jetmatt777
Crew
Design Your Own Airport! V2
Wed Oct 31, 2007 11:08 pm
Based off of a similar thread by COEWR777 that eventually faded out and went old.
Here is the new thread, new objects, different points etc.
You will be given 15000 points to begin with. You use these points to build everything to build a complete airport as big or as little as you want. If someone else adds flights to your airport, you get 100 points per flight. To add flights you must have airlines, when you add a flight you lose 15 or 20 points depending on what type of flight it is, Domestic or International.
Lets say player ABC adds flight to XYZ, the player that operates XYZ earns 100 points, and the person who added the flight loses 15 or 20, depending on the flight. To add a flight to an airport with a player operating it, you must have an agreement with the player from that airport to add the flight. For airports with no players operating them, obviously no agreement is to be made, so add the flight at your discretion.
To add an airline, it will cost you 150 points.
Objects
Runway (11,000 ft) - 500 points each
Runway (9,000 ft) - 450 points each
Runway (7,800 ft) - 350 points each
Runway (5,500 ft) - 250 points each
Runway (3,000 ft) - 100 points each
Control Tower - 500 points
Domestic gate - 100 points each*
International gate - 125 points each
Customs Facility - 200 points each
Security Checkpoint - 100 points each*
Above Ground Tram - 3500 points
Above Ground Tram Station - 150 points each
Below Ground Tram - 4500 points
Below Ground Tram Station - 350 points each
Cargo Building - 400 points each
Ground Service Equipment Building - 100 points
Fire Station - 150 points* each
Military Ramp - 500 points
General Aviation Ramp 1 (25 parking spots for small G.A.) - 200 points
General Aviation Ramp 2 (50 parking spots for small G.A.) - 400 points
General Aviation Ramp 3 (75 parking spots for small G.A.) - 600 points
General Aviation "T" Hangars (10 total slots) - 20 points each
Administration building - 200 points each
Parking Garage (2500 spots) - 300 points each
Parking Lot (1,500 spots) - 150 points each
Taxi Terminal - 50 points each
Rental Cars - 25 points each
* = required object
Syntax
1) name of airport, ICAO/IATA code (you can make it up if you want)
2) airlines
3) destinations by airline and frequencies
4) objects placed - total
5) objects placed this post
6) points used, points left
7) any other info, maps, etc.
More objects will be added weekly
when everyone gets below 2000 points left, I will begin adding 200 points to each player weekly.
Have fun!
-Matt
Lighten up while you still can, don't even try to understand, just find a place to make your stand and take it easy
PlymSpotter
RE: Design Your Own Airport! V2
Thu Nov 01, 2007 7:02 pm
OK, it's a little complicated but I'll have a go at joining in, although the terminal is meant solely for one airline it could be problematic. Think me a little weird, but I have more operations like this than you could ever imagine going on in my imagination... I actually use it as a method of winding down in bed at the end of the day before going to sleep... you'll see a bit of it gets mixed up in the below.
The airport is based very roughly South East of Urumqi in China, on an abandoned Chinese military location; the area is very remote, there being only a small city which formerly served the tertiary needs of the base. However, it's location falls under the path of many major Europe-Asia air routes. For this reason, NIA - Nepal International Airlines shifted their main base from KTM to this preferable location where there was flat ground not surrounded by high peaks to expand a dedicated airport for their hub operation. The idea is to tap even further into this market using special customs provisions granted on the basis that it is used solely as a transit hub (to begin with), thus passengers are not able to start or finish their journeys from this location. A customs facility though will be provided, by means of a bus to a separate and much smaller terminal for the city itself, thus allowing some domestic traffic.
The construction of the airport was allowed on the basis that it would act as a vehicle for employment and regeneration in the region, with the eventual hope of bringing inward investment. This may include the transfer of the production of aircraft* to the expansive ex military site. It is aimed to transfer the city into a financial business hub for North West China in 10 years. The terminal is a module and lies on one side of the runway, whilst the old domestic terminal is on the other. It is aimed that at least two further of these modules will be added and linked with a rapid transport system. Concurrently, another 14,000ft runway would be constructed on the other side of the terminal. Space is assigned for up to 4 parallel runways.
*See below destinations for the range of K aircraft.
