PAHS200
RFP V2 Free!
Fri Aug 17, 2007 10:03 pm
http://www.panelshop.com/OPS_RFP/RFP_Files.htm
one of the best payware a/c for FS is now FREE... only works with FS2004
LTU932
RE: RFP V2 Free!
Sat Aug 18, 2007 12:41 pm
Hopefully there will be a merge available, so I can merge the RFP panel with the POSKY v4 model.
flymia
RE: RFP V2 Free!
Sat Aug 18, 2007 3:11 pm
Yea I rember buying this plane in the summer of 04. It is a great add on very realistic, and you have to love the random flame outs and engine fires. All the systems of the 742 its a great plane. I remember the one of the guys at paneshop gave me a free download of the aircraft when my computer crashed a year ago. They were very nice about letting me download the plane again for free. Great to see a product like this out for everyone and its a top of a line product worth more than $20 and now free! If you like real classic flying this is a must have!
JohnKrist
Head Support
RE: RFP V2 Free!
Sat Aug 18, 2007 4:09 pm
Quoting LTU932 (Reply 1):
I'm not sure I understand you, ofcourse you can't use the VC, but the 2D panel should be no problem?
5D Mark III, 7D, 17-40 F4 L, 70-200 F2.8 L IS II, 50mm 1.4, EF 1.4x II, EF 2x III, SPEEDLITE 600EX-RT
QFA380
RE: RFP V2 Free!
Sat Aug 18, 2007 9:15 pm
I've just downloaded this package, I must say absolutely awesome. I never really thought about buying it off Justflight and now that its free I thought might as well. I'm finding it much more enjoyable than flying the Level-D as its more hand-ons flying, scary how advanced they were in the 60's.
[Edited 2007-08-18 14:32:34]
LTU932
RE: RFP V2 Free!
Sun Aug 19, 2007 11:49 am
Quoting JohnKrist (Reply 3):
Sometimes the panel is finetuned to a particular visual model. Hence why it is necessary to adapt the flight dynamics in order for a panel to work. That's a merge in FS basically. So I can't just use the model with the RFP panel just like that.
jetmatt777
RE: RFP V2 Free!
Sun Aug 19, 2007 12:05 pm
So is RFP include just a panel? or does it include the model aswell?
Also, if it does include the model, what model's are availiable? I can't find what aircraft is available from their website, if any.
Matt
Lighten up while you still can, don't even try to understand, just find a place to make your stand and take it easy
QFA380
RE: RFP V2 Free!
Sun Aug 19, 2007 1:11 pm
Quoting Jetmatt777 (Reply 6):
Its the entire plane. Boeing 747-200 for pax and cargo.
Here is the avsim link http://library.avsim.net/esearch.php?CatID=fs2004pan&DLID=108200
jetmatt777
RE: RFP V2 Free!
Sun Aug 19, 2007 1:37 pm
Just the 742?
thanx for link
Qantas744er
RE: RFP V2 Free!
Sun Aug 19, 2007 6:23 pm
Just checked out the Posky forum... that idiot of Warren just shut down the topic regarding the merge
Quoting him:
The Opensky plane was not developed for, nor tested with,
the RFP panel, although it should work.
User edits and merges are not supported. Swaping parts
are certainly not supported. Also, we don't Opensky
vs. PMDG vs. RFP posts here.
Sorry guys, I'm going to have to shut this one down.
We cannot be responsible, nor predict what happens
when users start to mis-and-match parts.
Please email each other, and do not upload your merges.
Thanks,"
This guys is seriously a idiot. He cant accep the fact that Posky 747's have no decent panels and so does not want his planes to get compared with others bla bla bla. I dont undestand where he sees a problem merging RFP Panel and Posky 747..
Anyways now that nobody will upload it from over there i will get the merge and upload it myself to Avsim.
Sorry Warren
If you want the merge send robbie from this discussion http://forum.projectopensky.com/inde...c=14697&st=0&p=125035&#entry125035 a PM he will bee happy to send it to you!
Leo
[Edited 2007-08-19 11:32:58]
You live and you die, by the FMA
Qantas744er
RE: RFP V2 Free!
Sun Aug 19, 2007 6:39 pm
Merge:
Follow the steps carefully!
1/ Go to any one of the RFP Freighters (located in your aircraft folder).
A/ Copy the "panel" folder & paste it into any of the Posky freighter aircraft. (Let windows overwrite any files that were already there.)
B/ If you want to use the new RFP sounds then you should do the same for the "sound" folder.
C/ Go into the RFP model folder and copy the freighter.mdl file and paste it into the Posky model folder. (Do not copy the model.cfg file!)
