kingsford
FlightOne ATR72 FSX How To Get Cockpit To Work?
Fri Feb 08, 2008 5:59 pm
Bought the add-on last week and in spite of following all the (unnecessary complicated) instructions to get the cockpit to work, all I have is black instruments... anybody out there could solve that I would be so happy. I have Windows Vista by the way.
If I go through the trouble of buying an add-on I expect it to work after the installation, with all the liveries. In this one, you also have to install the liveries yourself by installing Text-O-Matic software, then configure, then this then that...
Pitty because the model is really cool. Anybody with a solution for the cockpit ?
spencesaab
RE: FlightOne ATR72 FSX How To Get Cockpit To Work?
Thu Feb 14, 2008 5:21 pm
I can't say I've ever had a problem with the cockpit, however I did have problems with the liveries not loading with SP2 for FSX.
I solved it y reverting back to just SP1, then reinstalling SP2 - seemed to do the trick, don't know why it should or why there was a problem in the first place!
Hope that helps.
BTW, if you haven't got the service updates, you need SP1 to use addons. I assume you know this, and sorry to waste your time if you do - but to get the service packs go to www.fsinsider.com
Silence is Golden when you don't know a good answer
