BAW076
FS9 Causing Internet Connection Drop, Please Help!
Thu Aug 09, 2007 7:59 pm
Hi guys,
Over the past 4 or 5 days, whenever I have had FS9 running, my internet keeps disconnecting.
This is just when the program is running as normal without Real World Weather. It's never done this before, but as I say, the past 4 or 5 days it is just constantly disconnecting. I can only get my internet connection back when I reboot my PC, which is a pain in the rear end if I am in flight.
I have done system restores a few times to before this problem was occuring but to no avail. I've also done virus scans and spyware removal and registry cleans, but to no avail.
My internet is fine when FS isn't on. But I turn FS9 on, and within about 5 minutes, my net connection is lost.
This is SERIOUSLY bugging me now...
Any help much appreciated.
Chris  wave
N754AN (x2), G-CPEL, G-MIDE, G-BPEC, G-BZHC, EI-DCH, LN-KKN, G-VIIW, G-BNLT, G-DBCA, G-MEDE, G-DBCE, G-MIDP.
PAHS200
RE: FS9 Causing Internet Connection Drop, Please Help!
Fri Aug 10, 2007 5:50 am
did you try not using the real world weather does it still drop out?
BAW076
Fri Aug 10, 2007 7:04 am
Quoting PAHS200 (Reply 1):
Did you read what I wrote properly?
Quoting BAW076 (Thread starter):
LTU932
Fri Aug 10, 2007 11:14 am
It's happened to me once. All I did was powercycling first the modem, and then the router. If possible, try to powercycle (first shutting it down by pulling the plug, then turn it back on) your modem and router (if available) as well. It helped in my case.
BAW076
Fri Aug 10, 2007 11:54 am
I tried that hundreds of times, it didn't fix the problem  Sad
LTU932
Sat Aug 11, 2007 8:16 am
Quoting BAW076 (Reply 4):
In that case, all you can do is talk to your ISP about this, because there has to be something that is killing the connection when running FS, and perhaps only they may know what it is exactly.
AirPacific747
Sat Aug 11, 2007 9:00 am
Did you also try to reinstall FS?
BAW076
Mon Aug 13, 2007 7:00 am
Quoting AirPacific747 (Reply 6):
I have uninstalled and reinstalled both FS2004 and AOL, but it is still doing it.