So, here goes to start with;
Runway: 14,000ft = 600 points (11,000ft + 3000ft or 500+100, needed due to an elevation of 2000m ASL)
Control Tower: 1 = 500 points
Domestic gates: 2 = 200 points
'A' International gates: 26 = 3250 points
'B' International gates: 10 = 1125 points (bus gates)
Customs facility: 1 = 200 points
'A' Security checkpoints: 54 = 6625 points (1 for domestic terminal and 2 each for the gates*)
'B' Security checkpoints: 10 = 1000 points
Cargo building: 1 = 400 points
Ground service equipment building: 2 = 200 points
Fire station: 1 = 150 points
General aviation ramp: 1 = 200 points
Administration building**: 1 = 200 points
*Terminal operates on a split system, enables seamless operation of the A380. The upper level is for premium passengers only and leads directly from the aircraft, via walkways over the main terminal below, to a large business and first class lounge which extends as a central island throughout the entire terminal. Also contains dedicated 'premium' check in desks to hotel mentioned below...
**Administration building is located above the terminal at the top of a hotel. Idea being that all departures are based around three 'waves' - should your flight arrive on one wave and then depart on another, a complimentary hotel room is provided in the ticket price. Your standard of room will depend on the ticketing class.
Name:
Name = Altun Shan International Airport
IATA code = ATN
ICAO code = ZATN
Airlines & Destinations already operated:
Domestic:
Air China = BJS daily B738
China Eastern Airlines = PVG daily A320
China Southern Airlines = HRB x 3 weekly MD82, CAN x 5 weekly A319, URC x 3 daily A32S
Hainan Airlines = BJS daily B73G
Shanghai Airlines = SHA x 2 weekly B752
Shenzen Airlines = SZX daily B73G
International:
Air Astana = ALA 1 x weekly A320
Kyrgyzstan Airlines = FRU(Bishkek) 1x weekly Tu134
SCAT Airservices = ALA 2 x weekly Yak42
Tajik Air = DYU(Dushanbe) 1 x weekly Tu154 via URC
Formerly:
Nepal Airlines = KTM x 1 weekly B75M
NIA/Altun Airways present and launched destinations:
Europe:
AMS x 1 daily K553
ATH x 1 daily K245
BHX x 2 daily A388
BRU x 1 daily K254
CDG x 2 daily A388 and K552
CPH x 1 daily K552
DUB x 1 daily K552
FCO x 1 daily K552
FRA x 2 daily K553
GLA x 1 daily K553
GVA x 1 daily K254
HEL x 1 daily K254
IST x 1 daily K552
KBP x 1 daily K254
LED x 1 daily K254
LHR x 3 daily A389
LIS x 1 daily K254
MAD x 1 daily K552
MAN x 2 daily A388
MOW x 1 daily K552
MUC x 1 daily K552
MXP x 1 daily K553
OSL/ARN x 1 daily K553
PRG x 1 daily K552
VIE x 1 daily K552
ZRH x 1 daily K553
Asia/Pacific:
AUK x 2 daily A388
BJS x 2 daily K553
BKK x 2 daily K553
BWN x 1 daily K553
CCU x 2 daily K553
CEB x 1 daily K552
DAC x 2 daily K553
DEL x 4 daily A388
HAN x 1 daily A388
HKG x 3 daily A389
HYD x 2 daily K553
ICN x 2 daily A388
ISB x 2 daily K553
JAK x 1 daily A388
KIX x 1 daily K553
KTM x 6 daily A388*
KUL x 3 daily K553
MEL x 2 daily A388
MNL x 2 daily K553
NRT x 2 daily A389
PER x 2 daily K552
PVG x 2 daily K553
SGN x 2 daily K553
SIN x 3 daily K553
SYD x 3 daily A388
Africa/Middle East:
CAI x 1 daily K552
CPT x 1 daily K551
DXB x 1 daily K553
JNB x 2 daily K551
NBO x 1 daily K552
RUH x 2 daily A388
THR x 1 daily K553
TLV x 2 daily K552
North/Central/South America:
GRU x 1 daily K551
HOU x 3 daily K552
IAD x 1 daily A388
JFK x 3 daily A388
LAS x 2 daily K552
LAX x 2 daily A389
LIM x 1 daily K551
MCO x 2 daily A388
MEX x 1 daily K551
ORD x 1 daily A388
SFO x 2 daily K552
YVR x 1 daily K552
YYZ x 2 daily K552
So that makes any sense, here's an explanation of the types in the fleet. The KC558 twin jet is similar to a 777 in appearance, only seats 12 abreast in a 2-4-4-2 combination. I can't remember what KC means though, that's the only problem, it's something I thought up yonks back and which then stuck:
K254 = KC 258-400 ... 220 pax in 3 class (Tri-jet, identical design to MD-11)
K551 = KC 558-100 ... 240 pax in 3 class (Shortest in family of 558, speciality range of 10,500mi)
K552 = KC 558-200 ... 320 pax in 3 class (Range of 8500mi)
K553 = KC 558-300 ... 400 pax in 3 class (Replaced 744's in fleet)
A388 = A380-800 ... 480 pax in 3 class (Assumed built and in service for a while)
A389 = A380-900 ... 590 pax in 3 class (Yes, I have assumed they have designed and built it already Big grin )
Total points used in construction of my airport to transfer the airline to: 14,650
I will try to post some maps and diagrams if I have the time and, yes, I have far too great an imagination!
