QANTAS077
PSS 777 Help
Wed Apr 16, 2008 5:12 am
hi all,
been using the 777 for some time now and I came across this problem today, first time too! anyways, I go to set my position on the initialise page by entering the 4 letter airport code and its now saying that the airport is not in the db...I've tried a variety of codes to see if it was unique but its not, seems none of the 4 letter codes are "in database"...
can anyone help me out here or point me in the right direction?
thx
wilco737
RE: PSS 777 Help
Wed Apr 16, 2008 5:36 am
Quoting QANTAS077 (Thread starter):
Can you enter the 4 letter code on the Route page? I mean where you enter your depature and destination airport? Or do you get the same message here?
It sounds correct to me what you do. But maybe this feature isn't available on the PSS777? I don't use this PSS777, so I don't know for sure! But it's just a thought. IF you can enter the airport on the Route page, then there is just something wrong with the present position thingy. IF you cannot enter the airport there, then it seems to be a general db problem. Try to re-install it or contact the costumer service for PSS, they should know about it.
WILCO737 (MD11F)
 airplane
QANTAS077
RE: PSS 777 Help
Wed Apr 16, 2008 6:04 am
I couldn't but I can now...decided a new install of the a/c would fix the problem and it did...thanks!
wilco737
RE: PSS 777 Help
Wed Apr 16, 2008 6:50 am
Quoting QANTAS077 (Reply 2):
 thumbsup  very good! safe flying  Wink
WILCO737 (MD11F)
 airplane
QANTAS077
RE: PSS 777 Help
Wed Apr 16, 2008 6:55 am
just passing over Japanese mainland from Incheon to Narita!  Wink
