AA388
How To Land In FSX
Mon Sep 17, 2007 9:58 am
Has anyone else noticed that it is really hard to land in FSX? I watch all these videos on youtube and the planes sort of glide to the runway. How do you do that?
-max
Flown on A319, A320, A321, A330-200, A340-300,600, 717, 737-3,5,7,8,9, 747-400, 757-2, 767-300, 777-200
B727-200
RE: How To Land In FSX
Mon Sep 17, 2007 10:55 am
Lot's of practice, a good game controller and possibly using the ILS where available Big grin
I have noticed it is a little harder to land by stick on the bigger jets than in FS9 - anyone else think it is a little more difficult?
B727-200.
clewatcher
Mon Sep 17, 2007 10:56 am
practice will make it easier
but for me, its mostly dumb luck  Smile
-Raymond
bongo
Tue Sep 18, 2007 11:57 pm
I think it´s easier to land a real plane than to land an FS plane  Sad
MDE: First airport in the Americas visited by the A380!
Delboy
Wed Sep 19, 2007 12:36 am
I would suggest using autothrottle, it's one less thing to worry about. It sounded like a hot air balloon, power up, power down, power off!
Nice landing though.
ACDC8
Wed Sep 19, 2007 4:13 am
Quoting Bongo (Reply 3):
I find it is. I've got way more hours in FS then I do with my actual licence and I still have problems with landing in FS. I find that you just don't have the sensations of movement or actual depth perception in FS as you do in the real world. Even landing with the ILS, FS just doesn't give you that sense of movement that I find helps me land (and fly in general).
A Grumpy German Is A Sauerkraut
Adman737
Wed Sep 26, 2007 4:38 am
Yup i agree it is harder to land on FSX due to the sensations of flight you need have but i have pretty much mastered take off and landing i fly PHF to CLT daily at least 3 or 4 times a day and its nothing for me to land anymore. But it wasnt that easy when i forst got FSX i had a real hard time landing.
jamesbaldwyn
Wed Sep 26, 2007 6:49 am
I feel the same way. I make great landings in real GA. But on FS it's a diffrent story.
jamesjimlb
Tue Oct 02, 2007 10:47 am
Quoting Jamesbaldwyn (Reply 7):
oh man, then i must be awesome at real planes. lol
Quoting CLEwatcher (Reply 2):
no offense but that was a pretty bad landing. no flair just straight down, the struts would of been damaged.
The sky is no longer the limit, but the mere minimum
chksix
Tue Oct 02, 2007 5:36 pm
It's easier if you can find the Ref speeds to fly at each flaps setting and try to cross the threshold at Vref +5kt.
Retard the throttles to Idle over the threshold and flare at 20 ft by just a small amount. Don't float!
The conveyor belt plane will fly
clewatcher
Thu Oct 04, 2007 10:48 pm
Quoting JamesJimlb (Reply 8):
gotta start somewhere
-Raymond
bok269
Sat Oct 06, 2007 4:06 am
DOnt jump into the airliners right away. You need to master the basics of flight in a small aircraft (cough 172 cough cough). Do the lessons in the learning center, read up on it, etc.
You have to learn to walk before you run.
"Reality is wrong, dreams are for real." -Tupac
albird87
Sun Oct 07, 2007 1:33 pm
Quoting B727-200 (Reply 1):
Hmm im not sure about the 747 in FSX but i find that the A320 when flaps fully deployed and gear down, using my stick the response is sluggish... Now I normally try to approach the runway at 140-150 depending on my loads and i always find the aircraft very slow to respong to my controls. Is this normal in real life also??
Infact after the aircraft is aroun 120-130 just before touchdown the plane seems to become very reactive to anymoves i make.
Anybody else get this also or is it just me??
BAH!! call that a landing!! Real men do it from the cockpit!!
bok269
Sun Oct 07, 2007 2:48 pm
Quoting Albird87 (Reply 12):
I think it has something to do with the Airbus FBW system. I believe that the computer has to approved all inputs before the surfaces are deflected. ANyone feel free to confirm/correct.
jamesjimlb
Mon Oct 08, 2007 7:57 pm
Quoting CLEwatcher (Reply 10):
very true, and i apoligize for my statement.
UltimateDelta
Tue Mar 25, 2008 11:20 pm
A joystick makes it easier. i tried it with the mouse control, which is fiendishly hard. After I got my joystick, I noticed a definite change in ease.
Midwest Airlines- 1984-2010
Zuluaviator994
Wed Mar 26, 2008 12:57 am
I feel the same way. I make great landings in real GA. But on FS it's a different story.