Dan Smile
extspotter
Fri Nov 02, 2007 10:48 pm
Dublin/Weston International Airport (WSN/EIWN)
Ryanair: (7 aircraft based, all 738W)
5 x ORK
3 x SNN
2 x KIR
2 x NOC
7 x STN
2 x MAN
1 x EMA
1 x BRS
1 x NQY
1 x MME
1 x BOH
2 x PIK
3 x EDI
2 x BVA
2 x HHN
2 x CRL
1 x EIN
1 x BRE
2 x SKA
1 x PMI
2 x FAO
2 x GRO
1 x MXP
1 x TSF
1 x ALC
2 x AGP
3 x MAD
1 x VLL
Aer Arran (3 aircraft based, 2 ATR 42 and 1 ATR 72)
4 x ORK
1 x WAT
2 x KIR
5 x SNN
2 x GWY
3 x NOC
1 x SLG
1 x CFN
2 x IOM
1 x INV
1 x CWL
1 x BHX
2 x MAN
Cityjet (2 aircraft based, both B463s)
7 x LCY
3 x CDG
2 x AMS
1 x BRU
easyJet
3 x LTN
4 x LGW
1 x STN
2 x LPL
2 x GLA
1 x BRS
bmi
7 x LHR
2 x ABZ
British Airways
4 x LHR
Flybe
3 x EXT
1 x NQY
4 x SOU
1 x NWI
3 x BHX
5 x MAN
1 x BFS
Air Southwest
2 x NQY
1 x PLH
bmi Baby
2 x MME
1 x CWL
More airlines are interested in starting service, including Altun Airways to repalce Dublin/Swords for Dublin/Weston due to improved facilities, lower costs and a longer runway. British Pan European Airways is also keen to move it's DUB base to WSN
1 x Runway (11,000 ft) - 500 points each
1 x Runway (7,800 ft) - 350 points each
1 x Control Tower - 500 points
6 x Domestic gate - 100 points each*
30 x International gate - 125 points each
5 x Customs Facility - 200 points each
30 x Security Checkpoint - 100 points each*
1 x Above Ground Tram - 3500 points
1 x Above Ground Tram Station - 150 points each
1 x Cargo Building - 400 points each
2 x Ground Service Equipment Building - 100 points
1 x Fire Station - 150 points* each
1 x Administration building - 200 points each
4 x Parking Lot (1,500 spots) - 150 points each
2 x Taxi Terminal - 50 points each
4 x Rental Cars - 25 points each
13100 points used, 1900 to go.
Airport is on the site of the old Weston aerodrome. Runways are 10L-27R and 10R-27L to line up with the original Dublin airport in swords and stop conflicting traffic problems as with the old Weston runway which was 07-25.
[Edited 2007-11-02 15:53:46]
AF BE BY FR MV PD SZ U2 VZ DHC6, 8-3/4Q, 732/8, 763ER, A319, A380
jetmatt777
Crew
Sat Nov 03, 2007 12:21 am
Extra points will be now issued on Fridays for the players below 2000 points, (US Time)
Quoting PlymSpotter (Reply 1):
14,650
You have 350 points left + 200 = 550 points left. Correct me if my math is wrong  Wink
Quoting EXTspotter (Reply 2):
1900 to go
1,900 + 200 = 2,100.
Thanks for playing guys, hopefully some more people will start in, make it more interesting.
