wilco737
Question About FSX (problem)
Tue Nov 13, 2007 1:45 pm
Hey guys,
so I finally have a new Computer and using Windows Vista, so I tried the FSX and I must say I am shocked...
Framerates are okish, but I have another problem. When I am using the normal cockpit view, the runway and the ground disappear below the glareshield so I cannot see the airport or the runway during final approach, which sucks. In 2004 I used Shift + Enter to "sit higher", but in FSX this feature doesn't work...
Then I thought: ok, using the virtual cockpit (which I don't like very much). But here I encountered another problem: during short final at about 150' above the ground the screens (PFD, ND, etc) get "see through"... So I can see the ground objects on the ground through the screens, but at short final I need the PDF and ND or so... and no "see through screens"...
So, I cannot use the VC or the normal cockpit view to land properly...
Any suggestions, any help?
At the moment I am using FS2004 again which is working amazingly good on my new PC...
Thanks for the help
WILCO737 (MD11F)
 airplane
gunsontheroof
RE: Question About FSX (problem)
Tue Nov 13, 2007 9:26 pm
Quoting WILCO737 (Thread starter):
Any suggestions
Yes...
Stick with it!  Wink
Seriously though, that sounds pretty strange. Hopefully somebody else here who doesn't share my hostility towards FSX can help you get it working properly.
Picked a hell of a week to quit sniffing glue.
DFW13L
Wed Nov 14, 2007 7:48 am
I tested this tonight and here's the deal. In FSX the shift+enter and shift+backspace works differently in 2D cockpit than it does in 3D cockpit. In 3D cockpit it works the same as in FS2004, where your eye level inside the cockpit moves up. In FSX 2D cockpit view it's different. It's as if the entire airplane is lifted higher...and the result is that it is more like you are higher in the cockpit looking down just above the nose of the plane when on final to a runway.
It's imperceptable unless you know what it's doing. Set up in FSX on a nice big runway and then hit shift enter and watch what the runway does...it moves down.
Try it. No I don't like change either, but it made it where I could land on 2D view. Though I admit that in FSX I now use 3D to land. (by 3D I mean virtual cockpit, sorry if that was confusing)
Matt
See, I knew American Eagle was first class all along!
wilco737
Wed Nov 14, 2007 8:06 am
Quoting DFW13L (Reply 2):
Thanks for the reply! So I guess FSX is NOT an option anymore... When I sit in my cockpit I want to see the instruments properly AND the runway as well! The 3D view (virtual cockpit) is just weird! When the aircraft accelerates it moves up... this is just weird... Don't like it at all...
So, FS2004 with all graphic details set to highest with great framerates...
WILCO737 (MD11F)
 airplane
B727-200
Thu Nov 15, 2007 12:35 am
I found the virtual cockpit took a little getting used to, now I struggle when I go back to FS9 because of the 2D cockpit views on most of my downloaded aircraft.
Stay with it and you will grow to like it. The only thing that annoys me now is the number of buttons that don't work in VC and you have to go to the 2D pannel to switch on/off.
B727-200.
wilco737
Thu Nov 15, 2007 6:05 pm
Quoting B727-200 (Reply 4):
And thats friggin annoying and NOT very realistic! And I thought FSX is more realistic than FS2004... But apparently it makes it harder to get to the "real" thing...
But thanks for the reply!
WILCO737 (MD11F)
 airplane
David L
Sat Nov 17, 2007 8:42 pm
Shift-Enter does work differently in FSX but you can use Shift-Q and Ctrl-Shift-Q for exactly the same effect:
FS X Problem (not A Frame Rate Problem)  Wink (by WILCO737 Oct 16 2006 in Aviation Hobby)
Um... sound familiar, Wilco?  duck
Users browsing this forum: Mumrik and 1 guest