2/ The aircraft.cfg, the airfile, and the 2 .txt files to the posky aircraft folder. Overwrite the aircraft.cfg
replace the following categories with the provided data:
Contact points
Flap settings
Lights
Smoke System
Copy to Aircraft.cfg
point.0=1, 66.8, 0.0, -13.833, 1574.8, 0.000000, 5.826899, 70.0 ,0.700, 0.610, 0.518, 14.000000, 14.000000, 0.000000, 0.000000, 0.000000
point.1=1, -20.5, -17.3, -15.533, 1574.8, 1.000000, 5.826899, 6.0 ,2.520, 1.000, 0.651, 18.000000, 18.000000, 2.000000, 0.000000, 0.000000
point.2=1, -20.5, 17.3, -15.533, 1574.8, 2.000000, 5.826899, 6.0 ,2.520, 1.000, 0.651, 18.000000, 18.000000, 3.000000, 0.000000, 0.000000
point.3=2, -70.7, -102.0, 6.0, 1574.8, 0.000000, 0.000000, 0.000000 ,0.000000, 0.000000, 0.000000, 0.000000, 0.000000, 5.000000, 0.000000, 0.000000
point.4=2, -70.7, 102.0, 6.0, 1574.8, 0.000000, 0.000000, 0.000000 ,0.000000, 0.000000, 0.000000, 0.000000, 0.000000, 6.000000, 0.000000, 0.000000
point.5=2,-126.6, 0.0, 5.8, 1574.8, 0.000000, 0.000000, 0.000000 ,0.000000, 0.000000, 0.000000, 0.000000, 0.000000, 9.000000, 0.000000, 0.000000
point.6=2, 66.8, 0.0, 5.8, 1574.8, 0.000000, 0.000000, 0.000000 ,0.000000, 0.000000, 0.000000, 0.000000, 0.000000, 4.000000, 0.000000, 0.000000
static_pitch=1.00
static_cg_height=13.625
gear_system_type=0
Modified Flap settings
type = 1 // 1 - tail, 2 - lead
span-outboard = 0.5 // 0.0 .. 1.0
extending-time = 49 // seconds
flaps-position.0=0.000000,0.000000
flaps-position.1=6.665409,0.000000
flaps-position.2=13.330818,0.000000
flaps-position.3=19.996227,0.000000
flaps-position.4=26.661636,0.000000
flaps-position.5=33.327045,0.000000
flaps-position.6=39.992454,0.000000
damaging-speed = 200 // KIAS
blowout-speed = 250 // KIAS
lift_scalar = 0.23
drag_scalar = 1.00
pitch_scalar= 1.00
system_type = 1 //Hydraulic
span-outboard = 0.2
lift_scalar = 0.23
drag_scalar = 1.000
pitch_scalar=-15.00
type= 2
span-outboard= 0.800
extending-time= 3.000
system_type= 1
damaging-speed= 250.000
blowout-speed= 300.000
lift_scalar=-1.00
drag_scalar= 0.000
pitch_scalar=-15.25
flaps-position.0= 0.000, 0.000
flaps-position.1= 0.500, 0.000
flaps-position.2= 1.000, 0.000
type= 2
system_type= 1
lift_scalar=-1.00
drag_scalar= 0.000
pitch_scalar=0.00
flaps-position.1= 0.000, 0.000
type= 2
system_type= 1
lift_scalar= -0.2
Modified Lights
light.0 = 1, 65.200, 0.600, 19.100, Opensky_beacon ,
light.1 = 1, 13.900, 0.000, -7.080, Opensky_beacon ,
light.2 = 2, -41.600, -94.400, 8.800, fx_strobeh ,
light.3 = 2, -41.600, 94.400, 8.800, fx_strobeh ,
light.4 = 3, -122.3, -0.250, 12.300, Opensky_nav_yellow ,
light.5 = 3, -122.3, 0.250, 12.300, Opensky_nav_yellow ,
light.6 = 2, -121.5, 0.000, 11.450, fx_strobeh ,
light.7 = 3, 83.55, 0.000, 14.850, fx_vclighth ,
light.8 = 9, -111.1, -4.500, 43.750, Opensky_wing_light , // <-----3 previously
light.9 = 9, -111.1, 4.500, 43.750, Opensky_wing_light , // <-----3 previously
light.10= 5, 17.7, -29.200, -2.000, Opensky_nacelle_refl ,
light.11= 5, 17.7, 29.200, -2.000, Opensky_nacelle_refl ,
light.12= 5, 50.9, -11.700, 0.000, Opensky_nacelle_refl ,
light.13= 5, 50.9, 11.700, 0.000, Opensky_nacelle_refl ,
light.14= 5, 56.9, -13.700, 1.900, Opensky_nacelle_refl ,
light.15= 5, 56.9, 13.700, 1.900, Opensky_nacelle_refl ,
light.16= 5, 83.067, 0.000, -2.000, Opensky_nacelle_refl ,
light.17= 3, 79.1, -6.500, 6.000, Opensky_nacelle_refl ,
light.18= 3, 44.79, -4.500, 6.000, Opensky_nacelle_refl ,
light.19= 3, -47.11, 0.000, -3.000, Opensky_wing_light ,
Edit in the smoke system
smoke.0=0, -29.767, -86.167, Opensky_vortex
smoke.1=0, -29.767, 86.167, Opensky_vortex
ClearedDirect
RE: RFP V2 Free!
Sat Aug 25, 2007 11:51 pm
I downloaded the free version - read through just about everything and cannot locate the Passenge/Cargo loader nor the Takeoff calculator. The documentation mentions that it is on my desktop, but that is just not the case. I only have two icons that appeared on my desktop - "Where are the Manuals"" and "RFP Update"
Any help would be appreciated.
ClearedDirect
RE: RFP V2 Free!
Sun Aug 26, 2007 12:05 am
Nevermind all.
Found the additional files in their forum.....
