low.
Josh
ANITIX87
Wed Jun 20, 2007 10:05 pm
Quoting Jogales (Reply 1):
On the 777 I usually use, the SOURCE knob has NAV1, NAV2, and GPS as options. The autopilot has HDG and LOC. I assume I should be using NAV1 and LOC, right? Or should I use GPS for the source?
Along similar lines, I plan on flying DXB-ATL this weekend. Would this be a good route? All I did was look at a map of waypoints, and pick ones that look like they could be a realistic flight path.
GRD J209 RDU J209 ORF AR9 ZIBUT LARGE
JOBOC NATY MUDOS NATY STG UN725 BCN
UM601 ALG UM603 ROTUN UM728 VENTO UM601
GILOS UM601 BALMA R655 CAK J222 BASEM
R785 ZELAF UR785 RASLI UP559 BOTEP UP559
LOTIT A791 DESDI
Thanks.
TIS
jogales
Thu Jun 21, 2007 4:53 am
Quoting ANITIX87 (Reply 2):
GPS and LOC
I'd fly:
LOTIT A791 DESDI
as that is the route flown by a DL 772 operating DAL8 yesterday.
Josh
ANITIX87
Thu Jun 21, 2007 7:42 am
Thanks! Also, out of curiosity, is there a place I can go, online or elsewhere, to find a map of waypoints? I'd like to fly WAW-TLV, since I'm in WAW right now, but I don't know the waypoints on the way or anything like that.
TIS
jogales
Thu Jun 21, 2007 10:10 am
Quoting ANITIX87 (Reply 4):
Try here: http://www.flightsimaviation.com/_flight_planner.html
Josh
ANITIX87
Thu Jun 21, 2007 10:17 am
Thanks. I'll check that out.
Also, I downloaded a bunch of 777 from xpjets.com, and x-plane can't find them. It says the file is corrupt when I try to open it. Should I be doing anything particular with the folders that it gives me when I unzip the file? All I did was drag them into the Heavy Metal folder in the Aircraft directory of x-plane. What's going wrong?
TIS
jogales
Thu Jun 21, 2007 3:45 pm
Quoting ANITIX87 (Reply 6):
What version of X-Plane are you using? The XPJ 777 is made for 8.60, so make sure you have the latest version. Download the updater at X-Plane.com.
Josh
ANITIX87
Sat Jun 23, 2007 1:01 am
Hey, Josh.
I downloaded the update and I'm having a mass of problems. It's infinitely slower. The detail is good, but the plane doesn't respond. I put it on autopilot, and the autothrottle just stays at 101 percent, even when I'm at the speed I want. The heading hold doesn't work in HDG or LOC mode. And when I press the HDG or LOC button, the Altitude Hold comes up, but the number on the altitude turns into my present altitude. When I try to change it, the plane goes into oscillations, going up at +3000 fpm, losing speed until stalls, and then going to -3000 fpm. Once it hits the speed I had in the autothrottle, it starts to climb again, at 3000 fpm. And the cycle continues.
The plane won't follow the flight plan I give it, even at GPS and LOC, as you suggested.
If it matters, this is all with the BA 772 that comes in X-plane.
Also, when I try to enter a flightplan, it refuses to recognize some of the waypoints. The standard fixes like GITLA, KAROL, and the like are fine, but others, like three-letter ones or ones with numbers (J209, for example) don't show up on the flight plan. I also can't open the en-route map using CTRL-T anymore, and some of the other keyboard commands don't work either.
Any tips?
TIS
aabFlyer
Sat Jun 23, 2007 2:01 am
! was having some problems with X-Plane and a member kindly pointed me at X-Plane forums for help. Maybe you use the forums already but anyway here's the link:
http://forums.x-plane.org/index.php?act=idx
Cheers.
chksix
Sat Jun 23, 2007 2:34 am
I have to recommend the aircraft I'm co author on since it has a realistic Boeing autopilot simulation.
http://www.stratmann-web.net/xplane/Home.html
Check the BBJ's out : http://www.stratmann-web.net/xplane/Boeing_737-BBJ_v8.html
Also, whenever you update the sim or start having troubles, delete the contents of the Prefernces folder. New prefs will be created on restart.
[Edited 2007-06-22 19:36:08]
The conveyor belt plane will fly
jogales
Sat Jun 23, 2007 4:21 am
Quoting ANITIX87 (Reply 8):
Try looking at this page for help with the autopilot. It changed significantly in 8.60. http://home.earthlink.net/~x-plane/FAQ-Autopilot-V86.html
Josh
ANITIX87
Sat Jun 23, 2007 9:36 am
According to the Circle Mapper, JFK-GVA is 3863 nm.
I went to that flight planner site you linked me to and it gives me a route literally twice that length. It vectors me, instead of a bearing along the lines of 060, which is the direction in which GVA is located, along a vector of 160 degrees. It does that for about 4000 nm, until suddenly vectoring me at 40 degrees for another 1000nm, then 60 degrees for the last 1000nm. This is, obviously, a completely unrealistic route, and while I have figures out how to fly such a flight plan now, I am wondering what I should do? Anywhere else I can get a flight plan that will actually be realistic? A free on? Can I change my parameters on the site I've used already to get a better route?
chksix
Sat Jun 23, 2007 5:47 pm
Did you try the free Route planner http://rfinder.asalink.net/free/ ? It sometimes builds strange routes too. You have to enable NATS to get correct atlantic tracks.