BTW, did you guys count in the price of each flight? If not you don't have to completely redo the airport to cut costs to pay for the flights. We'll figuire out a way to pay without doing that.
-Matt
w3ndytj4n
Sat Nov 03, 2007 1:36 am
Proposed New Features:
Baggage Claim Carousel
Check In Desk
Wendy Tjan
jetmatt777
Crew
Sat Nov 03, 2007 3:22 am
Quoting W3ndytj4n (Reply 4):
Check In Desk
In my original thoughts for objects I thought of these. They will be re-considered though. By next Friday I will have more objects to be bought. Thanks for the suggestion.
W3ndytj4n
Why don't you play? Pull up a chair  biggrin   Wink
New players very much welcome, don't let your imagination be shy!  Wink
-Matt
QFA380
Sat Nov 03, 2007 7:54 am
Ok, Ill get the ball rolling.
My airport will be called Nancy Bird-Walton International Airport, it will replace SYD and be built at Badgery's Creek. IATA was going to be NBW but that's is taken by Guantanamo Bay, so IATA will be NBS, ICAO YSSN.
2 11, 000ft runway 1000
1 customs facility 200
17 Airlines 2550
Fire station 100
10 Domestic Gates 1000
18 International Gates 2250
1 Security checkpoint 100
1 taxi terminal 50
2 Parking lots 300
Ground Service Equipment 100
Admin Building 200
1 Cargo Building 400
6750 points left
QF International
3x SIN/LHR 744
1x JNB 744
1x HNL A333
2x HKG A333
1x PEK A333
2x LAX/JFK 744
1x SFO 744ER
1x BOM 763ER
1x CHC 738
2x AKL 738
1x WLG 738
Jetstar
2x HNL A332
1x KUL A332
1x ITM A332
Virgin Blue/ Pacific Blue International
2x NAN 738
1x RAR 738
1x TBU 738
1x YLI
1x CHC 738
1x AKL 738
1x WLG 738
Total 8
Singapore Airlines
1x SIN 388
3x SIN 744
1x DXB 773
1x HKG 773
3x SIN 744F
Total 6
Emirates
2x DXB 345
2x DXB 773ER
2x SIN 773ER
2x AKL 345
1x DXB 744F
Total 8
British Airways
2x HKG/LHR 744
1x SIN/LHR 772
1x JNB 744
Total 4
Continental
1x HOU/LAX 772ER
1x HOU/HNL 772ER
1x EWR/HNL 772ER
Total 3
American Airlines
3x LAX 772ER
2x DFW/HNL 772ER
Total 5
United Airlines
2x SFO 744
1x LAX 744
1x NRT/SFO 744
1x LAX/ORD 772ER
Total 5
Lufthansa
3x HKG/FRA 744
2x SIN/MUN 346
2x SIN/DXB/FRA MD11F
Total 7
Mayalsia Airlines
1x KUL 744
2x KUL 772ER
1x KUL 742F
Total 4
Korean Airlines
2x ICN 333
2x ICN 773
3x ICN 744F
Total 7
China Southern
2x PVG 346
1x PVG 744ERF
Total 3
Air China
1x PVG 332
2x PEK 744
2x PEK 744F
Total 5
China Airlines
2x TPE 744
3x TPE 744F
Total 5
South African Airways
2x CPT A346
1x JNB A346
Total 3
Air Canada
2x HNL/YVR 763ER
2x YVR 773ER
1x YYC 772LR
1x HNL/YOW 763ER
Total 6
Air New Zealand
1x AKL/LAX 744
2x AKL 763ER
3x CHC A320
2x WLG A320
2x AKL/HKG 772ER
Total 10
Total All International 108
Total International Cargo 16
International Passenger 92
Qantas Domestic
15x MEL 763ER
8x ADL 738
10x BNE 763ER
10x CBR DHC8
5x DRW 763ER
5x HBA 738
8x CFS DHC8
4x DBO DHC8
6x CNS 763ER
5x OOL 738
Total 76
Jetstar (all A320)
4x ADL
9x AVV
6x OOL
3x MCY
5x TNY
2x PPP
2x HTI
1x ROK
1x MKY
1x HYB
Total 34
Virgin Blue (737/738)
4x ADL
13x MEL
2x BNA
2x CFS
5x CNS
4x OOL
2x HYB
3x HBA
2x MKY
7x PER
1x PMQ E170
2x ROK
2x MCY
3x TNY
7x CNS
Total 59
Total Domestic 169
Just a question, would it be possible to make it say 50 points to add an airline, but that airline is never allowed to operate any more than 5 flights? 150 points for only a couple of flights it a little outrageous.
extspotter
Sat Nov 03, 2007 4:11 pm
Due to the majority of carriers moving from Dublin/Swords airport to Dublin/Weston airport because of better facilities, links and lower costs. Dulin/Swords is going to be closing down and the land sold off to housing developers. The displaced airlines will now be housed at the new Dublin/Weston airport. More facilities have been purchased.
