xaapb
FS9 In A Laptop?
Sat Nov 24, 2007 11:12 pm
Hi,
Some months ago I bought a Laptop, it's a HP DV6500T with Intel Core2Duo T300 2GB DDR2 of RAM, 128MB of video with a Nvidia GeForce 8400M GS. I haven't installed FS since it comes with Windows Vista, however I want to try it.
What do you think, will it run FS ok?
Thanks in Advance for your help and advises.
Jorge
Jorge Meneses
QFA380
RE: FS9 In A Laptop?
Sat Nov 24, 2007 11:20 pm
That should run FS9 pretty well and may even run FSX ok. I have a MacBook Pro with the same specs as that and FS9 runs very well. I haven't installed FSX yet, but it ran ok on my old computer which was less powerful than this.
jamesbaldwyn
Sun Nov 25, 2007 2:24 am
Yep, like QFA380 said, It'll run FS9 nicely.
ebs757
Quoting QFA380 (Reply 1):
I can second that. 2gbs of ram is pretty good for FS9. I have a Dell inspiron 256mb ATI video card and 1.5 gb of ram and a 1.8gz prosesor. It should run fine for you
Viva la Vida
KL773ER
Mon Nov 26, 2007 4:42 am
Jorge,
My laptop has less components than yours and runs FS9 quite well. The only really big issue I have on the laptop is receiving a FS9 error message every so often in-flight and the programme shuts down. (It is upsetting receiving this message during longhaul flights especially near reaching my destination.)
In general, you should have no problem.
Good luck,
-KL
KevinL1011
Fri Nov 30, 2007 5:46 am
My Dell Inspiron 9100 has basically the same set up as Ebs757's Inspiron, but I only have a 40gb HD. I'm not sure how many Gb's FS9 is but FSX is about 13Gb. I bought a Lacie 120gb external HD to load and run FSX due to lack of space. If you go with an external drive, get one with an access speed of at least 20mbps. Mine runs OK but I have to sometimes de-content the graphic settings to get 20+ Fps.
I prefer the ATI Radeon cards but your dual core with 2gb ram should be awesome !
474218, Carl, You will be missed.
TVNWZ
Tue Dec 04, 2007 7:00 pm
Quoting KL773ER (Reply 4):
Jorge,
In general, you should have no problem,
I always save the flight at various stages so if that happens I can pick up again along the route. I really make it a point to save the flight just as I am advised by ATC to start descending for landing.
xaapb
Thu Dec 06, 2007 4:14 am
Thank you very much for your answer's, I will test the simulator and let you know what happen!
Again, thanks!!
Jorge
Jorge Meneses
cba
Tue Dec 11, 2007 9:58 pm
Are you running FS through Paralells or VMWare, or do you boot up straight to Windows using BootCamp?
bilgerat
Sat Dec 15, 2007 10:49 am
That system should run FS9 fairly well, although the video card might choke a little if you try to run at a higher resolution with anti-aliasing and anistropic filtering.
If you are running on Vista there are a few things you can do to smooth things out. First of all don't install FS9 to the default directory (Program FilesMicrosoft GamesFlight Simulator 9). Install it to its own directory outside of your Program Files folder. For some reason Vista makes your Program Files folder read only which can cause problems. Likewise disable "User Account Control" (UAC). This is the cause of 99% of Vista's problems when running third party addons for FS9. I've found all my FS9 addons run fine when I disable UAC. If you're not sure how to disable it or what the implications are, Google it and make the decision. If you're a fairly savvy computer user and you aren't paranoid about security you shouldn't be too worried about disabling UAC.
airivoireA321
Sun Dec 16, 2007 10:33 pm
i have a new laptop Toshiba with a ATI HD 2600 , i run fs9 with no prob and have many add ons like pmdg and many flytampa airport etc. i think you could run fs9 but dont put 100% in all performance
QFA380
Mon Dec 17, 2007 3:20 am
Quoting Cba (Reply 8):
I use Bootcamp. I would get one of them but the performance loss from using them instead of a clean Windows is too great. I can run FSX fairly well but using one of them would make it unbearable.
AirframeAS
Thu Dec 20, 2007 7:16 pm
I am currently using a Dell XPS M1210 (its a gamer's laptop, I found out..) and it works WELL!!
CXfirst
Sun Jan 06, 2008 11:53 pm
same question - not as good laptop.
Dell Inspiron 6400 (uses different name in the US, not sure which)
1 GB ram
Intel Centrino duo T2050 1.60 Ghz
Intel(R) Graphics Media Accelerator Driver for Mobile Report (so not dedicated graphics, if I'm not mistaken)
-CXfirst
jamesbaldwyn
Sun Jan 06, 2008 11:58 pm
Quoting CXfirst (Reply 13):
Without knowing your graphics card, based on the information I know, I'd say FS9.
CXfirst
Mon Jan 07, 2008 3:35 pm
Quoting Jamesbaldwyn (Reply 14):
I can almost safely say that it won't run FSX, but I'm still a bit skeptical on FS9
-CXfirst
vinniewinnie
Wed Jan 09, 2008 10:08 am
The problem with laptops is overheating: Once you leave FS for a few hours on the processor really heats up which slows down general performance...
