Mike89406
Question About FS2004 Reverse Mode.
Wed Aug 08, 2007 6:00 am
Does anyone know how to make the jets go in reverse like a pushback. For example-I thought you could go in reverse by setting the Autobrake to RTO and throttling up. But that doesn't seem to work.
I've been playing FS as long as I can remember and I don't remember how to move back in reverse. Does anyone know how to do it?
Thanks Mike
aace24
RE: Question About FS2004 Reverse Mode.
Wed Aug 08, 2007 6:06 am
Pretty simple, just do Shift + P and then do the same to stop pushback.
jamesbuk
Wed Aug 08, 2007 8:43 am
RTO is Rejected Take Off and it should be in this mode during the take off run, so that if you reject the take off then it will hit the brakes full it doesnt help/make you reverse.
To reverse you just press Shift P and either 1 or 2 in quick succesion for which direction you want to turn. For example to turn 90' anitclockwise you would pres Shift+P then 2.
rgds --James--
You cant have your cake and eat it... What the hells the point in having it then!!!
ACDC8
Wed Aug 08, 2007 5:39 pm
As in the above posts, use SHIFT + P for a push back, then press it again to stop the push back (make sure your brakes are off). You can also do a power back if you want, just press F2 to engage the thrust reversers.
A Grumpy German Is A Sauerkraut
Mike89406
Wed Aug 08, 2007 11:22 pm
Quoting AAce24 (Reply 1):
Shift + P
Quoting Jamesbuk (Reply 2):
Thanks that helped.
Quoting ACDC8 (Reply 3):
Thanks thats sorta what I was looking for as well because I use a joystick on my game, and that gives me another option.
Gotcha so RTO is full ground brakes, speaking of which is there a air brake feature in FS 2004?
WestJetForLife
Thu Aug 09, 2007 8:41 am
Quoting Mike89406 (Reply 4):
Air brakes are generally known as spoilers. They help decelerate the aircraft as it begins its descent for landing (could be for numerous reasons: slowing down to prevent overspeed, to aid in reaching 250 knots before crossing below 10,000 feet, to help descend quicker, etc.)
Generally, the spoiler lever will be on the left-hand side of the throttle quadrant. Use it only during approach and landing, and you should be good.
Nik
I need a drink.
Longhornmaniac
Thu Aug 09, 2007 11:51 am
Use the / key (the one with the Question mark) to deploy the spoilers, and press Shift + / to arm the autospoilers, which will engage when you hit the ground.
Another thing, with the pushback, if you press Shift + P, followed by 1 or 2, it will turn the nose 90 degrees left or right, depending on the perspective. If you are looking from the front of the plane to the back, 1 will turn the tail right, and two will turn the tail left. Obviously, if you are sitting in the cockpit looking forward, 1 will turn the tail to the left (the easy way to remember is 1 is left of 2), and two will turn the tail right. If you don't want to go the whole 90 degrees, just press Shift P once to stop it, and press it again to keep moving straight. For example: if you wanted to turn the tail right (looking forward) 45 degrees, you would press Shift + P, followed by 2 (not the two on the number pad, but rather above the letter keys), until it gets to your desired angle, then press Shift P again to stop moving, then again immediately to start moving on the line you are on. If you do it quickly, you won't even stop moving.
Hope this helps!
Cameron
Cameron