2 x Runway (11,000 ft) - 500 points each
10 x Domestic gate - 100 points each*
40 x International gate - 125 points each
14,900 spent 300 points left
Aer Lingus: (4 A321, 18 A320, 9 A330)
3 x SNN
2 x GLA
2 x EDI
1 x NCL
3 x MAN
3 x BHX
6 x LHR
2 x LGW
1 x FNC
1 x ACE
1 x TFS
1 x JER
4 x CDG
1 x LYS
2 x NCE
1 x MRS
1 x BOD
1 x SCQ
1 x BIO
2 x MAD
3 x BCN
1 x SVQ
1 x ALC
2 x AGP
1 x PMI
1 x LIS
1 x FAO
1 x HEL
1 x RIX
1 x ATH
1 x OTP
1 x WAW
1 x PRG
1 x VIE
2 x TXL
1 x HAM
1 x CPH
1 x DUS
2 x FRA
2 x MUC
1 x NAP
2 x FCO
1 x BLQ
1 x VCE
2 x LIN
1 x ZRH
1 x GVA
1 x DXB
1 x MCO
1 x IAD
1 x BOS
2 x ORD
2 x JFK
1 x SFO
1 x LAX
Ryanair: (17 aircraft based, all 738W)
5 x ORK
3 x SNN
2 x KIR
2 x NOC
12 x STN
4 x LTN
3 x LGW
2 x DSA
2 x LBA
3 x NCL
6 x MAN
2 x LPL
1 x EMA
3 x BRS
1 x NQY
1 x MME
1 x BOH
1 x ABZ
2 x PIK
3 x EDI
2 x BVA
1 x NTE
1 x LRC
1 x BIA
1 x CRS
2 x HHN
2 x CRL
1 x EIN
3 x SXF
1 x BRE
2 x SKA
1 x MMX
1 x GOT
1 x BIL
2 x TRP
1 x PMI
2 x FAO
2 x GRO
1 x MXP
1 x TSF
1 x BLQ
2 x PSA
3 x CIA
2 x ALC
3 x AGP
4 x MAD
1 x VLL
1 x TFS
1 x TFN
1 x FUE
1 x MLA
4 x ORK
1 x WAT
2 x KIR
5 x SNN
2 x GWY
3 x NOC
1 x SLG
1 x CFN
2 x IOM
1 x INV
1 x CWL
1 x BHX
2 x MAN
British Pan European (8 738s and 4 ATR 42s)
4 x WAT
7 x ORK
4 x KIR
6 x SNN
3 x GWY
5 x NOC
2 x SLG
3 x CFN
2 x LDY
6 x BFS
2 x NNR
2 x IIA
2 x INQ
2 x IOR
3 x IOM
2 x ISC
2 x NQY
1 x PLH
3 x EXT
2 x BOH
4 x BRS
3 x SOU
2 x JER
2 x GCI
4 x BHX
2 x EMA
3 x LGW
1 x LYX
2 x NWI
3 x STN
2 x LCY
2 x CWL
1 x VLY
5 x LPL
7 x MAN
3 x NCL
2 x DSA
2 x LBA
1 x BLK
5 x EDI
4 x GLA
2 x ABZ
2 x INV
4 x ORY
2 x BOD
1 x LYS
2 x MRS
2 x GVA
3 x AMS
2 x BRU
1 x LBC
3 x HHN
1 x MUC
2 x SXF
2 x GRO
3 x MAD
1 x VLL
2 x PMI
2 x AGP
1 x VLC
1 x ALC
1 x SVQ
2 x FAO
1 x LIS
2 x LIN
2 x TSF
1 x BLQ
2 x CIA
1 x TRP
1 x CPH
1 x SKA
10 x LCY
6 x CDG
easyJet
3 x LTN
4 x LGW
1 x STN
2 x LPL
2 x GLA
1 x BRS
bmi
7 x LHR
British Airways
4 x LHR
2 x LDY
Flybe
3 x EXT
1 x NQY
4 x SOU
1 x NWI
3 x BHX
5 x MAN
1 x BFS
Air Southwest
2 x NQY
1 x PLH
bmi Baby
2 x MME
1 x CWL
Adria Airways
1 x LJB
Air Canada
1 x YYZ
Air Europa
1 x LPA
Air Transat
1 x YYZ
Air Baltic
1 x VIL
1 x RIX
Altun Airways
1 x ATN
American Airlines
1 x ORD
Arkia
1 x TLV
Blue1
1 x HEL
Centralwings
1 x Gdansk
1 x Katowice
1 x Wroclaw
1 x Szezecin
3 x WAW
1 x Wroclaw
Clickair
2 x BCN
Continental
1 x EWR
CSA
2 x PRG
Delta
1 x ATL
1 x JFK
Estonain Airlines
1 x Tallin
Etihad
1 x AUH
Eurocypria
1 x PAP
Finnair
2 x HEL
Flyglobespan