I agree, the sensation of flight is missing greatly on Flight Sim, which makes a difference I guess.
Quoting Chksix (Reply 9):
Yes, correct, but you can't really find an accurate Vref Speed (at least I can't), so it's quite difficult.
I would suggest fine tuning your control sensibility, because if your controls are too light you will crash definately because you will end up in a 90 degree nose dive with the slightest touch. If your controls are too heavy, you will not be able to pull up or down OR flare, which CLEWatcher could work on, he still had a little one though.
If Speed is life, Altitude is life insurance. No one has ever collided with the sky.
JCH
Wed Oct 01, 2008 12:33 am
 Smile
ANITIX87
Wed Oct 01, 2008 2:36 am
Many real pilots have posted above that landing a flight-sim aircraft is harder than a real one, and that the sensations just aren't there.
I'm curious what you all think of the physics, handling, and ease of flight in X-plane, since that's what I use.
TIS
jetmatt777
Support
Wed Oct 01, 2008 4:24 am
I still use FS9. But landing is the one thing that cannot be tought. It's more of an art than it is a science.
I remember using autoland (approach hold) and autothrottle to 'land' the plane. But since, I hardly ever do ILS approaches anymore, unless weather is pretty bad. I am one that really loves visual approaches. It makes you feel in control and knowing your aircraft, then watching some needle tell you when you are good. Most of the time, I land right on the centerline, about 1,250 down the runway, which is about 300 or 400 feet past the aiming boxes at an average of around -125 ft/min or so, which is not too shabby. Not to brag, but the only thing that will help landings is actually doing them. You can read all of the books in the world, but if you don't learn to feel the aircraft (hard to do in FS), then those books won't help you.
Most people who land a little rough like me saying this: The airplane should be flown onto the runway rather than floated and make a soft landing.
A harder landing is a safer one. (WITHIN reason)In your average commercial twin-engine jet, A -500 ft/min will ultimately destroy your landing gear, a -350 will probably bust a few bolts on the gear and give your pax a bit of a headache. A -250 is a firm, but safe landing, A -200 is just about perfect, A -150 is a still pretty perfect, A -100 is moving into unsafely floating, A -50 is not good, and lower is not good either. They may be comfortable, but a floated landing uses up precious stopping room, what if your brakes go out and you only have 5000 ft. of runway left? If you have 7,000 left, you may have enough room for momentum to die out before you reach the last turnoff. But, in FS unless you have failures set, then you don't have to worry about that, but if you have a program that randomly generates failures without you telling it to fail something, you might end up in the trick-bag.
Practice makes perfect when it comes to landing.
-Matt
Lighten up while you still can, don't even try to understand, just find a place to make your stand and take it easy
MidEx216
Wed Oct 01, 2008 4:51 am
Quoting ACDC8 (Reply 5):
I actually have to disagree. While I do believe it is hard to feel what's going on with the plane, and you don't have the added crutch of seeing around you, I'd say a real plane is far harder than Flight Simulator. I've done crazy landings, including doing a half-cuban off the runway, and diving straight towards the threshold with the flaps and spoilers out, and flaring out right onto the runway. Yet, it still stresses me to try to get a good landing off in a Cessna 152. I've left my share of marks, and had my share of go-arounds.
zappbrannigan
Thu Oct 02, 2008 1:31 am
In most cases I probably have to agree with ACDC8. I find conducting a visual approach in a real aircraft very "natural" - even without any glideslope/VASI etc. reference, you constantly have a good idea of whether you're above or below the ideal profile, and whether the aircraft is set up to maintain that profile. In FS it's harder to "feel" your way to the runway, so to speak.
At threshold height in a real aircraft, you are very aware of where the runway is, and you can comfortably fly it through the flare and landing, again "feeling" your way to the tarmac. If you've under or over-flared a bit, you'll feel this and compensate. I find flying, say, the C172 in FS, I'll flare too high, and because I have no real idea exactly how far the runway is below me, end up stalling onto the tarmac, still 8-10 feet in the air.
I completely agree though, the other side of the coin is you can get away with FAR more in FS than you can in a real aircraft. I'd say in general, FS is not so much harder, as far less intuitive.
babybus
Sun Oct 05, 2008 11:08 am
I found it almost impossible to any aircraft in FSX. I would get to about 500 ft from the runway then the "Pull up!" siren would go. Even without the siren the plane would just float over the runway despite whatever I did and I could never land.
I've gone back to FS9. It works every time.
and with that..cabin crew, seats for landing please.