ANITIX87
Sun Jun 24, 2007 4:14 am
Quoting Chksix (Reply 13):
I tried this site and it wouldn't load. So I decided to use the other one. But that wouldn't load either. And then I meant to go back to the one you recommended and I got to the one I'd previously used. Or so I thought. They are, believe it or not, the same thing. If you go to the site Jogales recommended, and you look at the HTML source code, you'll see they just use the site you recommended and insert it into the webpage as an iFrame.
So, I'm still having a problem with routing, until one of the sites will load correctly.
TIS
san747
Sun Jun 24, 2007 12:48 pm
For the record (and I didn't even realize this until a few months ago), three letter waypoints are always VORs and waypoint starting with J isn't actually a waypoint at all. It's a jet airway. Therefore, if the flightplan calls for J209, just add in all the fixes ALONG that jet airway.
The only reason it's listed as J209 in the flightplan is to abbreviate. Otherwise, you'd have to list all the individual fixes when filing a flightplan to ATC...
Scotty doesn't know...
ANITIX87
Mon Jun 25, 2007 1:44 am
Thanks.
Where can I find all the waypoints along a given Jetway? I've been using FlightAware to get plans of real flights, but, as you said, they always use the abbreviations, and I wouldn't know where to get the appropriate waypoints.
TIS
ANITIX87
Sat Jul 07, 2007 1:37 am
Ok, so I'm using GoodWay, along with the site you guys recommended, and it's working quite well.
More questions...
1) How do I use autoland? I'm curious to see how well it will work, but I can't get my plane to intercept the G/S.
2) It seems like every flight I make, at some point, I'll be cruising at FL330, IAS mach .87, and all of a sudden, my engine thrust will disappear, though the levers still indicate 99%. My IAS will go down to like 80kts and the stall warning goes off. It happens EVERY flight about 3 hours in.
TIS
jogales
Sat Jul 07, 2007 2:52 am
Quoting ANITIX87 (Reply 17):
1: Look at the local map in sectional mode with the "show all ILS" button checked to get the correct frequency if you don't already have it. Put that frequency into your nav1 radio and make sure the autopilot selector knob is set to nav1 and flight director switch is set to auto. Turn on LOC and G/S autopilot modes.
2: Mach .87 is a bit fast. Normal cruise for an airliner is somewhere between 0.79 and 0.85. About 3 hours into your flight sounds like you might be running out of fuel. Make sure you have enough to complete your flight before you take off. Fuel loads can be adjusted in the settings/weight&balance&fuel menu. 99% throttle is high. 90% or less should be all that's needed depending on weight. You'll use a lot more fuel down low at FL330 with 99% power than you will at FL390 with ~90% power.
Josh
ANITIX87
Sat Jul 07, 2007 3:54 am
Quoting Jogales (Reply 18):
Thanks. Will try when I get home! I have to approach the G/S from below, correct? Will the plane and and apply braking, speed brakes, and reverse all on its own?
[quote=Jogales,reply=18]2: Mach .87 is a bit fast. Normal cruise for an airliner is somewhere between 0.79 and 0.85. About 3 hours into your flight sounds like you might be running out of fuel. Make sure you have enough to complete your flight before you take off. Fuel loads can be adjusted in the settings/weight&balance&fuel menu. 99% throttle is high. 90% or less should be all that's needed depending on weight. You'll use a lot more fuel down low at FL330 with 99% power than you will at FL390 with ~90% power.
I always make sure I have enough fuel. The other day, for example, flying HNL-IAH, it happened 3 hrs in, and I still had 7.2 hrs of fuel left at FL330 and 84% thrust. Normally, if I go to Fail Equipment and click "Reset Operational" or whatever it says, nothing changes. The only thing I have found effective is dropping to a lower altitude at full thrust to get my speed back, and then things seem to go back to normal. I also notice that, when it happens, the horizontal stabilizer goes to the full UP position, I assume to avoid a stall, though I can't be sure.
Any other ideas?
TIS
[Edited 2007-07-06 20:54:45]
[Edited 2007-07-06 20:57:24]
chksix
Sat Jul 07, 2007 8:05 am
The problem with the dropping thrust could depend on the aircraft or the new busted xplane autopilot.
I forgot to mention that you should turn off all AI flown aircraft in the aircraft & situations screen to allow the cpu to use all it's power to fly your plane and draw the environment.
Also set your MTBF time to 99.9999999 etc to avoid inflight problems caused by unrealistic faults. (parts of aircraft falling off)
What plane and version of the sim do you use?
ANITIX87
Sat Jul 07, 2007 9:04 am
Quoting Chksix (Reply 20):
8.40, I almost always fly the 772 that's provided. I tried upgrading to 860, but it didn't work at all, and I didn't like some of the changes. So I'm sticking to 840.
TIS
chksix
Sun Jul 08, 2007 5:40 am
Take a look at this forum for free aircraft that are compatible with older versions of xplane:
http://www.xplanefreeware.net/forums/index.php?act=idx
mdodd
Thu Jul 12, 2007 6:51 am
Funny I fly in the 777 provided with X-Plane, version 8.6 and seem to have no issues like your describing. Possibly something on your end? Have you tried doing some simple maintenance to X-Plane? What are you running?
ANITIX87
Thu Jul 12, 2007 7:04 pm
Quoting Mdodd (Reply 23):
Version 8.6 was a big update, with completely changed AP. I tried running it, and found that for some reason, my computer complained even more. I'm using a G4 iBook (15") with OS 10.3 1.07GHz Power PC and 512MB DDR SDRAM.
TIS
Users browsing this forum: No registered users and 4 guests