1 x YHM
1 x YVR
FlyLAL
1 x VIL
Futura
1 x ALC
1 x FAO
1 x AGP
1 x NCE
1 x TFS
Iberia
4 x MAD
LTE
1 x ACE
1 x LPA
Lufthansa
3 x FRA
Luxair
1 x LUX
Malev
2 x BUD
SATA
1 x PDL
SAS
3 x CPH
3 x OSL
4 x ARN
SkyEurope
1 x BTS
Spanair
1 x LPA
1 x AGP
1 x PMI
Swiss
2 x ZRH
S7 (Siberia)
2 x DME
Turkish
1 x IST
US Airways
1 x PHL
jetmatt777
Crew
Sat Nov 03, 2007 4:28 pm
Quoting QFA380 (Reply 6):
Very good point. Airlines are now 50 points each. I will be giving refunds now.
PlymSpotter gets a refund of 1,200 points.
EXTSpotter get 4,200 points refunded
QFA380 gets 1,700 points refunded.
Correct me if my math is wrong.
-Matt
extspotter
Sat Nov 03, 2007 5:46 pm
Due to return of points, more facilities have been added at Sublin-Weston (WSN)
4 x Runway (11,000 ft) - 500 points each
20 x Domestic gate - 100 points each*
60 x International gate - 125 points each
800 Points left.
The new runways are aligned parallel to the original 2 runways on the 113 - 283 heading.
Now:
27L - 10R
27CL - 10CR
27CR - 10CL
27R - 10L
More airlines have started service to Dublin - Weston
Northwest:
1 x MSP
2 x DTW
1 x SEA
1 x MEM
Emirates:
3 x DXB
1 x LAX
1 x YYZ
1 x IAH
Air India
1 x BOM
1 x DEL
1 x CCU
JAL
2 x NRT
1 x KIX
1 x NGO
Cathay Pacific
2 x HKG
Air China
1 x PEK
Qantas
1 x BKK
1 x Sydney NBW
1 x CGK
1 x MEL
South African
1 x JNB
Varig
1 x GIG
TAM
1 x GRU
Two new announcements.
Ryanair's outspoken CEO, Michael O'Leary has announced orders for 100 Boeing 787 and 50 Airbus A380 aircraft. To be based at Dublin Weston and London Stansted for longhaul low cost travel. To start the building up of service, the Ryanair chairman is leasing Boeing 747, 767, 777, Airbus A330 and A340 aircraft to cover in the short term.
Service of this new airline at Dublin shall be in the near future, where it is thought 15 747s, 40 767s and 30 A330s will be based.
In the other announcement, Emirates is proud to pronounce that Dublin Weston will become its European hub when EU - UAE and UAE - US Openskies agreements come in in the near future. Up to 50 widebody aircraft will be based at dublin. Future Emirates orders will be scutanised by the Weston Airport Authority and more will be released soon.
[Edited 2007-11-03 10:48:56]
[Edited 2007-11-03 10:51:07]
w3ndytj4n
Sun Nov 04, 2007 9:42 am
Quoting Jetmatt777 (Thread starter):
How about we add the flight ourselves? We operate ATL, and we want to add DL flight to it, when there is no one playing as the airline?
