FSX A/c Range Question.
Sat Apr 12, 2008 1:03 pm
I just have a question: Why do the aircrafts in FSX have so little range. I cant for example even make LAX-JFK non stop with the 738. In the reality you can do that route easily with the 738. Why is it like this??
dw747400
RE: FSX A/c Range Question.
Sat Apr 12, 2008 3:16 pm
What altitude and cruise mode are you using? Whats your payload?
CFI--Certfied Freakin Idiot
Sat Apr 12, 2008 3:39 pm
Quoting Dw747400 (Reply 1):
37.000ft and 0.79m. The loads are: Full fuel load, and 22850 pounds of payload.
ACDC8
Sat Apr 12, 2008 7:27 pm
Just click the engines stay on when out of fuel feature and you'll be fine ....
[Edited 2008-04-12 12:28:32]
A Grumpy German Is A Sauerkraut
Sat Apr 12, 2008 7:42 pm
Quoting ACDC8 (Reply 3):
He,he. True, but you cant do that in the reality, right??  Wink
ACDC8
Sat Apr 12, 2008 7:55 pm
Quoting B747forever (Reply 4):
It's a game, just don't tell anyone and no one will know ...  Wink Some things if FS are just so unrealistic that you have to cheat a bit now and then.
Also, if you're using the default 737 in FS, you may want to try an aftermarket add-on such as PMDG or POSKY for a more realistic experience. POSKY is free btw.
Sat Apr 12, 2008 8:12 pm
Quoting ACDC8 (Reply 5):
POSKY is free btw
Then will try POSKY. Do you know where I can find it??
ACDC8
Sat Apr 12, 2008 8:18 pm
Quoting B747forever (Reply 6):
http://www.projectopensky.com/
www.avsim.com is another great site, it's free as well but you have to regisiter.
Sat Apr 12, 2008 8:24 pm
Quoting ACDC8 (Reply 7):
Great thank you so much. What will I need to do to get the files to work?? Where shall I install them, in which map and so on???
ACDC8
Sat Apr 12, 2008 8:31 pm
Quoting B747forever (Reply 8):
Everything that you need is there, just download the base/model package of the aircraft you want and download the airline package you want. Download them into a designated folder, open them up and follow the instructions on where to put the files in your FS folder. Try avsim for some more realisitic engine sound files as well. The only other program you'll need is WinZip to unzip the downloaded files.
Sat Apr 12, 2008 8:44 pm
Quoting ACDC8 (Reply 9):
Thank you so much for everything. Will try if it works!!
dw747400
Sun Apr 13, 2008 3:20 pm
Quoting B747forever (Reply 2):
I can't make any promises that the model is accurate, but you may want to slow down a bit. BBJs I work with typically do .76 on long legs. Domestically they can do .80 transcons, but they have a lot more fuel and a lot less payload than a commercial 738.
Sun Apr 13, 2008 6:22 pm
Quoting Dw747400 (Reply 11):
Will try that. Hope it works.
9VSIO
Mon Apr 14, 2008 12:02 am
How's your step climbing?
Me: (Lining up on final) I shall now select an aiming point. || Instructor: Well, I hope it's the runway...
Mon Apr 14, 2008 6:32 am
Quoting 9VSIO (Reply 13):
When I climb to the cruise altitude, I climb everything between 1000-3500ft/min.
ACDC8
Mon Apr 14, 2008 7:13 am
Quoting B747forever (Reply 14):
A step climb is basically a climb done in steps to your cruising altitude. Let's say you want a cruising altitude of FL350, what you would do is maybe climb to FL280 and maintain that altitude until you've burned off fuel. Once the aircraft is lighter, you would climb to FL320 and maintain that altitude until you've burned more fuel. Once the aircraft has again become lighter, you continue your climb to FL350. Kind of like stairs. The idea is that this is the most fuel efficient way to climb to an altitude. Of course, it depends on your type of aircraft, weight of aircraft and atmospheric conditions.
wilco737
Mon Apr 14, 2008 7:20 am
Quoting ACDC8 (Reply 15):
 thumbsup  but try to stay within the semicircular rules. Westboud fly at even flightlevels and eastbound at odd flightlevels. The 737 would be able to get to FL310 with MTOW and then as ACDC8 said, do the stepclimbs. Starting FL310 (eastbound from LAX to JFK) and ending maybe 370 or so. With that high load she won't get higher.
WILCO737 (MD11F)
 airplane
ACDC8
Tue Apr 15, 2008 5:37 am
Quoting WILCO737 (Reply 16):
 checkmark  Same applies to VFR cruise altitudes, for example in Canada it would be 000°-179° is odd thousand feet plus 500 feet and 180°-359° is even thousand feet plus 500 feet.
9VSIO
Tue Apr 15, 2008 5:47 am
That will affect fuel burn. Give it a go with step climbing. Climb to FL280, let fuel burn to 90% or so, then climb to FL320, then let fuel come down some more, then all the way up to FL390 (in increments). Don't let your speed bleed off too much in the climb, or it'll take forever to get back up to speed. It's much harder to manage this without a FMC. I've been having to judge manually on my CitationX to maximise its potential.
Also, what wind settings do you use?
Tue Apr 15, 2008 1:17 pm
Quoting 9VSIO (Reply 18):
Will try that.
Thank you for all help guys. You are really professional  Wink