N231YE
Wed Jan 09, 2008 1:13 pm
Should work fine, even at max settings. My older Tablet PC, which has older components in it, ran FS9 beautifully at max settings. FSX though, is a different story.
Specs: Acer TravelMate C314XMi with Intel Pentium M 760 (2.0GHz), 2GB 533MHz DDR2 SDRAM, NVIDIA GeForce Go 6200-128MB, Windows Vista Ultimate
IH8BY
Mon Jan 14, 2008 7:46 pm
I've been running FS2002 and then FS9 on my laptop over the last few years. Performance isn't amazing, and you do have to make compromises for either performance or visuals; you can't have both! But then again your system specs are much improved over mine:
Windows XP Home
Intel Celeron D (!) 2.8GHz
768MB RAM
40GB HDD
ATi Radeon 7000 IGP (uses up 128MB of my RAM, so I end up with 640MB)
I can't get water effects such as reflections as the DirectX support isn't up to date enough, but it looks OK. Given all that, unless you have issues with Vista the system should run FS9 fine.
Have you ever felt like you could float into the sky / like the laws of physics simply don't apply?
acroairfun
Fri Feb 01, 2008 1:37 pm
My Laptop:
Windows XP Home Edition
Intel Pentium M 1.60 GHz
512 MB RAM memory
40GB HDD
and Intel Extreme Graphics graphic card (I hate Intel graphic cards!).
Don't try to run FS9 on Intel graphic cards! After flight (when the flight duration is over ~20 minutes and you're flying by a big aircraft) you must always restart your computer, because the drivers always "die"!  Wow!  Angry  Angry  Angry  bomb   confused
Everything is flexible if you know how to bend it.
Gerry
Sat Feb 02, 2008 3:29 am
VinnieMinnie,
Agreed - overheating is a major problem when running FS9 on a laptop for extended periods. I bought a simple $30 USB cooling pad with three fans and the problem disappeared. By the way my laptop is a 3 year old ACER Ferrari 3400 with 1 Gb Ram, 128Mb video and an Athlon64 CPU. Runs like a dream even at high graphics settings but I do need that fan on.
Gerry
QFA380
Sat Feb 02, 2008 8:25 am
Quoting Gerry (Reply 20):
Hi Gerry, does that work well? If the heat is only moderte will it still bring the computer down or does it only really work when the computer is really hot? What about battery usage, noise and portability? Is your computers performance better with it ie the cooling is allowing it to run faster?
Do you have the Vantec Lapcool?
QantasA333
Sat Feb 02, 2008 10:02 am
Does FS9 work with Mac computers?
Gerry
Sat Feb 02, 2008 10:39 pm
QFA380
I have other Vantec stuff which works very well but all my cooling pad says is "Made in China". Being very simple devices I think that they would all run well. I only run my laptop from the mains while using FS9 and the main problem that it overcame was a total shutdown of fs everytime it got to some 30 minutes into a flight. It doesn't happen anymore - mind you that Athlon 64 chip did run so hot that I could hardly touch the bottom casing of the laptop after about 30 minutes of something as CPU intensive as FLight Sim.
All I can say about performance is that it seems better with the cooling pad but that may be psychological.
Gerry
EMA747
Sun Feb 03, 2008 3:10 pm
Will either of these run FS9 well? Which is best?
Acer Aspire 5520 TL58
AMD Turion™ 64 X2 Dual Core
NVIDIA® GeForce® 8400M, 128MB shared
Memory 2Gb
or
HP dv6527
AMD Athlon 64 X2 mobile
NVIDIA® GeForce™ 7150M - Up to 559 MB total available graphics memory
Memory 2Gb
Failing doesn’t make you a failure. Giving up and refusing to try again does!
acroairfun
Tue Feb 05, 2008 8:23 am
Quoting EMA747 (Reply 24):
FS doesn't need Dual Core. Anyway, I prefer Athlons. Shared memories aren't good - I think. on HP dv6527 you have older graphic card, but you wrote "Up to 559 MB total available graphics memory". If this 2GB of RAM are DDR I think HP will be better for FS.  Big grin  airplane
ShyFlyer
Sun Feb 10, 2008 7:09 am
For what it's worth, here are my specs:
Dell XPS M1730 w/ Windows XP Professional
2.6Ghz Core2 Duo
nVidia SLI Dual GeForce 8700MGT with 512MB GDDR3 Memory
4GB, DDR2, 667MHz 2 Dimm RAM
200G 7200RPM SATA Hard Drive
I've only recently installed FS9 and the little bit of flying I've done have proved the investment in this laptop was worth it. I have nearly all the sliders maxed out, and everything is buttery smooth. The only issue I'm having is a problem adjusting the contrast. While the nVidia control panel allows me to make adjustments, it always reverts to the default settings when I boot up.
Quoting Gerry (Reply 23):
A good cooling pad is always a good idea for a laptop, especially for gamers.