W3ndy
Wendy Tjan
jetmatt777
Crew
Sun Nov 04, 2007 9:18 pm
Quoting W3ndytj4n (Reply 10):
No one plays as the airline. You build airports and add flights to your airport on any airline. What I said above applies to if you add a flight from your airport, to someone elses airport, I'll use EXTSpotter's airport as an example, you would have to have an agreement from EXTspotter to add the flight so he can build the necessary facilities if he is short, or he can reject the offer if he doesn't have the necessary facilities or the means to build them, or if he just doesn't want the flight to his airport. If you start a flight to an airport that no one is using in the game, you don't have to get ageememnt's because there is no one to get an agreement from.
w3ndytj4n
Mon Nov 05, 2007 2:20 pm
Let me manage LHR:
1 Runway 11000 feet
1 Runway 7800 feet
1 Control Tower
1 Fire Department
1 Administration Building
2 Parking (1500 lots each)
1 Taxi Stand
1 Car Rental Company
5 Domestic Gates
15 International Gates
20 Security Gates
10 Custom Kiosk
1 Cargo Building
2 Ground Service
Total 9050
Airlines operation based in LHR:
AerLingus
Domestic Routes
2 daily LHR - ORK
equipment : Airbus 321-200
4 daily LHR - DUB
equipment : 2 Airbus 320-200, 2 Airbus 321-200
2 daily LHR - SNN
equipment : Airbus 320-200
BMI Group
Domestic Routes
3 daily LHR - ABZ
equipment : Airbus 319-100, 2 Embraer 145
3 daily LHR - BFS
4 daily LHR - DUB
equipment : Airbus 319-100, Airbus 320-200, 2 Airbus 321-200
2 daily LHR - MME
equipment : Airbus 319-100, Embraer 145
3 daily LHR - EDI
3 daily LHR - GLA
equipment : 2 Airbus 319-100, Airbus 320-200
1 daily LHR - INV
2 daily LHR - JER
3 daily LHR - LBA
3 daily LHR - MAN
International Routes
1 daily LHR - AMM
2 daily LHR - AMS
1 daily LHR - ESB
1 daily LHR - GYD
1 daily LHR - BEY
1 daily LHR - BRU
1 daily LHR - CAI
1 daily LHR - HAJ
equipment : Embraer 145
1 daily LHR - JED
equipment : Airbus 330-200
1 daily LHR - DME
1 daily LHR - PMI
1 daily LHR - IKA
1 daily LHR - VCE
British Airways
Domestic Routes
3 daily LHR - ABZ
equipment : Airbus 319-100, Airbus 320-100, Boeing 757-200
3 daily LHR - EDI
equipment : Airbus 319-100, Airbus 320-200, Boeing 757-200
3 daily LHR - MAN
2 daily LHR - NCL
1 daily LHR - AUH
equipment : Boeing 777-200/ER
3 daily LHR - AMS
equipment : 2x Airbus 321-200, Airbus 319-100
2 daily LHR - ATH
equipment : Airbus 320-200, Boeing 767-300/ER
1 daily LHR - BAH
equipment : Boeing 747-400
1 daily LHR - BWI
equipment : Boeing 767-300/ER
1 daily LHR - BLR
1 daily LHR - BKK
1 daily LHR - BSL
1 daily LHR - PEK
1 daily LHR - BEG
2 daily LHR - TXL
1 daily LHR - BOS
2 daily LHR - BRU
equipment : Airbus 319-100, Airbus 321-200
1 daily LHR - OTP
2 daily LHR - BUD
equipment : Airbus 320-200, Boeing 757-200
1 daily LHR - EZE
1 daily LHR - CAI
1 daily LHR - YYC
1 daily LHR - CPT
1 daily LHR - MAA
2 daily LHR - ORD
equipment : Boeing 747-400, Boeing 767-300/ER
2 daily LHR - CPH
1 daily LHR - DEL
1 daily LHR - DEN
1 daily LHR - DTW
1 daily LHR - DOH
