soon7x7
Best Adhesive For Braz Parts?
Tue Jan 15, 2008 6:34 pm
I'm adding BRAZ upgrade vertical fin to styrene a330 1/144th kit, what is the best adhesive for this application...epoxy?
Also ar e BRAZ (resin) optional parts compatible with styrene adhesives?
alaskamd80
RE: Best Adhesive For Braz Parts?
Tue Jan 15, 2008 6:51 pm
Hi, you should check out this forum they have all the answers for model building..
www.airlinercafe.com
Luciano
doug_or
Fri Jan 18, 2008 2:16 am
Epoxy or superglue (CyA). Make sure to thoroughly clean the parts beforehand. Normal plastic model glue will not melt the resin and therefore will not make a good bond.
When in doubt, one B pump off
soon7x7
Tue Jan 29, 2008 5:17 pm
Quoting Doug_Or (Reply 2):
thnx, epoxied them,worked great!
