LY777
Please, How To Activat The Thrust Reverser On FSX?
Thu Jun 21, 2007 12:58 am
Hi all,
I am not able to activate the thrust reverser on FSX, can someone explain me how to use it, please?
Also, when I arm spoilers for landing, they don't deploy during touchdown, I don't understand
thanks for your answers
regards
sacha
NWADC9
RE: Please, How To Activat The Thrust Reverser On
Thu Jun 21, 2007 4:14 am
Throttle back, F2
Message too short because Airliners.net doesn't like "Short-n-Sweet"
I get paid to convert dead dino juice into noise.
jamesbaldwyn
RE: Please, How To Activat The Thrust Reverser On FSX?
Thu Jun 21, 2007 4:38 am
For the spoilers you have to 'ARM' them. In the case of the 738 you open the engine panel and find the speed brake, drag it down to about 1/4 of the way where it says ARM and when you land and start the reverse thrust, she will stop a little faster  Smile
Happy Flying!
jamesbuk
Thu Jun 21, 2007 5:31 am
Quoting Jamesbaldwyn (Reply 2):
Cant you press shift + / like in FS9? Or is FSX less advanced  Wink Also i believe, if its like FS9, there is an assignment to assign that can dump all the throttle which in theory should make it go into reverse thrust.
Rgds --James--
You cant have your cake and eat it... What the hells the point in having it then!!!
QFA380
Thu Jun 21, 2007 7:50 am
Quoting Jamesbuk (Reply 3):
I think its F1, but that puts you back to idle. So as your coming in, you hit F1 passsing over the threashold and then press F2 a couple of times to get the reversers happening.
tbanger
Thu Jun 21, 2007 6:15 pm
Yes you can.
LY777
Sun Jun 24, 2007 6:48 am
And also I would like to know how to open cargo doors on FSX, please
Longhornmaniac
Mon Jun 25, 2007 5:20 am
If the plane has cargo doors, press Ctrl + E + 2. It's a bit picky with the timing sometimes, but keep trying it, and you'll get it. Oftentimes, with third party manufacturers, the airplane designer will assign the cargo doors to the "Tailhook" or "Wing Fold" function, so make sure you have keystrokes assigned for those as well.
Hope this helps.
Cameron
Cameron
NWADC9
Mon Jun 25, 2007 12:06 pm
Quoting Longhornmaniac (Reply 7):
You mean Shift+E 2/3/4  Wink
Longhornmaniac
Mon Jun 25, 2007 1:26 pm
Quoting NWADC9 (Reply 8):
 banghead  Yes. That is what I mean.  Smile Thanks for the correction!
Cameron
Cameron
LY777
Tue Jun 26, 2007 12:16 am
I have tryed it on both 738 and 744, and only the main doors open, not the cargo doors
ajd1992
Sat Jul 07, 2007 2:11 am
Sometimes they don't open because they weren't built into the model... Some do, some don't.
Anyway, to get the reverser engaged, idle the power, and hold F2 until you hear the roar.
For arming the spoilers, press Shift + /. Then when you land, they'll deploy automatically.