1 daily LHR - DXB
3 daily LHR - DUS
equipment : Airbus 319-100, Boeing 757-200, Boeing 767-300/ER
3 daily LHR - FRA
equipment : Airbus 319-100, Airbus 320-200, Boeing 767-300/ER
2 daily LHR - GNV
3 daily LHR - HAM
3 daily LHR - HEE
equipment : Airbus 320-200, Airbus 321-200, Boeing 757-200
1 daily LHR - HKG
1 daily LHR - IAH
1 daily LHR - IST
1 daily LHR - JNB
1 daily LHR - KBP
1 daily LHR - KWI
1 daily LHR - LOS
1 daily LHR - LIS
1 daily LHR - LAX
1 daily LHR - LYS
2 daily LHR - MAD
2 daily LHR - LIN
1 daily LHR - MXP
1 daily LHR - MIA
1 daily LHR - YUL
1 daily LHR - DME
1 daily LHR - BOM
3 daily LHR - MUC
2 daily LHR - JFK
equipment : Boeing 747-400, Boeing 777-200/ER
1 daily LHR - EWR
2 daily LHR - NCE
2 daily LHR - OSL
2 daily LHR - CDG
1 daily LHR - PHL
1 daily LHR - PHX
1 daily LHR - PRG
2 daily LHR - FCO
1 daily LHR - LED
1 daily LHR - GRU
1 daily LHR - SEA
1 daily LHR - PVG
1 daily LHR - SIN
1 daily LHR - SOF
2 daily LHR - ARN
equipment : Airbus 319-100, Boeing 767-300/ER
2 daily LHR - STR
1 daily LHR - NRT
1 daily LHR - YYZ
1 daily LHR - YVR
1 daily LHR - VIE
1 daily LHR - WAW
2 daily LHR - ZRH
Virgin Atlantic
1 daily LHR - BOS
equipment : Airbus 340-600
1 daily LHR - CPT
1 daily LHR - ORD
equipment : Airbus 340-300
2 daily LHR - DXB
equipment : Airbus 340-600, Boeing 747-400
1 daily LHR - HKG
1 daily LHR - JNB
1 daily LHR - LOS
2 daily LHR - LAX
2 daily LHR - MIA
1 daily LHR - BOM
2 daily LHR - JFK
1 daily LHR - EWR
1 daily LHR - SFO
1 daily LHR - PVG
1 daily LHR - NRT
1 daily LHR - IAD
4 Airlines x 150 = 600
136 International Routes x 20 = 2720
46 Domestic Routes x 15 = 690
Total 4010
Grand Total 13060
Left 1940
Wendy Tjan
LHR Management
[Edited 2007-11-05 06:21:11]
Wendy Tjan
QFA380
Thu Nov 08, 2007 6:42 am
Quoting EXTspotter (Reply 9):
1 x Sydney NBW
Yah!
New Airlines and addition
Qantas International
2x ATN A333
Etihad Airways
2x AUH A345
British Airways
1x AUH/LGW
Gulf Air
3x BAH A343
Hawaiian
2x HNL 763ER
Air France
2x SIN/CDG 773ER
JAL
3x Tokyo 744
2x Tokyo 744F
All Nippon
3x 773
2x 744F
Air India
3x BOM 777?
2x New Delhi something
Kingfisher
Phillipines
3x Manilla
Aeroflot
2x Moscow
El AL
2x BKK/TLV 77
Mexicana
(if possible)
Thai Airways
3x BKK 744
2x Phuket MD11
Air Pacific
1x NAN/LAX 744
3x NAN 738
Air Vanuatu
Air Tahiti Nui
2x PPT A343
Aerolineas Argentineas
2x AKL/EZE A342/744
LAN Chile
1x AKL/SCL A343
EVA Air
2x TPE 744
Asiana
3x ICN 772ER
Austrian Airlines
2x BKK/Vienna 772ER
Olympic Airways
1x DXB/ATH A343
Jet Airways
2x BOM 773ER
Royal Jordanian
1x AMM A343
KLM
2x SIN/AMS 744
1x BKK/AMS 772ER
1x DXB/AMS 744ERF
Air France
2x CDG/SIN 773ER
2x CDG/DXB 744ERF
jetmatt777
Crew
Thu Nov 08, 2007 10:05 pm
Quoting QFA380 (Reply 13):
Sorry I didn't catch that at first - 100 points awarded to QFA380
New features will be added tomorrow!
-Matt
Thanks for playing.
QFA380
Fri Nov 16, 2007 11:08 pm
Quoting Jetmatt777 (Reply 14):
 Yeah sure  bored   confused   crying   hissyfit   irked   liar   pray   scratchchin
Ok I'm done.... Big grin
