MaverickM11
Planning Flights In FS With Winds Aloft
Fri Jan 11, 2008 2:59 am
Is there a good way to choose a route in FS2004 taking into account the winds aloft? In other words how can I find out whether it's better to fly, say, ORD-BOM over the pole or over Europe using the winds that are programmed into FS2004 (they are real updated winds)?
E pur si muove -Galileo
N231YE
RE: Planning Flights In FS With Winds Aloft
Mon Jan 14, 2008 2:32 pm
Assuming you are using real world data and flying only within the USA, you can go to this site. You probably will have to interpolate data (they do in the real world) for locations that are between forecasting stations.
pilotboi
Mon Jan 14, 2008 3:33 pm
Quoting MaverickM11 (Thread starter):
If you choose that option. It's in the wx setup dialog box.
MaverickM11
Tue Jan 15, 2008 9:02 pm
How abou trans oceanic flights?
MaverickM11
Mon Mar 03, 2008 5:27 pm
Nada? I'm surprised. How do y'all plan transpolar flights? Just point and fly?
MHTripple7
Mon Mar 03, 2008 11:19 pm
What I do when flying transatlantic flights online is look up current or recent flights of the routes I want to fly on flightaware.com. Then, I plug those routes into a freeware addon called vasFMC, which couples with the autopilot and will fly the route for you.
Mir
Tue Mar 04, 2008 6:27 am
http://squall.sfsu.edu/crws/jetstream.html
They have several pictures of current charts showing approximate direction and relative speed of winds aloft (300mb level only - about 30,000ft) I take a look at what the winds are doing, and plan my flight along the appropriate airways using FSNavigator.
As an example, for ORD-BOM with the current winds, I'd say about an ORD-Greenland-Black Sea-India route would keep you in the tailwind the most while minimizing diversions (not worth it to follow the big troughs off the Newfoundland coast or south of the UK).
Flightaware helps out a lot as well.
-Mir
TropicalSQ744
Thu Mar 06, 2008 4:03 pm
Jetstream forecasts for Asia and other regions can be obtained here:
http://www.wunderground.com/global/Region/EU/2xJetStream.html
 Smile
DMK(TG773/772) PEN(SQ772/MH734) PER(QF333) PEK(CA763) HKT(MI320) HKG(SQ744) ICN (OZ333), CJU,TAE(OZ734) TPE(3K320) KUL(T
kimberlyRJ
Fri Mar 07, 2008 2:18 pm
Hello
I always follow this procedure when planning flight sim routes etc
1.While in flight sim plot the course using FS Navigator 4.7
2.Take the data and input it to FS Build 2.3.0 (this send your flight plan to any number of FS utilities including FS itself, Feel There, PMDG, Level-D & Active Sky
3.Using Active Sky I import the route, which gives me all the weather information you will never need, departure airport weather, in flight winds and temps etc
4.Engage the relevant fuel planner for the aircraft your using (I fly either feel there, PMDG or Level D – all of which have their fuel planners etc
5.Fly
Active Sky is the best utility for FS weather planning, it’s great! The website is http://www.hifisim.com/
Give me a shout if you need any further assistance.
Kimberly
